> VersaTune
 Old 05-28-2016, 11:57 AM   #1
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Default lambda to afr
maybe I'm missing something, but how do you switch from lambda values to afr values?
2013 CWP and Stock
 Old 05-28-2016, 10:25 PM   #2
Polish_Eagle's Avatar
Posts: 408   (View Stats)
In the app... I don't think you can.
However, mathematically you can do Lambda x 14.7 and that will give you the AFR for that lambda. If you want to go AFR to Lambda then do AFR / 14.7 and you'll have your lambda value.
 Old 05-29-2016, 12:50 AM   #3
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Unfortunately with Versatuner this is not possible when editing a tune. You only have different options when choosing the PIDs under the Dashboard tab for logging.
If it's that much of a problem then copy/paste to an excel/openoffice/whatever, multiply everything by 14.7, edit it, divide by 14.7 when you finish, paste back into Versa.
You don't need to do this very often but over time I came to "learn" some values so that I don't have to divide/multiply by 14.7 every time.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Boost_creep (05-29-2016)
 Old 05-30-2016, 12:46 AM   #4
NCspecV81's Avatar
That's exactly what i done. I just done the entire table in AFR and divided the table by 14.7. Pretty simple to do. I was just hoping there was an easy toggle. I'm not exactly the best at spotting small options.
2013 CWP and Stock
 Old 05-29-2016, 12:43 PM   #5
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
There's literally hundreds of pages about this online.
 Old 05-30-2016, 05:45 AM   #6
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
That feature is highly requested and will be incorporated in one of the future releases. Sorry about the inconvenience.
Ugnius
Lead Developer
Ugnius@VersaTune is offline   Reply With Quote
The Following 6 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
Boost_creep (05-30-2016), DingoDave (09-27-2016), Enki (05-30-2016), Mazdazilla6 (05-31-2016), mituc (05-30-2016), NCspecV81 (05-30-2016)
 Old 05-30-2016, 08:22 AM   #7
mituc's Avatar
Groans: 111
Incoming WIN!
The E85 guys will have to be more careful when working in AFR numbers instead of lambda, but usually at this level people know what they do.
 Old 05-30-2016, 12:06 PM   #8
Enki's Avatar
Shouldn't be much of a change over AFR, since it will still be a direct translation from Lambda. Changing the scalars will change the injection amount so you don't have to fuck with AFRs much.
ATR Fuel Tables??? (AFR / Lambda?) GlennMPS MazdaSpeed 3/6 - ECU Computer Tuning 5 08-05-2013 10:37 AM
Downpipe lambda sensor joey MazdaSpeed 3/6 - ECU Computer Tuning 12 11-17-2011 01:24 PM
Fucking lambda. ARES28 MazdaSpeed 3/6 - ECU Computer Tuning 2 09-04-2011 06:46 PM
MotorTrend: Next Escalade to go Lambda Haltech Automotive News 0 09-08-2008 11:10 AM
Page generated in 0.28309 seconds with 26 queries
