| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
![]() Join Date: Nov 2015 Location: Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 45
(Thread Starter) | Not Ranked : 0 score I know there is a secondary switch to have a secondary trigger. is there a way to hook up the secondary trigger to versatuner in a way where when versa or the ecu rather detects over boosting and initiates fual cut that it can also do the secondary trigger for the guardian angel. im gathering everything for my build now and want to know what need to do. so when I get to that point I know what I need to do... thank I appreciate the advice!!
__________________ 06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly ![]() Last edited by Juschiln19; 02-23-2017 at 03:10 AM. |
| Not Ranked : 0 score I uh, what
__________________ |
(Thread Starter) | Not Ranked : 0 score I read on one of the write ups that if you go bt that the factory ecu fuel cut and throttle cut wouldn't be fast enough. And that by the time those kicked in that you would have already hit full boost and blew up your motor.
__________________ 06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly ![]() |
(Thread Starter) | Not Ranked : 0 score I seen another speed running a guardian angel but they were running it with ap not versatuner. AP is tuned by boost. Versatuner is tuned by load. So with ap you should never go over the set boost psi. And u can set the Guardian angel to a notch above that. All is well.. but with versatuner boost psi will fluctuate. And will more then likely hit a number at that rpm that at a lower rpm will be really bad. How do u set it up then ? Like it might go 25 psi at 4500 rpm (GOOD) but then it might over boost and hit 25 psi at say 2000 rpm (BAD)
__________________ 06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly ![]() Last edited by Juschiln19; 02-23-2017 at 03:18 AM. |
(Thread Starter) | Not Ranked : 0 score I think I'm over thinking it. I'll just set the angel to a notch above peak boost of map I'm running.. just making sure I cross the T's and dot the I's.. bt & stock block... my bad
| Not Ranked : 0 score You can load tune with an AP as well. The boost based logic is just a toggle within the ECU that Cobb made available. VT has acknowledged its existence but didn't chase it because load tuning is pretty superior to boost tuning. To answer your question, the GA will open the BPV at whatever pressure you set it to. The turbo won't be able to surpass that pressure because opening the BPV is a HUGE pressure drop and only extremely massive turbos (like 80mm+) would be able to make boost with it open. And the factory cuts work just fine, you'll find that out the first time your face hits the windshield.
| The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post: | cyclist20 (02-23-2017), Juschiln19 (02-23-2017) |
__________________ 06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly ![]() | |
| Display Modes | |
| Guardian Angel - How do you Run Yours? | MazdaspeedKills | Mazdaspeed3/6 General Discussion | 2 | 10-03-2014 11:42 AM |
| Guardian Angel help? | MS6FL | Mazdaspeed3/6 General Discussion | 2 | 04-28-2012 07:13 PM |
