MAF cal worksheet Otay So I Just Spent A Couple Hours Examing Recent Logs, Writing Numbers In A Work Book, And Entering Values Into The Versatune Worksheet Step 6 N Versatuner’s Tune Editor, Open The Tune That Was Installed When The Logs Were Recorded. Open Maf Calibration 1 Table. For Each Maf Voltage, Multiply The G/s Value In The Cell By Corresponding Multiplier From The Worksheet. Once You Have Applied The Multipliers To All Cells In The Maf Calibration 1 Table, Select All Cells In The Maf Calibration 1 Table And Copy Them To The Clipboard. Highlight The First Cell Of The Maf Calibration 2 Table And Paste The Modified Cells. Update The Tune Properties Information Such As Version And Description And Save The Modified Tune. any One Care To Translate That Mess Into Into "Old Drunk That Can Use A Sliderule" I Mean I Could Have Done Some Cells By Hand, But I Am Assuming This Worksheet Should Be A Tap Tap, Right Click Tapparoo Paste And I Am Not Feelin It Also, I Assume I Can Get The Lbs/per Hour Changed Somewhere ? Not A Big Deal, My Speedo Is In Furlongs/fortnight, But It Would Be Nice. I Was Hoping To Flash This Today, But..... Guess I'll Go Lace That Nice Wheel Cover. Oh, A Good Value For Methanol In Lambda As Max Rich The Vp Website Is Incorrect Apparently Cuz Their Chemist Quoted Sg =0.807 Stoich= 6.5 And He Had No Guidance For A Power Rich Lamda Value As Opposed To The Msds Which Is .816 And 6.64 |
OK, I did not caps lock that post, I just came in from the car and refreshed the page and watched it pop back capped out |
Drunk already I see :beerchug: |
Maybe you forgot you wrote in ALL CAPS sent from my Pixel XL |
DEM SHADOW NINJA EDITS ON CAPS ROCK THURSDAY |
Quote:
Quote:
I was pretty sure you were effin wit me which is like kicking a kitten. I'm very delicate I think you just found a new avatar. Just make em morph from 1 to 3 like a Hindu thing Quote:
| All times are GMT -7. The time now is 11:29 AM. |
