> VersaTune
 Old 12-14-2011, 09:15 AM   #1
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
Default Feature requests and ideas
I thought it would be more convenient to have all feature requests, ideas, wishes and suggestions for VersaTuner in a separate thread.
To start the list, here are some most wanted things from Lex:
2. EGR control
3. VTCS control
4. Injection timing - something COBB is working on AFAIK but not sure on the progress
Post here if there's anything special you would love to have in VT
Ugnius@VersaTune is offline   Reply With Quote
The Following 4 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
atvfreek (12-18-2011), Lex (12-14-2011), mayer (12-19-2011), rfinkle2 (01-27-2012)
 Old 12-14-2011, 07:46 PM   #2
Alpha Wolf's Avatar
Posts: 396   (View Stats)
Alpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the world
CX7 needs
1. Full throttle in any gear when you command it with your foot
2. Full boost in any gear
3. Traction control to be turned off. It is a pain and I learned to drive on bikes and cars without that nanny ware. Hate it. Kills takeoff and kills hard cornering.
4. Allow car to pull to top speed in 6th with Auto tranny.
5. Be able to pass the mandatory smog inspections every other year.
6. Not blow up engine.
2007 Touring CX-7 Liquid Platinum
Kenwood DDX419 DVD/Bluetooth/CD/ Rosen headrest DVD/Game units CP-E CAI ETS 3" Black Powder Coated TMIC
Forge Black Powder Coated BPV Nitto 420 Tires Vogtland Lowering Springs. Tuned with VersaTune
Alpha Wolf is offline   Reply With Quote
The Following User Says Thank You to Alpha Wolf For This Useful Post:
Zdraveca (12-14-2011)
 Old 12-14-2011, 08:00 PM   #3
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Originally Posted by Alpha Wolf View Post
CX7 needs
  • No Problem - Already done
  • No Problem - Already Done
  • Does the CX-7 have a DSC disable button like the 3/6?
  • Depends more on hardware than the tune, assuming you have rational values for AFR.
  • No Problem - The base tunes are conservative.
When can you start testing
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
rfinkle2 (12-18-2011)
 Old 12-18-2011, 06:28 PM   #4
The interface - would really like to have interpolation functions built in. Both Horizontal and Vertical interpolation. Does the interface have any hotkeys for multiplication, addition etc. when working with table cells?
 Old 12-18-2011, 07:46 PM   #5
Interpolation and smoothing are coming. There are +/-, multiply, and fill functions already for single or multiple cells.
Steve
Lead Tuner
 Old 12-18-2011, 07:56 PM   #6
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
The DSC button doesn't really disable it all the way.
You have to unplug the steering sensor on the 3, for example, to get it all the way off.
Any ideas?
 Old 12-18-2011, 08:25 PM   #7
As I've stated elsewhere, if it is too tightly integrated into the DSC system, we will leave it alone for liability reasons. For straight line acceleration, the DSC disable button does the job. We are looking at the steering angle situation.
Steve
Lead Tuner
 Old 12-18-2011, 08:28 PM   #8
Mizzle's Avatar
Groans: 324
I would assume you could just lie to it and tell it the angle is whatever-degrees all the time and make it detect that when the DSC is disabled, no?
 Old 12-18-2011, 08:41 PM   #9
If the steering angle is only used by the ECU to limit normal torque and is not a part of the DSC function, then we can do something with it. If it's integral to the DSC function, then we will leave it alone.
Steve
Lead Tuner
 Old 12-18-2011, 08:54 PM   #10
Mizzle's Avatar
Groans: 324
It's linked with the car's overall body control system. You can disable the DSC and the car still cuts power when the wheel's turned as well as when the rear wants to slide out.
 Old 12-19-2011, 03:14 AM   #11
Rich-PMS's Avatar
Posts: 1,461   (View Stats)
Rich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the world
Groans: 68
If youd like a genWON test vehicle, feel free to PM me.
Rich-PMS is offline   Reply With Quote
 Old 01-27-2012, 04:47 AM   #12
yurko's Avatar
Posts: 1   (View Stats)
yurko will become famous soon enough
mps gen 2 support?
yurko is offline   Reply With Quote
The Following User Says Thank You to yurko For This Useful Post:
 Old 01-27-2012, 07:30 AM   #13
We are working on Gen2 support. We will announce the availability as soon as it is ready.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Atom88 (02-18-2012), Lex (01-27-2012)
KW Measurement/Photo Requests Design MazdaSpeed 3/6 - Suspension & Brakes 11 05-22-2011 10:31 AM
Lawyer: Dealers can just say 'no' to upgrade requests Haltech Automotive News 1 02-08-2011 12:43 PM
Detroit 3 aid requests exceed $50 billion Haltech Automotive News 0 11-06-2008 06:43 PM
Page generated in 0.32581 seconds with 26 queries
