> VersaTune
Like Tree31Likes
 Old 03-06-2015, 10:23 AM   #81
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
The ECU is tied in to the cruise control system, I'm sure (these cars are drive by wire, after all). Maybe holding down the cancel button or something is an option.
RE-ACTIONENGSPEED3 (03-07-2015)
 Old 03-11-2015, 01:12 AM   #82
Mfinlay04's Avatar
Posts: 827   (View Stats)
@Steve@VersaTune;
Anyway to add P2096 to the list of CEL that we can disable.
I prefer to run @ 1.05 Lambda at cruising load/RPMs and need to be able to disable this code. I know this request would be very personalize but it'd be awesome if you guys could do it.
Thanks
2006 MS6 Titanium Grey
Tuned with
 Old 03-11-2015, 01:31 AM   #83
Enki's Avatar
I think you can just disable the codes for the secondary O2 and that should do it.
 Old 03-11-2015, 05:33 AM   #84
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Originally Posted by Mfinlay04 View Post
@Steve@VersaTune;
Thanks
From the main screen, go to settings, Edit Tune Customizer Profile, then in the Tune Customizer window, go to the Disabling DTCs tab, then hit the Advanced button. All available DTCs on the vehicle should be listed there. If P2096 is not on the list there, and the ECU is throwing that code, let me know.
Steve
Lead Tuner
 Old 03-11-2015, 05:52 AM   #85
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I think this has been brought up, but any way to increase logging resolution. I know turning more Parameters of helps, but it still seems like the resolution of the AP is higher with similar numbers of parameters logged
Damond Built Speed 6
 Old 03-11-2015, 06:18 AM   #86
High speed logging is definitely on the list.
Mfinlay04 and SpeedRebirth like this.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Mfinlay04 (03-12-2015), SpeedRebirth (03-11-2015)
 Old 03-12-2015, 12:08 AM   #87
Mfinlay04's Avatar
I'm not seeing it. My car is a 2006 mazdaspeed 6 if that matters?!
Tuned with
 Old 03-19-2015, 06:14 AM   #88
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
@Steve@VersaTune;
Is there a way to put a battery volt indicator due to the time we flash our car?Also if it easy to put a safety limit(such under 11.9v) so that can not let us flash our cars ....or a warning...
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
 Old 03-19-2015, 07:13 AM   #89
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
Originally Posted by RE-ACTIONENGSPEED3 View Post
@Steve@VersaTune;
Yes, that's possible and a good idea. We'll add it to the list.
Ugnius
Lead Developer
Ugnius@VersaTune is offline   Reply With Quote
The Following 3 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
Nliiitend1 (03-21-2015), RE-ACTIONENGSPEED3 (03-19-2015), SpeedRebirth (03-19-2015)
 Old 03-23-2015, 05:18 AM   #90
Mfinlay04's Avatar
here is a screenshot of the CEL in VT just for verificication too
Tuned with
 Old 03-23-2015, 05:20 AM   #91
There are some DTCS that are handled differently in the rom. We are working on masking them.
Mfinlay04 likes this.
Steve
Lead Tuner
Mfinlay04 (04-07-2015), SpeedRebirth (03-23-2015)
 Old 03-24-2015, 09:41 AM   #92
Polish_Eagle's Avatar
Posts: 408   (View Stats)
How exactly do the Warmup Enrichment tables work? The reason I ask is because I set the decrement for them to 0 (up to 60 F) so it won't remove enrichment until my car is at 60 degrees fahrenheit (I run lean AFR).
Thing that has me confused is that at idle it works fine and the AFR is richer to where I set it, but as soon as I start driving the AFR targets my values from the closed loop table (no enrichment applied). Is there anything I can do to make it target the closed loop value and then apply the given enrichment at all times until the required temperature is reached?
 Old 03-24-2015, 11:49 AM   #93
That would require custom ECU code to change the logic.
Steve
Lead Tuner
 Old 03-24-2015, 12:32 PM   #94
So are the enrichment tables meant only for idle? I thought this was a global percentage of fuel increase until the decrement removes all the additional fueling.
 Old 03-24-2015, 12:42 PM   #95
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
So, where is the great (announced) benefit of these tables if they only come into play at idle (which is less than 1% of all driving conditions)?!?
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 03-24-2015, 12:49 PM   #96
Enki's Avatar
It makes starting cars on full corn MUCH easier.
Mfinlay04 (04-07-2015), phate (03-24-2015)
 Old 03-24-2015, 12:57 PM   #97
EmPeEs6's Avatar
Pity, since I could need some enrichment during warmup phase for my E-mix, too...
Gesendet von meinem HUAWEI Y300-0100 mit Tapatalk
 Old 03-24-2015, 12:59 PM   #98
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Why?
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 03-24-2015, 12:59 PM   #99
EmPeEs6's Avatar
Since my engine runs noticeably unsmooth during the first few minutes but not directly after startup, when enrichment is max.
 Old 03-24-2015, 01:56 PM   #100
I personally find when running lean cruise my car runs really rough until the engine coolant temperature reaches approximately 55 - 60 degrees Fahrenheit, that's why I was hoping I could apply the warm up enrichment values to my requested AFR until the car is warmed up to the right temp.
 Old 03-24-2015, 02:03 PM   #101
These tables are meant to be used for cranking and afterstart until the chambers get warmed up enough to get good atomization. It's not for long term warm-up running. Once closed loop operation starts, trims are based on O2 sensor feedback.
Steve
Lead Tuner
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (03-24-2015), phate (03-24-2015), Polish_Eagle (03-24-2015), RE-ACTIONENGSPEED3 (03-24-2015)
 Old 03-24-2015, 02:55 PM   #102
Enki's Avatar
^^^ This is what I thought it was for too, not warming up the car faster. Yeah, it's annoying driving the car around when it sputters like that, but it also shouldn't take long to get to a temperature where it starts to run good again.
 Old 03-24-2015, 05:22 PM   #103
Maybe in Arizona it doesn't take too long, but during cold Canadian winters it can be a fare amount of time.. Lol.
Thanks for clearing that up Steve, I guess I'll stop with the madness..
 Old 03-24-2015, 05:30 PM   #104
Enki's Avatar
Maybe leave the heater off for a little while until the car heats up? Should warm up faster that way.
 Old 03-24-2015, 07:34 PM   #105
I use the auto climate control and it does that already
 Old 03-25-2015, 09:35 AM   #106
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Steve i think you and i have discussed before, but what about actual AFR and PSI values as apposed to KPA and lambda?
Also when i was playing with my tune last night, i noticed something about boost based logic in there but wasnt used. Whats the deal with that?
 Old 03-25-2015, 11:38 AM   #107
They have found some tables for boost based tuning and they just have them avaliable(for now it is useless unless they make an option for boost logik tuning)
2008 speed3
True red.
 Old 03-25-2015, 11:53 AM   #108
The ECU has native boost tuning capability. It is disabled by default and load based tuning is used. Some people prefer the simplicity of boost tuning. If you fully understand how load based tuning works, it is very powerful. We exposed the boost tuning tables for reference. They are not used in any way when the ECU is in load based tuning mode.
Steve
Lead Tuner
kgb (03-25-2015), Nliiitend1 (03-26-2015), RE-ACTIONENGSPEED3 (03-25-2015), SpeedRebirth (03-26-2015)
 Old 03-25-2015, 12:05 PM   #109
Enki's Avatar
Personally I prefer load based tuning; it's way more reliable and consistent.
The Following 5 Users Say Thank You to Enki For This Useful Post:
Mfinlay04 (04-07-2015), Nliiitend1 (03-26-2015), RE-ACTIONENGSPEED3 (03-25-2015), SarcasticOne (03-25-2015), SpeedRebirth (03-26-2015)
 Old 03-26-2015, 07:04 AM   #110
Jarods7920's Avatar
I have no issues with load tuning at this time, but i was just curious as to what it was is all. They arent set to any relevant values right now. More just informational.
 Old 04-01-2015, 03:00 PM   #111
@Steve@VersaTune; @Ugnius@VersaTune;
Any estimation about when the Versatuner 2.0 will be released?
p.s. I really need the rolling megaspool & the revlimit above 8000rpm...
2008 speed3
True red.
The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Enki (04-01-2015)
 Old 04-02-2015, 08:08 AM   #112
torquemaniac's Avatar
Posts: 733   (View Stats)
...and I need access to the transmission tables
2011 CX-7 AWD 2.3 turbo
 Old 04-24-2015, 05:22 PM   #113
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Tested my win 8.1 tablet for the first time today. Works good so far.
Encountered a small issue though. When trying to save a log with the preselected filename it fails because of the timestamp includes a : between hour/minutes/seconds. Get a Invalid filename error
Example: 22:55:35
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
Enki (04-24-2015)
 Old 04-24-2015, 07:41 PM   #114
Enki's Avatar
Example: 22:55:35
It also fails because of slashes in the file name. Bit of a pain.
How long until the next update, @Steve@VersaTune;?
 Old 05-03-2015, 08:44 PM   #115
Mfinlay04's Avatar
-Anyway to incorporate a way to see what tune is currently flashed on the car? Or perhaps adding a line on the individual map with a flash date.
More than once I've mad revisions to a map in the middle of the night and then forgot to flash it the next time i went to my car. And then days/weeks go by and then I can't remember which revision is actually on the car. Shit I'm getting too old.
-Also, I've noticed when exporting a datalog to CSV it seems to cut off some of the parameters. I'd have to actually look and count but for example there are 10 slots to live datalog but when exporting them to CSV form it only exports 8/10.
@Steve@VersaTune;
Tuned with
 Old 05-03-2015, 08:53 PM   #116
Enki's Avatar
I've only been monitoring 8 but I'll try 10 tomorrow and see if I can replicate.
 Old 05-03-2015, 10:46 PM   #117
Mfinlay04's Avatar
I don't remember the exact # without doing it myself. But if your going to test it load up as many parameters you can and see if they all export to CSV.
Tuned with
The Following User Says Thank You to Mfinlay04 For This Useful Post:
Enki (05-03-2015)
 Old 05-03-2015, 10:48 PM   #118
Enki's Avatar
I vaguely recall not being able to monitor more than 8...
 Old 05-04-2015, 03:43 AM   #119
Groans: 33
12 is max number of logged/monitored parameters
15 would be much better so we could include coolant temp and a few other usefull parameters
Mazdaspeed6 -06
290 AWHP / K04
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
Enki (05-04-2015), Mfinlay04 (05-08-2015)
 Old 05-04-2015, 10:20 AM   #120
Enki's Avatar
Maybe I went with 8 due to logging frequency. Don't remember
The Official AP v3 Landscape Request Thread hnda etr Cobb Tuning 41 03-18-2014 01:19 PM
atr feature request : dual monitor support someguyondrugs
Cobb ATR Support
7 11-26-2013 02:04 PM
Page generated in 0.69248 seconds with 32 queries
