> VersaTune
 Old 03-09-2017, 07:45 PM   #1
Trithemius's Avatar
Posts: 44   (View Stats)
Trithemius has much to be proud ofTrithemius has much to be proud ofTrithemius has much to be proud ofTrithemius has much to be proud ofTrithemius has much to be proud ofTrithemius has much to be proud ofTrithemius has much to be proud ofTrithemius has much to be proud ofTrithemius has much to be proud ofTrithemius has much to be proud of
Default IM Absolute Pressure Map Setting
I'm making this thread to figure out how I missed this information, and to help anyone else who may miss it in the future.
About 3 weeks ago, I installed many parts, including a 3 bar map sensor. I informed my tuner, and he sent me a tune that had the proper numbers in the MAP scale tables to work with the 3 Bar. No matter what we tried, the dashboard and logs were showing a -2 psi with engine off and a peak boost of 9 psi on spring, which is supposed to be 14.
I thought maybe the map sensor or adapter was bad, because the tune was fine, but it turned out to be this.
This is the configuration of the Intake Manifold Absolute Pressure parameter on the dashboard. This is completely separate from the tune. Changing the drop down from Stock to Bosch 3 Bar completely fixed my problem. It only took me 3 weeks to find this. Probably because we were monitoring with the Boost Pressure parameter, not this one.
Did I miss something? Is there anywhere that this has been stated, other than a brief mention in the suggestions thread? I know plenty have had success with Versatune, did everyone else just figure this out, and I'm the dummy? Why is this essential setting buried into a parameter that isn't necessary for tuning? Maybe a setting on the tune customizer would be better.
I'm not being critical, just curious to see if others struggled like me, and where I could have found this information.
2007 Mazdaspeed 6 Liquid Silver // BNR S3 V1 // JBR 3" Intake // Grimmspeed 3 port // 3 Bar MAP // Autotechs // DM OCC // Magnaflow CBE // OBX Test Pipe // Custom Shift Cables
Trithemius is offline   Reply With Quote
 Old 03-10-2017, 04:35 AM   #2
Polish_Eagle's Avatar
Posts: 408   (View Stats)
It was mentioned in their release notes: VersaTuner 1.12.0 released : Software Support
The Following User Says Thank You to Polish_Eagle For This Useful Post:
Trithemius (03-10-2017)
 Old 03-10-2017, 07:31 AM   #3
I made this same mistake earlier this week. I've always used boost pressure before, for some reason decided to use manifold pressure instead.
 Old 03-10-2017, 07:45 AM   #4
Trithemius's Avatar
Thank you, I definitely should have noticed that.
Setting The Pressure Threshold on your TPMS RichB MazdaSpeed 3 - How-To's 12 09-18-2012 10:08 PM
Absolute Load vs Mods quad4svtspeed6 MazdaSpeed 3/6 - ECU Computer Tuning 7 05-16-2011 08:22 PM
Amp setting/Line out converter setting? 2k6speed6 MazdaSpeed 3/6 - Car Audio & Electronics 0 07-31-2009 12:10 PM
Absolute beefyness, you can't get any better than this steven88 Custom Performance Engineering (cp-e.com) 10 04-19-2009 08:36 PM
Page generated in 0.24601 seconds with 22 queries
