> VersaTune
 Old 05-29-2016, 12:50 AM   #1
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
maybe I'm missing something, but how do you switch from lambda values to afr values?
Unfortunately with Versatuner this is not possible when editing a tune. You only have different options when choosing the PIDs under the Dashboard tab for logging.
If it's that much of a problem then copy/paste to an excel/openoffice/whatever, multiply everything by 14.7, edit it, divide by 14.7 when you finish, paste back into Versa.
You don't need to do this very often but over time I came to "learn" some values so that I don't have to divide/multiply by 14.7 every time.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Boost_creep (05-29-2016)
 Old 05-30-2016, 12:46 AM   #2
NCspecV81's Avatar
Posts: 2,867   (View Stats)
That's exactly what i done. I just done the entire table in AFR and divided the table by 14.7. Pretty simple to do. I was just hoping there was an easy toggle. I'm not exactly the best at spotting small options.
2013 CWP and Stock
ATR Fuel Tables??? (AFR / Lambda?) GlennMPS MazdaSpeed 3/6 - ECU Computer Tuning 5 08-05-2013 10:37 AM
Downpipe lambda sensor joey MazdaSpeed 3/6 - ECU Computer Tuning 12 11-17-2011 01:24 PM
Fucking lambda. ARES28 MazdaSpeed 3/6 - ECU Computer Tuning 2 09-04-2011 06:46 PM
MotorTrend: Next Escalade to go Lambda Haltech Automotive News 0 09-08-2008 11:10 AM
Page generated in 0.23837 seconds with 23 queries
