| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
![]() Join Date: Sep 2013 Location: Tacoma, WA
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 382
| Not Ranked : 0 score Well MoTEC and the ProEFI live both use the cruise control button/stock. But I don't know if that's possible with the MS3.
__________________ 2011 Mazdaspeed 3 [Sold] 2013 Ford F-150 XLT 3.5 Ecoboost |
| The Following User Says Thank You to Putin 2.3T For This Useful Post: | RE-ACTIONENGSPEED3 (12-09-2014) |
| Not Ranked : 0 score If it's going to be increased, might as well go to 10k.
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | SpeedRebirth (12-09-2014) |
| Not Ranked : 0 score I wasn't aware our valvetrain could handle 7500 RPM. I thought the limit for float was around 7200.
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score There are lots of checks at 8k in the ECU. I have not spent much time investigating what actually happens at 8k since not many have had the aux fuel needed to spin that high till recently. |
| Not Ranked : 0 score Well he's clearly hitting a rev limiter. What's it set to?
| The Following 2 Users Say Thank You to Enki For This Useful Post: | phate (12-09-2014), RE-ACTIONENGSPEED3 (12-10-2014) |
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
| Not Ranked : 0 score It is set to 8000rpm
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] |
| Not Ranked : 0 score If possible, requesting access to hpfp spill valve duty cycle for logging/testing.
| Not Ranked : 0 score Export to CSV default filename: replace / with either - or _
| The Following User Says Thank You to Enki For This Useful Post: | phate (12-20-2014) |
| Not Ranked : 0 score Current default export format: XML /Datalog/Data/PID[@ID = #]/Record @Time = # @Value = # / Alternate export format: XML /Datalog/Data/Record @PID = # @Time = # @Value = # / It will be extremely easy to split this data format out into separate PIDs versus having to join all the separate PIDs together in a concise format. I can do the XSLT work for the requested export format.
| Approved MSF Vendor ![]() Join Date: Dec 2011
Rep Power: 189 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
The way it is now, I'm not sure you could use XSLT to spit out a CSV (just as an example) without probably a large amount of code in the XSLT file, whereas the structure I've outlined above would take about 15 minutes. If the data is already in a pile, it's easier to break it up than it is to re-consolidate it.
__________________ | |
What we do is interpolate values of all PIDs at fixed intervals and spit out CSV. *.vtlog is a proprietary format for sharing logs between two VersaTuner instances. It would be interesting for me to find out what the potential uses for our raw data would be. Maybe we are missing some features in our log viewer. | |
| Not Ranked : 0 score Pivoting, averaging, trending over multiple logs compiled into one view or data set. I have to export to CSV top do these. Viewing logs over time as the x-axis isn't as helpful as viewing things over rpm or maf or load, etc.
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score Access to the automatic transmission tables for the CX-7...
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
| The Following User Says Thank You to torquemaniac For This Useful Post: | Micha (01-12-2015) |
![]() Join Date: Dec 2013
Rep Power: 0 ![]() Thanks: 8
| Not Ranked : 0 score I don't have VT but it would be awesome if you could make it so the ECU doesn't cut power when the brakes are applied the same time as the accelerator on +2011's. It would be nice to be able to trail brake and brake boost without the ECU cutting the power. Not sure if it's possible since it is some safety code in the ECU but you were able to disable the boost limiter and SWAS so I have hope. |
| Not Ranked : 0 score I'm just a raw data kind of guy; the number of squiggly lines and the side scales are a bit distracting. Hell, duplicating values in the logs would be fine if the data has not updated yet; pretty sure that's what the AP does.
| Not Ranked : 0 score You should also add a log pid , for injector duty cycle %
![]() Join Date: Feb 2012 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
| Not Ranked : 0 score You can log inj. pulse width and calculate idc very easily.
__________________ Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat |
![]() | | #19 | ![]() |
| Not Ranked : 0 score I know that. but when you are in the road and tune sometimes is usefull just to watch it without calculations...
| The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Micha (01-12-2015), SpeedRebirth (01-12-2015) |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Don't make vt software automatically start full screen. Some of us have bigass monitors and don't need to be blinded when opening it up lol
![]() | | #21 | ![]() |
| Not Ranked : 0 score Cruise/max timing isn't being obeyed. All my tables are topped out at 40 degrees, yet I regularly see 55+.
![]() | | #22 | ![]() |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score @Steve@VersaTune; @Ugnius@VersaTune; I have a question about disabling codes and the ready monitors. If I disable for example the EGR code because I deleted the EGR, is it possible to have VersaTune set the monitor as READY? It would be nice if the monitor could be set to ready, but only once the car finishes the required drive cycle.
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - |
![]() | | #23 | ![]() |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Technically speaking though, flash tuning a vehicle is considered illegal too because you're modifying the factory tune which is approved under emissions. So I don't see why this can't be implemented.. Lol
![]() | | #25 | ![]() |
Find me one example of stock ecu tuning solution that can fully set any code as ready and reporting properly.
![]() | | #26 | ![]() |
So since flash tuning technically is illegal, I don't see why this feature would matter since you've already ventured into the illegal domain. Ideally you'd have the ECU monitor everything as usual, but when it goes to report a status it just reports READY. Anyways, I'll just leave it up to the software developers to figure out if they want to do it or not. It definitely would be a nice to have feature.
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - | |
![]() | | #27 | ![]() |
![]() Join Date: May 2009 Location: Memphis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,249
| Not Ranked : 0 score @Steve@VersaTune; Anyway we can make the Tuner Customizer menu scrollable? On me netbook I'm not able to access ther bottom of the menu =/
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with |
| The Following User Says Thank You to Mfinlay04 For This Useful Post: | Enki (02-27-2015) |
![]() | | #28 | ![]() |
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] | |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Rolling antilag triggers on second honk. (LOL)
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Micha (03-22-2015), RE-ACTIONENGSPEED3 (03-01-2015) |
![]() | | #30 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score I really want to switch from the AP to versatuner. Get those logging rates and the ease of logging in line with the AP and I'll make the switch.
__________________ 2013 CWP and Stock |
| The Following User Says Thank You to NCspecV81 For This Useful Post: | Enki (03-01-2015) |
![]() | | #31 | ![]() |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score I really think it would be awesome to have the rolling anit lag. One question i have. Rumor has it that when you get into high horsepower 600+ load only tuning becomes difficult to manage. Whats say you to that?
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have never had any trouble load tuning all the way to the IDC limit. I dyno'd around 500AWHP on a mustang dyno. It could be that people are having trouble with tuning with supplemental fueling. Rolling anti-lag is on the list. We need to find a good way to trigger it. There is not much integration with driver interface buttons and the ECU. Most of that stuff is wired to the other modules. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | RE-ACTIONENGSPEED3 (03-05-2015) |
![]() | | #33 | ![]() |
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah | |
![]() | | #34 | ![]() |
![]() Join Date: Nov 2015 Location: Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 45
Can we get a update on when this will be coming???
__________________ 06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly ![]() | |
![]() | | #35 | ![]() |
| Not Ranked : 0 score It would be rather nice if the table headers floated (kind of like split or freeze in Excel). Would make it easier to mod the lower values on the extended tables for sure.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | phate (03-05-2015), RE-ACTIONENGSPEED3 (03-06-2015) |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's on the list. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | Mfinlay04 (03-11-2015) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score @Steve@VersaTune; Anyway to add P2096 to the list of CEL that we can disable. I prefer to run @ 1.05 Lambda at cruising load/RPMs and need to be able to disable this code. I know this request would be very personalize but it'd be awesome if you guys could do it. Thanks
![]() | | #38 | ![]() |
![]() | | #39 | ![]() |
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with | |
![]() | | #40 | ![]() |
| Not Ranked : 0 score @Steve@VersaTune; Is there a way to put a battery volt indicator due to the time we flash our car?Also if it easy to put a safety limit(such under 11.9v) so that can not let us flash our cars ....or a warning...
| Display Modes | |
| The Official AP v3 Landscape Request Thread | hnda etr | Cobb Tuning | 41 | 03-18-2014 01:19 PM |
| atr feature request : dual monitor support | someguyondrugs | Cobb ATR Support | 7 | 11-26-2013 02:04 PM |
