| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
![]() | | #161 | ![]() |
| Not Ranked : 0 score
| The Following User Says Thank You to phate For This Useful Post: | Micha (02-05-2016) |
![]() | | #162 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score Planning to make an android app?
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
![]() | | #163 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2011
Rep Power: 189 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| The Following 4 Users Say Thank You to Ugnius@VersaTune For This Useful Post: |
![]() | | #164 | ![]() |
| Not Ranked : 0 score I was just kidding but that would be sweet as I just bought a chrombook for garage computer but then realized I could not use it for car.
![]() | | #165 | ![]() |
| Not Ranked : 0 score I'm so in for an Android app. Gives me an excuse to buy a tablet and run MHD on my 135i too lol. So there is specific fuel gravity scalars already? What about real time graphing (historgrams) for monitoring/logging?
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings Last edited by Mazdazilla6; 03-03-2016 at 07:14 PM. |
![]() | | #166 | ![]() |
| Not Ranked : 0 score Yes, and a built in calculator for it too (it's different from AP).
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | Mazdazilla6 (03-03-2016) |
![]() | | #167 | ![]() |
| Not Ranked : 0 score I was reading around a bit. So if you change the FSG you don't have to change the MAF curve but you do have to change your load targets?
![]() | | #168 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score There is no reason to run anything but accurate maf scaling and load targets with e85 tuning. Modifying the FSG value based on the e85 calculator output compensates for the e85 specific gravity and afr difference. |
| The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post: |
![]() | | #169 | ![]() |
| Not Ranked : 0 score So it's as simple as changing the FSG and then tuning as I normally would?
![]() | | #170 | ![]() |
(Thread Starter) | Not Ranked : 0 score edit Correction: You should change AFR targets a bit to compensate for the different ideal max load AFRs. VersaTuner e85 tuning guide: https://www.versatuner.com/E85TuningGuide.aspx Last edited by Steve@VersaTune; 03-03-2016 at 08:21 PM. |
![]() | | #171 | ![]() |
![]() Join Date: Feb 2015 Location: Waukegan, IL
Rep Power: 74 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
| Not Ranked : 0 score -- Live Tuning/Auto Tune (It would be great to be able to make real time changes on the fly. Instead of flashing the entire tune, you can just flash a spark revision without wiping out STFT and/or LTFT data. Or, is it possible to do a quick flash which will only update the cells of the tune which has been revised, or must the entire tune be reflashed each time?) -- Conditional Statements for Automatic Data-logging (If rpm is above 2500rpm, and load is above 1.025, then datalog the requested parameters until x happens, the load drops below a certain point, or the timer reaches x amount of seconds.) -- It would be nice if you could read and enter values in kpa instead of load, or 14.68 instead of 1 lambda. -- It would be more convenient if you could just select your datalog and then export it to excel instead of having to load it just to click the button. -- It would be great if you could incorporate an Undo button that way if you screw up, you can press the undo button and it'll go back to the last value that you had. It would be different from the restore button which goes back to the default values of the tune. -- It would be awesome if you could reconfigure the datalogging section to have different skins (i.e. gauges, bars, ect) which move around in real time. I apologize if anything that I've suggested would be unrealistic. I spent many years tuning from scratch via MegaSquirt on a forgotten platform without any sort of help from vendors.
__________________ Last edited by flylike2kites; 03-31-2016 at 02:14 PM. |
| The Following 4 Users Say Thank You to flylike2kites For This Useful Post: | aviator79 (04-01-2016), Jarods7920 (03-31-2016), torquemaniac (03-31-2016), Ugnius@VersaTune (04-01-2016) |
![]() | | #172 | ![]() |
| Not Ranked : 0 score I think the only thing unrealistic would be the partial flash; I'm probably wrong on this but I think the ECU uses a hash of some sort when powering up to make sure it isn't corrupt before running, which means any changes would alter the match to the hash and thus make it not viable if that makes sense.
| The Following User Says Thank You to Enki For This Useful Post: | torquemaniac (03-31-2016) |
![]() | | #173 | ![]() |
| Not Ranked : 0 score Makes perfect sense, Enki. I didn't think about the possibility of the ECU having a checksum for error detection. Thank you. Edit: I was originally under the impression that the ECU's RAM could be rewritten and specific data could be copied over from there. Meh, I'll leave it to the pros. Live tuning/Auto-Tune would be a Game Changer for sure.
![]() | | #174 | ![]() |
| Not Ranked : 0 score It already flashes faster than AP.
![]() | | #175 | ![]() |
| Not Ranked : 0 score You know what feature I want to see- A bounty program on AccessPorts... I'd switch over in a heartbeat if the cost was easier to deal with. I'd send you my AP hardware if you gave me a discount for making the transition. Stupid, I know- your customer service and attention to the platform is beyond excellent. Your product is great. The results speak for themselves. For me, and I suspect many others, the only thing preventing making the jump is simply financial...
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | meicalnissyen (10-08-2016) |
![]() | | #176 | ![]() |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // | |
![]() | | #177 | ![]() |
| Not Ranked : 0 score Unless it's encrytped WITH the hash. Then you have to reflash the entire thing anyways.
![]() | | #178 | ![]() |
| Not Ranked : 0 score This is true, but MegaSquirt spoils you. You're going MS3 Pro with your project. 1 minute is forever in comparison to a few milliseconds.
![]() | | #179 | ![]() |
| Not Ranked : 0 score Fair enough. I'm too lazy to go figure out what's actually happening, but you have a point.
![]() | | #180 | ![]() |
| Not Ranked : 0 score My biggest gripe here lately is the data logging text. I'm using an HP stream most of the time but even on my Lenovo Yoga Pro 3 the min and max values are so small and thin it's hard for my old eyes to read. I'd like to see these bold and all of them (even the current data numbers) just a touch bigger or more predominant. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | meicalnissyen (10-08-2016) |
![]() | | #181 | ![]() |
As for live tuning, this is problematic, because the flash memory of the ECU can only be erased in sectors and those sectors are quite big (up to 256 KB, depending on MCU). So you would still have to reflash a significant portion of the ROM. Add the overhead of setting up the communications and putting the ECU into reflash mode and the gains are not that big. Another problem is that Mazda OEM reflash protocols do not allow specifying the memory area to be erased and always erase everything. So implementing something like that would require significant effort from our side and a lot of custom code in the ECU. The way they do it when calibrating the ECU in the test cell - they have special development ECUs with lots of RAM and keep all the table data in RAM. That way it can be altered in near real time. Production ECUs, on the other hand, have very small RAM sizes and you could barely fit more than a couple of tables in the free space there. What concerns measurement units, there is no direct conversion between kPa (manifold pressure) and engine load. Load is calculated as the actual air mass per intake stroke divided by maximum air mass per intake stroke at WOT at 100% volumetric efficiency. Relationship between air mass and pressure depends on many factors. AFRs instead of lambda are possible, we'll probably add that option in the future, but with the possibility to customize your stoich AFR (some people run ethanol blends that have different stoich AFR). | |
| The Following 7 Users Say Thank You to Ugnius@VersaTune For This Useful Post: | Enki (04-01-2016), Mazdazilla6 (04-01-2016), meicalnissyen (10-08-2016), Nliiitend1 (04-07-2016), RE-ACTIONENGSPEED3 (10-17-2016), SpeedRebirth (04-02-2016), torquemaniac (04-01-2016) |
![]() | | #182 | ![]() |
| The Following User Says Thank You to Code Monkey For This Useful Post: | SpeedRebirth (04-02-2016) |
![]() | | #183 | ![]() |
| Not Ranked : 0 score Nope, not unless you can write good enough code to do all the stock functions on the can bus.
| The Following User Says Thank You to Enki For This Useful Post: | Code Monkey (04-04-2016) |
![]() | | #184 | ![]() |
![]() | | #185 | ![]() |
| Not Ranked : 0 score In for GB
![]() | | #186 | ![]() |
| Not Ranked : 0 score Lol, there would be a group buy a month after I paid full price for the software & cable. No worries. It's worth every penny. Very happy that I bought VersaTune over Accessport ATR On a side note, do you guys have recommendation for a lower profile cable for datalogging? I have big feet [Size 12.5], so when I datalog while driving, I hit the cable when I step on the brakes. It's not a big deal, but half an inch would be great!
| The Following User Says Thank You to flylike2kites For This Useful Post: | osubeaver (04-02-2016) |
![]() | | #187 | ![]() |
(Thread Starter) | Not Ranked : 0 score You can get an extension cable on ebay for a few bucks. 90* angle cables too. You can also log with any ELM327 bluetooth just at a lower pid rate. Sent from my SM-G900V using Tapatalk |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | osubeaver (04-02-2016) |
![]() | | #188 | ![]() |
Groans: 33
| Not Ranked : 0 score If you have a 6 you can just move the OBDII port to the right and zip tie it there and run the cable along the center console to the logging device
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi Last edited by SpeedRebirth; 04-03-2016 at 06:47 AM. |
![]() | | #189 | ![]() |
| Not Ranked : 0 score I pulled the bottom part of my dash out and cut a hole in the back where the plug is, ran the USB cable through there and a hole in the gauge cluster shroud with a grommet. I also use a 90 degree USB adapter to keep it all low profile, as the tablet mounts to my dash as well.
![]() | | #190 | ![]() |
| Not Ranked : 0 score Minor issue: For the data log naming convention, can you change it to a 24 hour format that uses a yyyy_mm_dd_hh_min_sec convention? When you export them, the 12-hour format doesn't arrange in chronological order when you shift from 12 o'clock logs to 1 o'clock logs.
| The Following User Says Thank You to phate For This Useful Post: | Enki (04-04-2016) |
![]() | | #191 | ![]() |
| Not Ranked : 0 score I'm almost ready to make the jump, the biggest thing holding me back right now is being too preemptive and missing a GB. Is that still a possibility?
![]() | | #192 | ![]() |
(Thread Starter) | Not Ranked : 0 score GB is always an option. We have a standing GB policy 5-9 buyers = $50 off, 10+ = $100 off. |
| The Following 9 Users Say Thank You to Steve@VersaTune For This Useful Post: | Enki (04-19-2016), Mazdazilla6 (04-19-2016), Micha (04-22-2016), nindoja (04-20-2016), Nliiitend1 (04-22-2016), phate (04-19-2016), SofaKingAwesome (04-20-2016), SpeedRebirth (04-19-2016), TiGraySpeed6 (04-22-2016) |
![]() | | #193 | ![]() |
| Not Ranked : 0 score Well let's get this thing going! Copy and add yourself if interested. 1. Mazdazilla6
| The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post: | Enki (04-19-2016), TiGraySpeed6 (04-22-2016) |
![]() | | #194 | ![]() |
2. nindoja
| The Following User Says Thank You to nindoja For This Useful Post: | Mazdazilla6 (04-20-2016) |
![]() | | #195 | ![]() |
(Thread Starter) | Not Ranked : 0 score Where should this group buy be posted? Is there a GB forum? |
![]() | | #196 | ![]() |
![]() | | #197 | ![]() |
| Not Ranked : 0 score @Steve@VersaTune; I've got 2 vehicles. If I buy 2 licenses and 1 cable, is that 1 count towards GB or 2? Also, I think as a Vendor, you can post GB/GI threads in your own forum. @InkedInspector; @SofaKingAwesome; - what's the rule for vendor-sponsored GBs?
| The Following 3 Users Say Thank You to nindoja For This Useful Post: |
![]() | | #198 | ![]() |
Sent from my SM-G900V using Tapatalk | |
![]() | | #199 | ![]() |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score Group buy rules for Vendors 1) Group buy shall have a start date and end date. 2) A list of members will be shown in the GB thread and updated accordingly by the organizer of the GB. 3) Price of the item WILL be posted in the GB post. 4) Organizer of the Group Buy will be responsible for keeping the members up to date. 5) The post of the GB will contain descriptive information pertaining to the sale of that item. I would suggest that the vendor posts the Group Buy in their section, so as to allow them access to modify thread/posts as needed. Steve, PM me if you have any questions.
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following 2 Users Say Thank You to SofaKingAwesome For This Useful Post: | InkedInspector (04-20-2016), Mazdazilla6 (04-20-2016) |
![]() | | #200 | ![]() |
![]() Join Date: Nov 2010 Location: Breckenridge CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 69
adnoird app sounds nice tho(AP v3 should of been an andoird app imho, instead of a 700 smartphone gimped down into being an ap with a bigger screen, which is still too damn small imho to be more useful than my DH was, and my plx kiwi2 is)
__________________ Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray! Cpe: FMIC, CAI, TIP, HPFP, bone engine mount Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar Turbine Tech: Extra front motor mount, both diff mounts +bushings EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk, AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto. 17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand | |
| The Official AP v3 Landscape Request Thread | hnda etr | Cobb Tuning | 41 | 03-18-2014 01:19 PM |
| atr feature request : dual monitor support | someguyondrugs | Cobb ATR Support | 7 | 11-26-2013 02:04 PM |
