> VersaTune
 Old 10-23-2015, 03:53 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Default Cruise/idle max timing
One thing I've noticed for a while now is that cruise and idle timing doesn't follow the map; even though I'm only commanding 40 degrees max, it will still run the default of 60. I know that ATR has a different table for this (Ignition global max) which does work, but I don't see a table for this in VT.
I'm bringing this up now because this could potentially be a serious issue for me after my build is done; with my extremely high static compression ratio combined with high rod ratio, 60 degrees of timing could potentially hurt the engine when 20 might be the new maximum (and 5-15 might be MBT @ 8k RPM).
chaser27 (10-26-2015), WetzMS3 (10-26-2015)
 Old 10-24-2015, 04:43 PM   #2
Enki's Avatar
Here's a log of it going over commanded timing, plus my actual map I'm currently running. As the engine warms up, it will exceed target timing and hit as high as 60 degrees, before settling back down around the low 50s.
Issue starts around row 531; missing about 15-30 seconds of data right after the cold start (first start of the day).
 Old 10-26-2015, 07:45 AM   #3
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
send me your current tune.
Steve
Lead Tuner
 Old 10-26-2015, 08:01 AM   #4
Enki's Avatar
Thought I attached it, but forgot that we can't do that here. Email incoming.
 Old 10-31-2015, 11:45 AM   #5
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Got any update on this @Enki; ?
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 10-31-2015, 12:57 PM   #6
Enki's Avatar
Negative.
 Old 11-09-2015, 08:18 PM   #7
Doh. We've had this defined internally for ages, but never exposed. I was looking for something much more complicated. We will expose this table in the next release. Sorry for the delay.
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (11-09-2015), Polish_Eagle (11-11-2015), SpeedRebirth (11-09-2015)
Rough idle after timing job mps606 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 09-19-2014 08:31 AM
Hesitation/Fuel Cut/Pulled Timing at low load cruise...No KR. Please Help! Motocooney MazdaSpeed 3/6 - ECU Computer Tuning 22 01-05-2014 06:51 AM
Timing of ECU settling and initial start up idle speed cudaman MazdaSpeed 3 - Engine, Transmission & Driveline 45 01-27-2012 12:43 PM
What should timing look like at idle? Death-From-A-Mile MazdaSpeed 3/6 - ECU Computer Tuning 6 11-14-2008 07:05 PM
Page generated in 0.27270 seconds with 23 queries
