> VersaTune
Closed Thread
 Old 11-27-2015, 12:19 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Default Important note about VT update
Make sure you back up the settings as recommended; for some reason, it's not keeping tune customizer settings (megaspool, DTC disable, etc) settings for me between restarts of the app.
Pending some investigation on my end.
Enki is offline
 Old 11-27-2015, 12:36 PM   #2
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Same here! The only setting that was saved after restart was "Vehicle Interface: MongoosePro ISO"
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
SpeedRebirth is offline
 Old 11-27-2015, 12:38 PM   #3
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
So I gambled and went ahead with an update before backing up my data. Everything saved except for the logging device (the connection cord). I choked this up to now having the Bluetooth as an option.
jdmage_mx5 is offline
 Old 11-27-2015, 12:38 PM   #4
Enki's Avatar
@Steve@VersaTune;
Looks like the local settings (Megaspool, FFS, DTCs) get trashed upon close of app UNLESS you restore them from backup...which wipes any maps you imported since.
WORKAROUND:
1. Take a screenshot of your settings from the settings tab (either before or after install, but if doing after install don't close the app)
2. Install and load your new map or just load your new map if already installed.
3. Go to settings screen, manually restore settings.
4. Flash the new map.
This should get most people where they need to be.
Once you import a new map, it wipes your settings again. Hopefully, that's enough to go off of.
Enki is offline
 Old 11-27-2015, 02:10 PM   #5
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
This bug has been reproduced and fixed. A hotfix will be rolled out tomorrow.
We are sorry about the inconvenience.
Ugnius@VersaTune is offline
The Following 9 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
BLKSTIG (11-28-2015), Code Monkey (11-28-2015), Easter Bunny (11-28-2015), Enki (11-27-2015), impossible (05-21-2016), Polish_Eagle (11-27-2015), RE-ACTIONENGSPEED3 (11-28-2015), SpeedRebirth (11-27-2015), Speed_j23 (11-27-2015)
 Old 11-28-2015, 03:31 PM   #6
The 1.10.1 hotfix has just been released. Check your emails for the download link.
The Following 7 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
Code Monkey (11-28-2015), Easter Bunny (11-28-2015), Enki (11-28-2015), impossible (05-21-2016), jdmage_mx5 (11-28-2015), phate (11-28-2015), Speed_j23 (11-28-2015)
Closed Thread
this why it's important... to have child :) mrdouble99 Mazdaspeed3/6 General Discussion 19 07-10-2013 02:55 PM
Important Information for all ... ricknm Gen2 MS3 General Discussion 13 02-23-2013 10:54 PM
Page generated in 0.27308 seconds with 23 queries
