> VersaTune
Like Tree31Likes
 Old 05-07-2015, 06:04 PM   #121
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Not sure if it's been requested yet - Would it be possible to log the steering angle?
-06 MS6
-Corn fed 07 MS3 - Sold
aviator79 (03-04-2016), Enki (05-07-2015), Micha (08-15-2015)
 Old 05-08-2015, 12:00 AM   #122
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Originally Posted by Mfinlay04 View Post
...I've noticed when exporting a datalog to CSV it seems to cut off some of the parameters. I'd have to actually look and count but for example there are 10 slots to live datalog but when exporting them to CSV form it only exports 8/10.
I took a bunch of short logs today and did not have this issue with 12 parameters.
Mfinlay04 likes this.
Mfinlay04 (05-08-2015)
 Old 05-09-2015, 02:36 AM   #123
Enki's Avatar
Confirmed not an issue for me.
Attached is a significantly longer log; wholly untainted.
 Old 05-12-2015, 02:46 PM   #124
MSMS3's Avatar
Posts: 2,827   (View Stats)
Question: Can anyone help me generate a logcfg.txt file for gen 1 MS3? It is the logging file needed to run Tactrix Open Port 2.0 on-board stand alone SD card data logging.
I am data logging my gen 1 MS3 with a laptop software program called ScanXL Pro with Mazda PIDs. It has very low resolution via USB dongle.
I recently purchased a Tactrix Open Port 2.0 which operates with a J2534 interface and has an internal SD card for stand alone direct data logging that can then be later downloaded as a complete csv file. No conversion needed.
To activate the data logging it has to have a logcfg.txt file loaded on the SD card.
I am ignorant of how to write the script for that file to log our engine parameters.
I did find a file out there on the 'net, where someone developed a log file for a N/A Mazda. It is attached. It is configured to start logging at a certain pedal position reflective of WOT and stop when the pedal is lifted.
The file runs, but most of the data other than time, rpm, LTFT and AFR is either irrelevant or is reported inaccurately from our ECU, or is reported in metric units.
I'm looking for someone who can write a logcfg.txt file that would activate the particular corresponding PIDs for our cars.
Ideally, I'd like to have a logcfg.txt file that would log the parameters that would work with Virtual Dyno.
I don't know if anyone here uses Tactrix Open Port 2.0 for direct SD card logging, but it is very fast and convenient, and seems to be supported by VersaTune.
If anyone can offer assistance, it would be appreciated.
phate (05-12-2015)
 Old 05-12-2015, 03:16 PM   #125
Eth Fiend
phate's Avatar
If available, a complete list of parameter names would be more useful. That looks like a pretty simple config file. Sweet find. Can you post one of the data logs that you took with it?
-06 MS6
 Old 05-12-2015, 03:37 PM   #126
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
I've just started to work with VT on a friend's BT car... Just wondering what will measure when you're running out of fuel, other than the obvious lamda going lean...
It doesn't have IDC like ATR, and I'm not sure how to read the pulse width and fuel flow as a percentage (or something similar) of the fuel system's capacity...
Also, if he sends me a .vlog file, how do I view that as a CSV or similar?
 Old 05-12-2015, 05:44 PM   #127
MSMS3's Avatar
Will do.
phate (05-12-2015)
 Old 05-12-2015, 06:22 PM   #128
MSMS3's Avatar
Here are two files.
The first is the .csv file on the SD card (there are actually 15 of them there). It obviously did not wait to WOT to start logging, nor does it stop logging with a lift in throttle.
The second is an interesting file called logcfg.out . I renamed it logcfg.txt for the limited purpose of being able to upload it to this board and to read it. But it is extension .out on the SD card so as not to overwrite the master file. I don't know what it does.
If you open that in a text file reader you will see a lot of information including that something has set refresh rate at only a max of 8 frames per second, which is what is showing up in the log, even though the dongle is capable of much faster rate.
I don't know what to make of this beyond that the data log is grossly inaccurate except for time and rpm. Everything else appears to be scaled incorrectly for our ECU.
At least it is a peek under the hood, so to speak.
If someone could generate a workable logcfg.txt file for this dongle it would be really neat. Dare I say, it would be something worth purchasing at an affordable price.
phate (05-12-2015)
 Old 05-13-2015, 12:10 AM   #129
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
Hi, you log injector ms and you calculate the IDC %( i have an ecxel ready and i just through the revs and the id ms )...
As for the log you open it in the versatuner(.vlog format ) and then you save it as .csv format
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Juschiln19 (06-20-2016), SarcasticOne (05-13-2015)
 Old 05-13-2015, 02:51 PM   #130
Enki's Avatar
The whole point of his feature request is that this is something that could easily be done in VT, so the end users don't *have* to do math to figure it out.
Logging is the single biggest thing (in my opinion) that the AP has over VT, and anything done to mitigate that makes VT more appealing to the masses.
MSMS3 (05-13-2015), RE-ACTIONENGSPEED3 (05-14-2015), SpeedRebirth (05-13-2015)
 Old 05-13-2015, 03:42 PM   #131
Yeah, found something on the VT forums about doing the maths, but it was late and I just couldn't be bothered... (Yes, I know it's easy enough to do in excel)
Was just hoping for an easy way to tell straight off a VT log...
Pretty much!
There's even a field to reduce load above a certain IDC %, if I can edit that field, why can't I log IDC?
Enki (05-13-2015), torquemaniac (09-14-2015)
 Old 05-13-2015, 06:01 PM   #132
Enki's Avatar
For anyone that doesn't know:
=ROUND(IPW/(1000/(RPM/60))*100;2)
SarcasticOne (05-13-2015), torquemaniac (09-14-2015)
 Old 05-14-2015, 01:42 AM   #133
turns out, 9ms IPW @ 6550rpm = 99.75% IDC... so, almost out of fuel!
that is about 365 g/s of air @ 11.4 AFR :p
 Old 09-14-2015, 06:13 PM   #134
Eth Fiend
phate's Avatar
@Steve@VersaTune;
I left VT logging on my tablet for ~1.5 hours while driving, hoping to see it would capture the entire thing. It only logged about 20 minutes worth of data. Is there some limitation on my end that can be configured to allow it to log for longer periods of time, or is the 20-ish minutes a limitation of VT?
I'd like to be able to log entire sessions for autocross, which can be upwards of 3 hours long. It's just one less thing to worry about between runs.
-06 MS6
 Old 09-14-2015, 06:41 PM   #135
torquemaniac's Avatar
Posts: 733   (View Stats)
@Steve@VersaTune;
I regularly log the 45 minutes commute to the shop with no problem...only time I had problem with this is when the laptop would automaticaly go ''asleep''
2011 CX-7 AWD 2.3 turbo
The Following User Says Thank You to torquemaniac For This Useful Post:
phate (09-14-2015)
 Old 09-14-2015, 07:00 PM   #136
Eth Fiend
phate's Avatar
I wondered about that. The screen timed out and went black for a couple seconds, but it said it was still logging. I'll change the sleep settings and try it again.
-06 MS6
 Old 09-14-2015, 07:56 PM   #137
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I've noticed that if my screen goes to sleep and I wake it back up the logger says it is going. After reviewing some of the logs they don't appear to be complete logs (time wise).
Let me finish by saying I am a VersaTune noob so take what I say with a grain of salt.
 Old 09-15-2015, 12:58 AM   #138
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
The new version of VT will automatically prevent the computer from sleeping while the logger is turned on. Hopefully, that will fix those problems. In the meantime you can try adjusting your power settings to disable the sleep time out.
There are no specific limits on the amount of data that can be logged in one tuning session. The data is logged straight to disk, so it should survive power outages or other unexpected problems. When developing the log viewer we tested to make sure that it works efficiently with 1 hour logs. We will check whether anything needs to be further optimized to handle 3 hour logs efficiently.
Ugnius@VersaTune is offline   Reply With Quote
The Following 6 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
Mfinlay04 (09-20-2015), MS3Shadow (09-15-2015), phate (09-15-2015), RE-ACTIONENGSPEED3 (09-15-2015), SpeedRebirth (09-15-2015), TiGraySpeed6 (09-15-2015)
 Old 09-15-2015, 07:39 AM   #139
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Will the new version of VT also increase logging resolution? Do we have an ETA for the release?
Sent from my SM-N910V using Tapatalk
Damond Built Speed 6
The Following 2 Users Say Thank You to Deldran For This Useful Post:
keridil (10-10-2015), RE-ACTIONENGSPEED3 (09-16-2015)
 Old 10-19-2015, 10:17 AM   #140
Eth Fiend
phate's Avatar
I tried this again a while back and it did the same thing, cutting the logs off ~20 minutes in. Screen never went to sleep or anything. Is there anything I could look at to fix this?
-06 MS6
 Old 10-23-2015, 02:39 PM   #141
I think I could send you a new beta version next week and you would be able to check if it has this issue resolved.
The Following 5 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
phate (10-23-2015), Polish_Eagle (10-25-2015), RE-ACTIONENGSPEED3 (10-31-2015), SpeedRebirth (10-23-2015), TiGraySpeed6 (10-23-2015)
 Old 10-23-2015, 02:46 PM   #142
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Remain impressed by the customer service offered by VT in general, and doubly so compared to C...
340hp / 371tq
 Old 10-31-2015, 01:50 AM   #143
Can i have a the new beta version to test the revlimit above 8000rpm👼👼???😷😷😷
2008 speed3
True red.
The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Enki (10-31-2015)
 Old 11-10-2015, 01:15 AM   #144
Is there any chance to have controll to our dwell time ignition system???
@Steve@VersaTune; @Ugnius@VersaTune;
2008 speed3
True red.
Justin@Freektune (11-11-2015)
 Old 11-11-2015, 01:53 AM   #145
Also is it possible to raise the overboost limiters above 400kpa ??For those who use the 4bar map sensor and want to raise boost above 400kpa. @Steve@VersaTune; @Ugnius@VersaTune;
2008 speed3
True red.
The Following 3 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Enki (11-11-2015), Justin@Freektune (11-11-2015), MS3Shadow (11-12-2015)
 Old 11-16-2015, 08:19 PM   #146
Enki's Avatar
With progress being made on the aftermarket injector front, couldn't hurt to request this early:
Might need some exposure to injector control above and beyond the FSG.
Also a scalar might be helpful to avoid having to do a bunch of math to figure out injector control (right now everything is done through the FSG).
RE-ACTIONENGSPEED3 (11-18-2015)
 Old 11-17-2015, 03:39 AM   #147
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
With progress being made on the aftermarket injector front...
Did I miss anything???
However, access to the fuel scalar parameter would further simplify E85-tuning when using VT...
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 11-17-2015, 09:38 AM   #148
Enki's Avatar
You sure did. Check the E85 section.
EmPeEs6 (11-17-2015)
 Old 11-21-2015, 01:55 PM   #149
We get a lot of requests to raise some table limits for extreme applications, so we decided to add an "expert" mode to the tune editor that will allow you to enter any value in any cell (at your own risk). Some values will still be limited by the data type used in the ROM, e.g. you can only enter 0-255 in byte sized memory locations.
This feature will be released in the new version that's coming out next week.
The Following 12 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
Code Monkey (11-21-2015), Easter Bunny (11-24-2015), Enki (11-21-2015), Jarods7920 (11-23-2015), jdmage_mx5 (11-21-2015), maisonvi (11-21-2015), mazdakaps (11-22-2015), Nliiitend1 (11-23-2015), phate (11-21-2015), Polish_Eagle (11-22-2015), RE-ACTIONENGSPEED3 (11-24-2015), SpeedRebirth (11-21-2015)
 Old 11-21-2015, 02:03 PM   #150
Eth Fiend
phate's Avatar
YYYEEEEEESSSSSSSSSS.
-06 MS6
 Old 11-21-2015, 06:11 PM   #151
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
I love you Ugnius!!! (Much home)
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 11-21-2015, 06:49 PM   #152
Enki's Avatar
I read that, passed out from bloodloss due to painful erection, woke up, read it again, same thing; happened a few times.
Easter Bunny (11-24-2015), SpeedRebirth (11-22-2015)
 Old 11-24-2015, 10:05 AM   #153
Enki's Avatar
Would it be difficult to add a checkbox or something similar to disable open loop trimming for those of us that want to run meth as a safety net that way the car doesn't run lean if it craps out?
EDIT:
Turns out this sort of already exists, so doesn't need to be added to the list:
Closed loop load limit
 Old 12-10-2015, 04:50 AM   #154
EmPeEs6's Avatar
Unfortunately I found a bug in the new version: The intake air temperature parameter seems to be ignored when exporting the log data into a csv file...
 Old 02-03-2016, 07:01 AM   #155
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Is it possible to get a protuner version of the software. I'm willing to pay for it vs having to install each individual customers .exe file
jdmage_mx5 and xfeejayx like this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Enki (02-03-2016), MS3Shadow (02-03-2016), RE-ACTIONENGSPEED3 (02-03-2016), xfeejayx (02-04-2016)
 Old 02-03-2016, 10:41 AM   #156
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
You can edit all maps for a specific vehicle type with only one installation. So basically you need, say, 4 installations only: Mazdaspeed 3 gen1, Mazdaspeed3 gen2, Mazdaspeed6 and CX7.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 02-03-2016, 10:44 AM   #157
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
It is something that we're working on. We have been focused on adding capability to the single user version, but we are working on a pro version.
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (02-03-2016), Justin@Freektune (02-03-2016), phate (02-03-2016)
 Old 02-03-2016, 10:51 AM   #158
Eth Fiend
phate's Avatar
Steve or Ugnius,
For the cold start and warm up tables, are those x-axis values in °F or °C? I'm assuming the y-axis is % enrichment.
Huge thanks for the floating tables window, that is a really awesome feature I've recently discovered. Makes the huge tables easier to manage. Once you've selected the 'floating' feature, how do you revert to the docked mode? The floating window X isn't available to click.
Edit: I'm asking about the temperature units because they don't change when you change the units settings from metric to imperial. Not sure if any other tables do similar.
-06 MS6
aviator79 (02-03-2016), Enki (02-03-2016)
 Old 02-03-2016, 11:32 AM   #159
Steve or Ugnius,
Looks like I forgot to tag them as temperature units. They are *C. I will fix that for the next release so that they use the user selected unit settings.
Steve
Lead Tuner
The Following 5 Users Say Thank You to Steve@VersaTune For This Useful Post:
aviator79 (02-03-2016), Enki (02-03-2016), Justin@Freektune (02-03-2016), phate (02-03-2016), xfeejayx (02-04-2016)
 Old 02-03-2016, 06:43 PM   #160
Groans: 33
Right click the blue part of the floating window and select Dockable, then click and drag it to the left side. A small window apears at the sides of the screen when you drag it to let you know that it's dockable there
Mazdaspeed6 -06
290 AWHP / K04
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
Micha (02-05-2016), phate (02-03-2016)
The Official AP v3 Landscape Request Thread hnda etr Cobb Tuning 41 03-18-2014 01:19 PM
atr feature request : dual monitor support someguyondrugs
Cobb ATR Support
7 11-26-2013 02:04 PM
Page generated in 0.61811 seconds with 35 queries
