> VersaTune
 Old 09-30-2016, 03:52 PM   #1
Yea. For the most part. You're pretty much telling the computer when the MAF sensor has a certain amount of air flowing over it, causing it to output X voltage, that tells the computer that there is Y airflow. Assuming the sensor is calibrated properly, if the computer knows how much air is going in, then it knows how much fuel to spray in order to meet the desired AFR.
Load based vs inertia based dynos Cheapspeed FREEKTUNE 2 06-10-2015 07:47 AM
Convert MAP Based Meth Controller to MAF Based BlueStreak MazdaSpeed 3 - How-To's 20 11-27-2011 02:08 PM
right base map for me trioskater
Cobb ATR Support
4 05-08-2010 04:05 PM
Page generated in 0.22076 seconds with 21 queries
