> VersaTune
Like Tree31Likes
 Old 12-09-2014, 12:47 PM   #41
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
How high do you currently rev?
In drag strips i stretch the 1st gear at 8000rpm and also rev 4th gear almost 7800rpm ,all the others i shift around 7400rpm...
In road racing i shift near 7400-7500...
Mfinlay04 likes this.
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
The Following 3 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Enki (12-09-2014), Micha (12-10-2014), phate (12-09-2014)
 Old 12-09-2014, 12:57 PM   #42
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Cool. Do you have any logs showing your car near or above 8000 rpm? I ask because tachs are notoriously inaccurate. I'm just curious because Cobb has claimed a hard limit of 7900 RPM that can't (or would be very difficult to) be re-coded. If VT is already allowing 8k+ rpm, there will be a few more interested people.
Similar to you, I rev higher just so I don't have to make a shift. Only 7500 rpm, and not really willing to go much higher with stock valvetrain, haha. Haven't revved above 7k yet with VT.
-06 MS6
-Corn fed 07 MS3 - Sold
Enki (12-09-2014)
 Old 12-09-2014, 01:08 PM   #43
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
I wasn't aware our valvetrain could handle 7500 RPM. I thought the limit for float was around 7200.
 Old 12-09-2014, 01:11 PM   #44
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
There are lots of checks at 8k in the ECU. I have not spent much time investigating what actually happens at 8k since not many have had the aux fuel needed to spin that high till recently.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Micha (01-12-2015), phate (12-09-2014)
 Old 12-09-2014, 01:34 PM   #45
I do not have because it is dificult while make a run at drag to have the laptop log...but with the first chance i will go out and send you a 4th gear -hi rev log ...
2008 speed3
True red.
The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
phate (12-09-2014)
 Old 12-09-2014, 02:27 PM   #46
Enki's Avatar
Well he's clearly hitting a rev limiter. What's it set to?
phate (12-09-2014), RE-ACTIONENGSPEED3 (12-10-2014)
 Old 12-10-2014, 12:18 AM   #47
It is set to 8000rpm
2008 speed3
True red.
Enki (12-10-2014), Micha (12-10-2014), phate (12-10-2014)
 Old 12-17-2014, 10:09 PM   #48
Enki's Avatar
If possible, requesting access to hpfp spill valve duty cycle for logging/testing.
 Old 12-20-2014, 02:40 PM   #49
Enki's Avatar
Export to CSV default filename: replace / with either - or _
phate (12-20-2014)
 Old 12-20-2014, 02:56 PM   #50
Enki's Avatar
Current default export format: XML
/Datalog/Data/PID[@ID = #]/Record
@Time = #
@Value = # /
Alternate export format: XML
/Datalog/Data/Record
@PID = #
@Time = #
@Value = # /
It will be extremely easy to split this data format out into separate PIDs versus having to join all the separate PIDs together in a concise format.
I can do the XSLT work for the requested export format.
 Old 12-22-2014, 08:04 AM   #51
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
@Time = #
@Value = # /
@PID = #
@Time = #
@Value = # /
What's the purpose of having this XML format? What are you going to use it for?
Ugnius@VersaTune is offline   Reply With Quote
 Old 12-22-2014, 08:13 AM   #52
torquemaniac's Avatar
Posts: 733   (View Stats)
Access to the automatic transmission tables for the CX-7...
2011 CX-7 AWD 2.3 turbo
The Following User Says Thank You to torquemaniac For This Useful Post:
Micha (01-12-2015)
 Old 12-22-2014, 09:48 AM   #53
Enki's Avatar
It would be much easier to spit it out as a single dataset using XSLT, and it should also be easier to write for VT, seeing as how each individual PID will be written in the order it arrives.
The way it is now, I'm not sure you could use XSLT to spit out a CSV (just as an example) without probably a large amount of code in the XSLT file, whereas the structure I've outlined above would take about 15 minutes.
If the data is already in a pile, it's easier to break it up than it is to re-consolidate it.
 Old 12-22-2014, 01:40 PM   #54
undecided's Avatar
Posts: 9   (View Stats)
undecided will become famous soon enough
I don't have VT but it would be awesome if you could make it so the ECU doesn't cut power when the brakes are applied the same time as the accelerator on +2011's. It would be nice to be able to trail brake and brake boost without the ECU cutting the power. Not sure if it's possible since it is some safety code in the ECU but you were able to disable the boost limiter and SWAS so I have hope.
undecided is offline   Reply With Quote
 Old 12-22-2014, 02:41 PM   #55
XSLT won't be enough to convert to CSV, because CSV implies that every record (set of values of all PIDs) was taken at a certain fixed point in time. Whereas in reality, PIDs are requested sequentially, one by one. We also request slowly changing PIDs at a lower rate to save bandwidth for fast changing ones. So it's a pool of data streams with different resolutions.
What we do is interpolate values of all PIDs at fixed intervals and spit out CSV.
*.vtlog is a proprietary format for sharing logs between two VersaTuner instances. It would be interesting for me to find out what the potential uses for our raw data would be. Maybe we are missing some features in our log viewer.
Ugnius
Lead Developer
 Old 12-22-2014, 02:49 PM   #56
Enki's Avatar
I'm just a raw data kind of guy; the number of squiggly lines and the side scales are a bit distracting.
Hell, duplicating values in the logs would be fine if the data has not updated yet; pretty sure that's what the AP does.
 Old 12-22-2014, 02:59 PM   #57
Eth Fiend
phate's Avatar
Pivoting, averaging, trending over multiple logs compiled into one view or data set. I have to export to CSV top do these. Viewing logs over time as the x-axis isn't as helpful as viewing things over rpm or maf or load, etc.
-06 MS6
 Old 01-11-2015, 03:39 PM   #58
You should also add a log pid , for injector duty cycle %
2008 speed3
True red.
 Old 01-12-2015, 01:07 AM   #59
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
You can log inj. pulse width and calculate idc very easily.
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 01-12-2015, 05:11 AM   #60
I know that. but when you are in the road and tune sometimes is usefull just to watch it without calculations...
2008 speed3
True red.
The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Micha (01-12-2015), SpeedRebirth (01-12-2015)
 Old 02-14-2015, 08:13 PM   #61
Enki's Avatar
Don't make vt software automatically start full screen. Some of us have bigass monitors and don't need to be blinded when opening it up lol
 Old 02-15-2015, 03:10 PM   #62
Enki's Avatar
Cruise/max timing isn't being obeyed. All my tables are topped out at 40 degrees, yet I regularly see 55+.
 Old 02-27-2015, 04:35 AM   #63
Polish_Eagle's Avatar
Posts: 408   (View Stats)
@Steve@VersaTune; @Ugnius@VersaTune;
I have a question about disabling codes and the ready monitors. If I disable for example the EGR code because I deleted the EGR, is it possible to have VersaTune set the monitor as READY? It would be nice if the monitor could be set to ready, but only once the car finishes the required drive cycle.
 Old 02-27-2015, 10:22 AM   #64
Enki's Avatar
Disabling the code sets them as permanently not ready. There is no way to make them read as ready via tune; it's an emissions legality thing.
 Old 02-27-2015, 10:31 AM   #65
Technically speaking though, flash tuning a vehicle is considered illegal too because you're modifying the factory tune which is approved under emissions. So I don't see why this can't be implemented.. Lol
 Old 02-27-2015, 10:38 AM   #66
Enki's Avatar
Because it can't.
Find me one example of stock ecu tuning solution that can fully set any code as ready and reporting properly.
 Old 02-27-2015, 12:06 PM   #67
Because it can't.
If you search google you can see the Evolution (See here) has a "Force OBD inspection patch". It's possible to do since developers of flash tuners are modifying the ECU software. The problem is legality, but in most places any type of tampering with the emissions systems is illegal and the ECU false under emission control.
So since flash tuning technically is illegal, I don't see why this feature would matter since you've already ventured into the illegal domain.
Ideally you'd have the ECU monitor everything as usual, but when it goes to report a status it just reports READY.
Anyways, I'll just leave it up to the software developers to figure out if they want to do it or not. It definitely would be a nice to have feature.
 Old 02-27-2015, 12:18 PM   #68
Mfinlay04's Avatar
Posts: 827   (View Stats)
@Steve@VersaTune;
Anyway we can make the Tuner Customizer menu scrollable? On me netbook I'm not able to access ther bottom of the menu =/
2006 MS6 Titanium Grey
Tuned with
The Following User Says Thank You to Mfinlay04 For This Useful Post:
Enki (02-27-2015)
 Old 02-27-2015, 12:34 PM   #69
Enki's Avatar
So there's one. Any others? Also, how old is the EVO ECU?
 Old 02-27-2015, 04:21 PM   #70
You told me to find one.. Lol. If I'm not mistaken I think our ECU is similar to that new evolution. The Mazda ECU is Mitsubishi made. Anyways, I'll see what the VT guys think of this idea, if they can make it happen that's awesome, but if not no worries. It was just a thought.
 Old 02-28-2015, 05:58 AM   #71
Originally Posted by Mfinlay04 View Post
@Steve@VersaTune;
I have the same issue and i bought a biger 15.6 inch laptop....
2008 speed3
True red.
 Old 02-28-2015, 06:39 AM   #72
It could be done. There are two reasons it hasn't been done and probably won't.
1 - It would take a lot of custom ECU coding.
2 - It starts getting the attention of the US EPA. I know of at least one diesel tuner company that got hit hard with fines from the EPA for circumventing diesel emission controls.
@Steve@VersaTune;
It's on the list.
Steve
Lead Tuner
Last edited by Steve@VersaTune; 02-28-2015 at 06:39 AM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (02-28-2015), Mfinlay04 (03-01-2015), Polish_Eagle (02-28-2015), RE-ACTIONENGSPEED3 (03-01-2015)
 Old 03-01-2015, 02:15 AM   #73
It's on the list.
So any estimation about when the new version will be released??
2008 speed3
True red.
 Old 03-01-2015, 12:50 PM   #74
Enki's Avatar
Rolling antilag triggers on second honk.
(LOL)
Micha (03-22-2015), RE-ACTIONENGSPEED3 (03-01-2015)
 Old 03-01-2015, 01:01 PM   #75
NCspecV81's Avatar
Posts: 2,867   (View Stats)
I really want to switch from the AP to versatuner. Get those logging rates and the ease of logging in line with the AP and I'll make the switch.
2013 CWP and Stock
Enki (03-01-2015)
 Old 03-05-2015, 07:52 AM   #76
Jarods7920's Avatar
Posts: 1,415   (View Stats)
I really think it would be awesome to have the rolling anit lag.
One question i have. Rumor has it that when you get into high horsepower 600+ load only tuning becomes difficult to manage. Whats say you to that?
 Old 03-05-2015, 07:57 AM   #77
I have never had any trouble load tuning all the way to the IDC limit. I dyno'd around 500AWHP on a mustang dyno. It could be that people are having trouble with tuning with supplemental fueling.
Rolling anti-lag is on the list. We need to find a good way to trigger it. There is not much integration with driver interface buttons and the ECU. Most of that stuff is wired to the other modules.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
RE-ACTIONENGSPEED3 (03-05-2015)
 Old 03-05-2015, 10:19 AM   #78
Enki's Avatar
It would be rather nice if the table headers floated (kind of like split or freeze in Excel). Would make it easier to mod the lower values on the extended tables for sure.
phate (03-05-2015), RE-ACTIONENGSPEED3 (03-06-2015)
 Old 03-05-2015, 10:25 AM   #79
It's on the list.
Steve
Lead Tuner
Mfinlay04 (03-11-2015)
 Old 03-06-2015, 09:06 AM   #80
Jarods7920's Avatar
Yes, that could be an issue. If only there was someway to integrate that via the stock ecu. I think you and i have discussed this before though.
The Official AP v3 Landscape Request Thread hnda etr Cobb Tuning 41 03-18-2014 01:19 PM
atr feature request : dual monitor support someguyondrugs
Cobb ATR Support
7 11-26-2013 02:04 PM
Page generated in 0.69294 seconds with 32 queries
