| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
(Thread Starter) | Not Ranked : 0 score By default, these tables are set to 2.5 load (which is where the issue the other guys have). For shits and grins, I set mine to 1.75 (as I'm pretty much over 1.8 all the time when wot. Both sets of pulls on both 1.75 and 2.5 maps (which is the ONLY difference between the two) were done AFTER flogging the shit out of it before hand to get the trims settled. With some more testing, it might be safe to rename these to "Fuel Trim Load Limit" instead of closed loop since they obviously effect "open" loop as well. Food for thought; logs attached.
__________________ |
| The Following 11 Users Say Thank You to Enki For This Useful Post: | HawkeyeGeoff (12-02-2015), LumberJack (12-02-2015), meicalnissyen (10-26-2016), Micha (12-25-2015), MS3Shadow (12-02-2015), RE-ACTIONENGSPEED3 (12-02-2015), SpeedRebirth (12-04-2015), taf0422 (12-02-2015), TiGraySpeed6 (12-02-2015), WetzMS3 (12-03-2015), xfeejayx (12-07-2015) |
| Not Ranked : 0 score I guess I'm missing what this means. Is there some sort of closed loop to open loop slow transition that causes the slow downward drift in AFR? Is there any associated transition time that can be changed.
__________________ Max Bolted and Built Stock K04 |
(Thread Starter) | Not Ranked : 0 score No. There are two types of fuel trims, both of which have limits. The closed loop fuel trims show up in the stft and ltft numbers; the open loop fuel trims do not. The closed loop fuel trims are inactive at/after the targets specified in the "Closed loop open loop threshold" tables, whereas the open loop fuel trims have no visible (loggable) value, and are inactive at/after the load specified in the "Closed loop load limit x" tables (which is a bit of a misnaming for the tables, honestly). Once you are past the values set for the end of the open loop fuel trims, it defaults to ZERO trims. Basically, if your ECU is adding 10% fuel up to the load value specified in the "Closed loop load limit x" tables, and you go a little further load wise, you lose all trims and will run 10% leaner (or off target, if you will). That's why this is important to have control over. Another example: You're spraying a metric fuckload of methanol, but have enough injector overhead to not need it. Let's also say you never go over the value specified in this table. The ECU will compensate for the meth, and if it ever shuts off, you lose all that fueling headroom and immediately run lean. If you're on pump gas, you lose the motor. If you had this turned down to below the threshold where your meth starts to spray, you basically wind up hitting your AFR target instead of running rich when your meth fails.
| The Following 5 Users Say Thank You to Enki For This Useful Post: | meicalnissyen (10-26-2016), MS3Shadow (12-05-2015), Nliiitend1 (12-03-2015), SpeedRebirth (12-04-2015), WetzMS3 (12-03-2015) |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score So during the initial tuning phase's when one is dialing in the maf curve. Would a smart approach be to lower this limit as to see the wot portion of the curve in true open loop and dial it in. Then raise the limits back up? Or just raise them if load conditions get near the limit? |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Nice work! I stare at the code till I'm cross-eyed, but I don't always see what it's doing. Thanks for taking the time to experiment and log! |
| The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post: |
If I wasn't going to spray meth for aux cooling, I'd do the same but set it back up to above what I'll be hitting at WOT for safety after the load is dialed in.
__________________ Last edited by Enki; 12-03-2015 at 10:40 PM. Reason: MSF Database - Automerged Doublepost | ||
| Not Ranked : 0 score @Enki; Since I missed the point originally, I'll try this again and see if it's similar to what you are saying. When I started spraying Meth in my GenPu, it obviously messes with the AFRs. Plus, the GenPu corrects some open loop. I tried to make it so that when spraying, I was just under where the ECU could correct, and if the Meth fails, I should have that 8% or so correction to help save my motor?
(Thread Starter) | Not Ranked : 0 score Let's say you're hitting 2.3 load when WOT. With these tables set to 2.5 load, it will correct for meth; you target 12:1 AFR, you get 12:1 AFR, even with meth spraying. If your meth setup fails, and you don't have enough fueling headroom to auto trim (which would happen after current WOT pull, I believe), you will run lean. If you set this table to 2.0 load, have a spot on MAFCAL and target 12:1 AFR, when spraying meth you will run rich. If it fails, you'll just hit target AFRS.
| Not Ranked : 0 score In OP you said "competition had some problems" are you referring to a company that produces a port to access our ecu? Also has anyone ever tried running our car as a fully closed loop system (ie set the transition value above whats achievable)? Might not be possible thinking about it because it probably uses throttle position too. If so is there a table for that? My 135i uses a fully closed loop system and has fuel trims at WOT, tuning is a breeze. There's one table for each "bank" so there's no messing around with CL/OL tables.
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] | |
| The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Mazdazilla6 (12-05-2015), xfeejayx (12-07-2015) |
| Not Ranked : 0 score Awesome! Do you still currently have it set up that way or did you go back for any reason?
| Not Ranked : 0 score No i m open loop.The basic reason i went back to open loop is to hold at a steady % my idc% so that i can play with my aux fueling.
| The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Mazdazilla6 (12-05-2015) |
(Thread Starter) | Not Ranked : 0 score Technically with these tables set up you're in a sort of hybrid closed/open loop with an individual (probably third and thus unviewable) trim. I wouldn't think staying closed loop full time would be a good idea due to reaction speed of the trimming system (it's not terribly fast). It seems like this third trim carries over the LTFT it was last at and makes adjustments for the next WOT pull rather than trying to do it immediately. When I'm done with my build I'll probably set these to the same as the open/close threshold, MAFCAL properly, then re-enable it after for safety (up to the point where I start spraying meth, which I don't want compensated).
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score Thread revival ![]() If the ''closed loop load limits'' tables are set to 3.0 load, will this extended the open loop trims to 3.0 load...or is the ECU limiting this to 2.5 and lower load!? Im asking because I inject lots of meth, and want to scale the MAF at a minimum...
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
![]() Join Date: Oct 2013 Location: FL -IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
Edit: this is with single d07 nozzle. I tried with a single d10 and ecu couldn't trim enough to hit targets, which then I actually had to scale my maf for that nozzle size. Since you say you are spraying lots of it, you will prob have to scale maf as well. | |
| The Following User Says Thank You to GabbyChaves For This Useful Post: | torquemaniac (10-17-2016) |
(Thread Starter) | Not Ranked : 0 score If you want to scale the MAF, you should reduce these tables, not raise them (if you aren't using meth as aux fuel, anyways). Let it run a bit rich, and if it fails, no big deal as you'll be on target vs rich.
| Not Ranked : 0 score Im running 4 X 0.6mm Aquamist nozzles in the manifold ports (about 15gph, 100% meth)...scaling is absolutely necessary
![]() | | #19 | ![]() |
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
Necro-ish I have been reading alot of late this caught my eye Strong post, strongly worded I keep my jizz intank, but still..... food for thought I have just done a bit of work on timing with OL Seems the CL tables are normally left alone they normally transition well..........but i the gap is large
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch | |
![]() | | #20 | ![]() |
sent from my Pixel XL
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
![]() | | #21 | ![]() |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not on my car; might as well be only one set of tables.
![]() | | #23 | ![]() |
![]() Join Date: Feb 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score Enki is this table / function specific to the Gen 2 ECU?
__________________ - 2008 Gen1 MS3 Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires. Self tuned on E85 |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score No, every gen most likely. This thread is about my genwon, so it's obviously in the 09 version of VT at a minimum.
| Display Modes | |
| Closed Loop Knock | Madman2015 | 2010 MS3 - ECU Computer Tuning | 5 | 08-05-2011 06:51 PM |
| Closed Loop Tables | SLS MS3 | Cobb ATR Support | 29 | 05-09-2011 10:06 AM |
| MS6 Closed Loop changes | SLS MS3 | Cobb ATR Support | 8 | 06-01-2009 06:29 PM |
| Closed Loop, Open Loop | FreeFlyFreak | Cobb ATR Support | 8 | 05-19-2009 11:28 PM |
| Closed and open loop | booya620 | MazdaSpeed 3/6 - ECU Computer Tuning | 39 | 09-23-2008 03:06 PM |
