> VersaTune
Like Tree8Likes
  • 7 Post By
  • 1 Post By
 Old 03-07-2016, 08:47 PM   #1
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Originally Posted by Dwightb View Post
Steve;
Thanks for the explanation. You have seen the OEM tables for the Gen1 MS3. I live in CO at ~5100' elevation. My ecu limits the boost to ~11 lbs with a WGDC of ~30%. its apparent that the ECU limits the load based on the BARO reading. Seems pretty conservative. Do they do this for the sake of the turbo or is there something not right with my car?
This is done to prevent overspeeding the turbo. You can adjust the baro load limits in the "Requested Load Limits Baro Specific" table. 5100' should be around 83 - 84 kPa. The stock table limits load quite a bit at that baro pressure, especially at the higher rpms. Don't forget to adjust the overboost protection table too so you don't get fuel cut.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
silvapain (03-08-2016)
VersTune load targeting joey MazdaSpeed 3/6 - ECU Computer Tuning 10 11-17-2011 11:12 PM
Need some advanced technical data about 2.3L DISI Turbo (L3-VDT) prince igor MazdaSpeed 3 - Engine, Transmission & Driveline 4 07-07-2009 09:52 AM
q"s for all big turbo disi cars ms3guy22 MazdaSpeed 3/6 - Turbo Induction 9 02-23-2009 11:26 AM
Page generated in 0.23998 seconds with 21 queries
