Like Tree40Likes
 Old 09-09-2013, 05:15 AM   #441
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Wanna bet?
"Exclusivity" - CP-enis
Demodded.
The Seals
kabobulate (09-09-2013), silvapain (09-09-2013)
 Old 09-09-2013, 11:56 AM   #442
2.3speed06's Avatar
Posts: 811   (View Stats)
2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world
I guess we'll find out when I can make it down there.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
2006 Black Cherry Mica Mazdaspeed 6 GT
Cobb AP 50/50 FREEKTune/Cobb 3port EBCS/C-PE Nano Intake/C-PE TIP/C-PE TMIC/HKS SQ3 BOV/Auto Tech HPFP/M2 DP/Custom CB/Denso ITV 22's/JBR RMM/Sure SSP/Sure Shifter Bushings/Custom EGR Kit/TB&IM TIG/MD Stage2 OCC/Koni Yellow S&S/H&R LS/Stoptech Blanks/EBC Red/Techna-Fit SS Brake Lines/
2.3speed06 is offline   Reply With Quote
 Old 09-21-2013, 03:39 PM   #443
speeding3's Avatar
Posts: 118   (View Stats)
speeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond repute
Any updates on this looking forward to seeing results
speeding3 is offline   Reply With Quote
 Old 09-21-2013, 06:28 PM   #444
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
I'm on the RP but it's too soon to say for sure. So far, so good. I'll have a final answer tomorrow most likely, with regular updates after that, so long as it doesn't shit the bed.
El_Diablo (09-21-2013), mazdafreak (09-21-2013), wolly6973 (09-23-2013)
 Old 09-22-2013, 10:42 AM   #445
Enki's Avatar
Pressure dropped off halfway through my morning trip; I will say, however, that while cruising on the freeway the engine was "kicking" quite a bit and AFRs were stable, so I take that as a sign that the pressure was trying to come back.
Also, the moment I got home, pressure started to return and at some point was even at target. While it doesn't last long, I hold hope for my next oil change removing more of the old oil which is what I'm thinking is the cause of the current issues.
That said, I'll be pulling the spill valve this afternoon to see if that is the only issue (which I'm hoping is the case). If it isn't, I'll be going back to 50/50 until sometime after next oil change (which will be in the next couple months, and will be RP again).
Constantin (09-24-2013), El_Diablo (09-22-2013)
 Old 09-22-2013, 05:16 PM   #446
Enki's Avatar
IT'S ALIVE!
Spill valve had a little sticky. 5 minutes and back at full gumption; 1/4 tank down, let's see how far this goes.
 Old 09-22-2013, 06:40 PM   #447
He Hate Me's Avatar
Posts: 460   (View Stats)
He Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the world
Dunno if this has been discussed, but came across this. Willing to give it a try.
He Hate Me is offline   Reply With Quote
The Following 3 Users Say Thank You to He Hate Me For This Useful Post:
Constantin (09-24-2013), El_Diablo (09-22-2013), Enki (09-22-2013)
 Old 09-22-2013, 06:43 PM   #448
Enki's Avatar
I can try that with RP too; I'm basically invested in doing the next 2 or so oil changes with it.
El_Diablo (09-22-2013), He Hate Me (09-22-2013)
 Old 09-22-2013, 06:46 PM   #449
He Hate Me's Avatar
Interested to see results of that, to see if it's even worth trying this ULX110. Because it could separate it when it's new but after some cycle through the engine it could break down and allow the E85 to blend with it.
So definitely interested to see how some RP unused mixes (or doesn't) with E85.
Finding this ULX110 looks to be a challenge in the U.S as wel...
 Old 09-22-2013, 06:56 PM   #450
He Hate Me's Avatar
Found a contact in the U.S
ULX110 USA Manufacturer
Coolant Control Inc.
5353 Spring Grove Avenue
Cincinnati, Ohio 45217
U.S.A.
Toll-Free Phone: 1-800 535 3885
 Old 09-22-2013, 10:47 PM   #451
Mfinlay04's Avatar
Posts: 827   (View Stats)
If the fuel pressure holds, it'd be interesting to see a UOA on the RP after 3000 miles or so. From what I've seen over at bitog rp sucks balls compared to pretty much ever other uoa for most cars.
But if it allows us to run 100% e85 it might be a trade off
2006 MS6 Titanium Grey
Tuned with
 Old 09-22-2013, 10:56 PM   #452
He Hate Me's Avatar
I've also read the same things of RP breaking down pretty fast. I've seen a lot of people say it's good for a few runs down the track and it's broken down pretty fast.
Nevertheless, I'd like to see you mix some fresh RP and E85, and shake it and see how bad(or good)it "dilutes" begin with @Enki.
I have a feeling that any unused oil will separate E85, but it's finding an oil that works for a decent amount of time and how well it works inside the HPFP.
Mfinlay04 likes this.
The Following 2 Users Say Thank You to He Hate Me For This Useful Post:
El_Diablo (09-23-2013), Mfinlay04 (09-22-2013)
 Old 09-23-2013, 12:00 AM   #453
Enki's Avatar
This UOA seems to be decent-ish:
Royal Purple 5W30 UOA
I'll know more for sure when I do my first UOA though; I've asked for two kits, so depending on the results from the first test, I may be changing the oil sooner/later.
 Old 09-23-2013, 05:06 AM   #454
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
There are so many different types of RP that you really cant just say they all suck. Which version are you using currently @Enki;?
 Old 09-23-2013, 10:11 AM   #455
Enki's Avatar
As stated in the other thread:
 Old 09-23-2013, 10:26 AM   #456
El_Diablo's Avatar
Groans: 769
I believe that is their HPS series which might hold up a little better over the long haul.
 Old 09-23-2013, 10:44 AM   #457
Enki's Avatar
We will see. I've ordered test kit(s) from Blackstone.
 Old 09-23-2013, 05:15 PM   #458
Enki's Avatar
So went out for lunch today, about 40 minutes round trip. Pressure fell out on the way back, but did the same thing it did the previous time; it fought to come back, so I'm pretty sure it's just the spill valve again.
I'll go clean it a little later and see what's up, but I'll probably go back to 50/50 until sometime after the next oil change before I continue testing it, or until the scraper gets built.
If it is just spill valve again (likely), then it's already a huge ass leap forward on this problem.
El_Diablo (09-23-2013), PapaSmurf (09-23-2013)
 Old 09-24-2013, 08:50 PM   #459
Enki's Avatar
Update posted here:
Kings of Corn (HPFP + OIL)
 Old 06-06-2014, 01:05 PM   #460
fullboostms3's Avatar
Posts: 7   (View Stats)
fullboostms3 will become famous soon enough
Any news in this issue? Started having the p0091 code and car won't boost and hpfp reading is at 60psi at idle. Wondering if anyone has came up with a fix, mods are stage 2 ots with cat less downpipe, tih, auto tech internals, cai, Cbe, turbo smart bpv, fmic. Any help would be appreciated
fullboostms3 is offline   Reply With Quote
 Old 06-06-2014, 01:45 PM   #461
Enki's Avatar
Epic first post brah.
Easter Bunny (06-07-2014), udntknw (06-07-2014)
 Old 06-06-2014, 01:53 PM   #462
bladerunner10121's Avatar
Posts: 83   (View Stats)
bladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the world
Check the flux-capacitor for the HPFP.
I've seen the "stage 2 OTS" map short the capacitor and cause HPFP issues. If that's your problem good luck finding a replacement.
bladerunner10121 is offline   Reply With Quote
 Old 06-06-2014, 03:31 PM   #463
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
60psi at idle is pretty much the pressure from the in-tank fuel pump. Sounds like you might need to pull the hpfp internals and examine
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 06-09-2014, 10:06 PM   #464
Ended up taking it all apart and cleaning the spill valve, and hpfp and no more problems. Thanks for the help though
The Following User Says Thank You to fullboostms3 For This Useful Post:
himurax13 (06-09-2014)
 Old 10-23-2014, 03:48 PM   #465
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
I did not read all 12 pages because I don't feel like it. But just glancing on Mobil 1's website I found this QA:
Question:
Which Motor Oil Is Best for Engines Using E85 Fuel
I am using E85 fuel in a converted Honda engine originally not designed for its use. One of the primary concerns of this is the formic acid created in the event of water contamination of the fuel. I have always used Mobil 1 5W-20, but am wondering if Mobil Clean or Extended Performance would be a better choice for me. What Mobil oil has the greatest amount of acid neutralizers in it?
-- Andrew Champion, Frisco, CO
Answer:
We recommend you use a heavy duty diesel product if you want additional acid neutralizer. We recommend you try Mobil 1 Turbo Diesel Truck 5W-40 as it is based on HD diesel technology, which contains additional over-based detergents for acid neutralization.
So it sounds like we're on the right track with our Rotella, still.
 Old 10-23-2014, 04:20 PM   #466
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
http://www.nulon.com.au/products/Ful.../#.VEl6g8szHqB
Found this here in Australia, looks like it has potential...
Meets the desox requirements and also states that it's ethanol happy!
Also comes in a 6L bottle (engine takes 5.7)
 Old 10-23-2014, 04:24 PM   #467
Enki's Avatar
My original testing and my current local full corn tester refute that statement completely.
Full Synthetic 5W-30 Long Life Engine Oil- Nulon Australia
Only one way to find out!
OverBoosted (10-24-2014), wolly6973 (10-23-2014)
 Old 10-26-2014, 03:50 AM   #468
Spectrix's Avatar
Posts: 332   (View Stats)
Groaned at 7 Times in 3 Posts
I wonder if an oils ability to withstand fuel dilution in a crankcase might make it even more prone to adding to black death/sticky problems in an MZR fuel pump. We see this with Rotella.
2008 Gen1 MS3
Self tuned on E85
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/resolving-hpfp-corn-woes-black-death-sticking-107141/
E85 issues with injectors? - Page 3 - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 09-12-2014 09:25 PM
Quel est le meilleur carburant? - Mazda 3 Quebec This thread Refback 05-26-2014 10:29 AM
/v/ - Vehicles This thread Refback 03-05-2014 09:35 PM
HOW TO: Remove & Disassemble HPFP Spill Valve silvapain MazdaSpeed 3/6 - E85 Fueling 139 04-09-2018 04:02 AM
Spill valve spring mod Enki MazdaSpeed 3/6 - E85 Fueling 15 02-02-2014 11:01 AM
HOWTO: Spill Valve SST Enki MazdaSpeed 3/6 - E85 Fueling 9 02-17-2012 09:07 AM
hpfp woes 37HSSV 2010 MS3 - Engine, Transmission & Driveline 5 11-14-2011 09:00 AM
HPFP Woes 37HSSV 2010 MS3 - Troubleshoot/Diagnostics 9 11-13-2011 03:44 PM
Page generated in 0.50998 seconds with 33 queries
