  • 1 Post By littleloogy
  • 1 Post By mokidii
 Old 05-10-2015, 10:33 AM   #1
lolwrx's Avatar
Posts: 217   (View Stats)
lolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the world
Default Spill Valve O-Ring
Hey guys today I took off my spill valve to clean and lube it up with some redline S1. Its most likely the first time the valve has ever been taken off and as i un screwed it the O ring snapped in two.
I found the correct dimensions on another thread already and ordered a new one but I was wondering if any plain rubber O ring gasket would do. Just wanted to know if I could go look for one at lowes to get me by or if it most likely wouldn't hold up to the fuel/heat? Thanks
BNR s3, Freek 3.5", Autotech internals, depo racing catless dp, TR6, JBR FMIC piping, 80a rmm, OCC, TIGs, EGR delete and Coolant bypass
FREEKTUNED
lolwrx is offline   Reply With Quote
 Old 05-10-2015, 11:02 AM   #2
littleloogy's Avatar
Posts: 4,005   (View Stats)
I did the same thing when I took mine off the first time as well. Son of a bitch ripped. I then tried to a use a regular nothing special o-ring, but it started breaking down. (Black shit, looked like ink). But it did seal. I ran it that way for a few days until my replacement came in. So in short... As long as it seals, it should be fine. just don't don't forget about it and use it as a permanent fix.
Remember, that spill valve area only sees ITFP pressure. As long as it does not leak when your turn your key to the on position, you will be okay.
Sent from my iPhone 6
lolwrx likes this.
Enki (05-10-2015), lolwrx (05-10-2015)
 Old 05-10-2015, 11:23 AM   #3
lolwrx's Avatar
Thanks man!
FREEKTUNED
 Old 07-04-2015, 01:12 AM   #4
mokidii's Avatar
Posts: 15   (View Stats)
mokidii is a jewel in the roughmokidii is a jewel in the roughmokidii is a jewel in the roughmokidii is a jewel in the rough
Would you guys happen to have the part number for that o ring? Or where would I find a replacement? Mine is in two pieces lol.
Sent from my SAMSUNG-SM-G920A using Tapatalk
2012 Black Mica Mazdaspeed3
PTE 6266 | PD tuned | Manley Pistons/Rods | Crower 65lb Valvesprings | L19 Headstuds | Keyed Crank/Pinned Cams | JMF PI Intake Manifold W/ 4x 1000cc injectors | Fuel Lab Fuel Pressure Regulator | AEM 385 LPH Inline Fuel Pump | AEM Wideband Failsafe | JBR tru 3.5" Intake | Treadstone Fmic w/ TR8L | Forge BPV V2 | John Russel V-band Tubular Exhaust Manifold | Kozmic Catless Downpipe | Custom 3" CBE | Corksport HPFP | AP V3 | MD Trilogy Mounts
mokidii is offline   Reply With Quote
 Old 07-04-2015, 06:05 AM   #5
lolwrx's Avatar
Pm me your address and I'll send one out. I had to order a 10 pack when I got them lol
FREEKTUNED
The Following 3 Users Say Thank You to lolwrx For This Useful Post:
brandonnicholson (07-04-2015), Enki (07-04-2015), g00s3y (07-04-2015)
 Old 07-05-2015, 03:23 AM   #6
mokidii's Avatar
I actually bought 10 too lol. Found a thread where it listed all the replacement o rings and ordered it last night, thanks though I appreciate it
Using a generic autozone one for now, I'm on straight 91 so hopefully the gas won't dissolve the o ring like mentioned earlier in the thread.
lolwrx likes this.
HOWTO: Spill Valve SST Enki MazdaSpeed 3/6 - E85 Fueling 9 02-17-2012 09:07 AM
Page generated in 0.26985 seconds with 22 queries
