| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Looking at the first log, you are seeing fuel cut well before you hit 6600. Are you sure your LC limiter was set at 6600? It looks like 6100 in the logs. Some things to try: enable smooth shift set NLS retard at some extreme value like -30* so it's obvious if you're hitting this. raise LC km/h threshold - it's possible that you're exceeding LC speed threshold before the clutch pedal switch is triggered. You are going from 0 to 12 km/h between the two clutch pedal samples showing disengaged and engaged. I may need to rewrite the LC/NLS speed check to accommodate hard launching cars. |
| The Following 11 Users Say Thank You to Steve@VersaTune For This Useful Post: | Code Monkey (07-13-2015), Dano (11-10-2015), Easter Bunny (07-13-2015), Enki (07-13-2015), Justin@Freektune (07-14-2015), Micha (08-10-2015), phate (07-13-2015), RE-ACTIONENGSPEED3 (07-14-2015), Realgib3 (07-14-2015), TiGraySpeed6 (07-13-2015), xfeejayx (04-27-2017) |
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Realgib3 (11-09-2015) |
Great track prep, tire heat/pressure, driver control = too much speed = bog. so so track prep, tire heat/pressure, driver control = not enough speed = no bog.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following 2 Users Say Thank You to Dano For This Useful Post: | phate (11-10-2015), RE-ACTIONENGSPEED3 (11-10-2015) |
| KR at WOT issue | 6262ms3 | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 04-06-2013 08:18 AM |
| DVD Nav Issue | djern | MazdaSpeed 3/6 - Car Audio & Electronics | 5 | 08-18-2012 12:22 AM |
| Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon | Haltech | Automotive News | 3 | 04-17-2010 08:40 PM |
| :: new issue :: | :: Gusto :: | MazdaSpeed 6 - Engine, Transmission & Driveline | 10 | 09-14-2009 10:00 PM |
| CPE PNP Issue | Phantom | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 02-20-2009 03:01 PM |
