> VersaTune
Like Tree31Likes
 Old 04-21-2016, 02:32 AM   #201
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
If you think the features are the same, you really need to read more; I'm fairly certain there's a thread on this very subject, actually.
Also, the single biggest reason for switching is this very thread. Read through it, and if you still don't get it I'll get my bigass spoon out just for you.
Jarods7920 (04-21-2016), Micha (04-22-2016)
 Old 04-21-2016, 04:32 AM   #202
Juschiln19's Avatar
Posts: 160   (View Stats)
Juschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of light
Talking
Originally Posted by Steve@VersaTune View Post
Rolling anti-lag is on the list. We need to find a good way to trigger it. There is not much integration with driver interface buttons and the ECU. Most of that stuff is wired to the other modules.
Can we get a update on when this will be coming???
06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly
Juschiln19 is offline   Reply With Quote
 Old 04-21-2016, 10:17 AM   #203
Enki's Avatar
You kind of already can if you're very light on the clutch and have FFS and Megaspool enabled.
 Old 04-21-2016, 12:30 PM   #204
flylike2kites's Avatar
Posts: 64   (View Stats)
flylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud of
Sure. I'd be happy to explain.
Keep in mind that I transferred from an 18 year old dead platform with minimal vendors and tuning solutions. If you wanted to make any real power on that dead platform, you had to go full standalone and wire in a harness from scratch. I spent 4 years tuning with MegaSquirt 1 V3 and MegaSquirt 2 V3. In my honest opinion, this is the closest that you can get to a full standalone setup without actually hacking up any of the wires or removing the ECU.
Pro's:
-- VersaTune still supports the MazdaSpeed platform (HUGE BONUS). For those of you whom are following the bigger injectors thread, they're already waiting for the green light that way they can write code for an injector scale. Good luck trying to get COBB to do anything for us.
-- Accessport only logs 6 options at a time. I can easily log 12 at a time in VersaTuner.
-- VersaTune's customer service is top notch. Plus, they're active in our forums and post a lot of valuable information for us to learn from.
-- It flashes in a minute. That's half the amount of time you'll have to wait in comparison to an Accessport. Who knows, maybe they'll release a faster flashing process with their future updates.
-- For those of you whom have swapped your GPS with a physical tablet, you can install VersaTune on it and tune from the tablet via Bluetooth or a hardwired USB cable.
-- The Option to Download Multiple Tunes and then see which data points have been changed in comparison to yours makes life easier. For those of you whom are tuning your own rides, this will help when creating an OTS Base Tune.
-- You can rev to 8K instead of 7K. This means that you can hit 60mph in 2nd gear if you have the airflow/turbo/mods for it, or if you wanna be cool. Those of us with bigger turbos or built engines will benefit from this. 60mph in 2nd gear happens at about 7200rpms with stock tires.
-- You don't have to look at some small little screen to make adjustments. Seriously. There's throwaway phones with better resolution and larger screens than an Accessport.
-- Anti-Lag is pretty awesome. It's like having a 2-Step.
-- It's more convenient overall. Every tuning point has a descriptor, and when datalogging, there are a lot of preset options for you to select. For example, if you want to datalog MAF Values, then you just click a pull down tab and everything you need is there. You can also see an actual 3D Graph of your datapoints so you can adjust the highs and lows.
-- The Accessport will always be limited to its hardware. VersaTuner is software only, which means it can be migrated to computers/laptops with faster processors and it won't ever be obsolete. There's 3 versions of the Accessport. How many of you have bought more than 1 Accessport for basically the same software? VersaTuner updates the software for free. 1 Purchase and you're done. That's it.
-- The migration from Accessport to Versatuner is also pretty easy. There's already a How-To thread about seamlessly migrating your custom tunes over to VersaTuner.
-- VersaTuner is also cheaper. You can have everything for 550, or you can have an Accessport V3 for 650 plus tax. The software itself is only 400, and you guys will be a part of a group buy, so you'll be getting it even cheaper than what I paid for it.
flylike2kites is offline   Reply With Quote
The Following 3 Users Say Thank You to flylike2kites For This Useful Post:
Juschiln19 (04-21-2016), Mazdazilla6 (04-21-2016), Micha (04-22-2016)
 Old 04-21-2016, 01:18 PM   #205
Juschiln19's Avatar
Is that like brake boosting where it kinda works or works sometimes when done just right.... I've only brake boosted a few times... I know I got it right at least 2 out of 5 tries but right after those 5 tries my brakes were making a screaching noise. And i javent had a problem with the brake since buying car in November... so since its clearly bad on the brakes. I was looking into other options for basically rolling anti-lag or brake boosting without going thru brakes lol... so with that in mind i was more interested in the push botton, no fuss rolling anti-lag....
But just so I know what u mean can u explain... I currently don't have VT but am making the decision on VT or AP and everyone keeps saying there's a huge difference but unless I haven't found a specific page that explains the differences then l... I go to both sites and compare, and Come up with the ap data logs at a faster rate, and is more openly accepted by local shops. And this fourm. And VT takes care of shift shutter. VT let's u tune upto 8000rpm or 4.0 bit I'm not looking to do the whole engine rebuild... it's looking like 10k built block(1000hp capable) $6300 and a head job for another 2k and I'd still need a big turbo to set it off right... not including 5th port fueling... yeah over the top for me lol but looking to push this motor to its factory internal limits.. I've read that's around 400whp max then it's tapped out. Correct me if I'm wrong... that's why I'm on this one us because I see new features in the making for VT... I'm leaning towards VT for sure tho... it's the lack of local support for tuning or evan etuning that's gorlt me on the fence now... thanks for ur assistance! :-) and any advice is greatly appreciated! !!!
 Old 04-21-2016, 01:44 PM   #206
What it does is spools up big turbos by retarding the ignition timing and keeping the exhaust valves open that way the air heats up, gets sent out the exhaust, the hot air expands, and spools the turbo up super quickly. Basically, you leave the line at full boost.
Also, turbos like the GTX3071, EFR 7163, Borg Warner S252 Billet BatMoWheel, Precision 6262, ect are still making power past 7 Grand.
Either way, if you're going big turbo, you'll want VersaTuner.
Think of it like buying Fuel Pump Internals. Just do it and never have to worry about it ever again.
Also, Steve and Lex are very capable etuners. They have a lot of experience and they know what they're doing. If you're not for the eTuning option, the learning curve for VersaTuner isn't very high. It's easier to navigate than Accessport.
Once you buy it, you'll wonder why you didn't make the swap sooner.
The Following 2 Users Say Thank You to flylike2kites For This Useful Post:
Juschiln19 (04-21-2016), Micha (04-22-2016)
 Old 04-21-2016, 02:08 PM   #207
Enki's Avatar
Originally Posted by Juschiln19 View Post
Is that like brake boosting...
Nothing like brake boosting. There's a switch attached to the clutch pedal, which activates when depressed. I think it's mostly used for disabling the cruise control and starting the car; activating this switch via pushing the clutch in will activate the FFS settings including ignition retard (for fireballs and spool).
Right now it has to be set for whichever gear and speed you want to do this in, but I think if this switch can be adjusted to activate sooner (while the clutch is still fully engaged) and VT can be adjusted to hold that RPM it will be a winner.
 Old 04-21-2016, 02:19 PM   #208
Juschiln19's Avatar
Oh so there is a few E-tuners for the VT sweet them it's a done deal tmy concern was if I don't get it and started f'ing it up can someone help and get it back on track lol... and so with FFS and megaspool u still can't build boost while moving tho right?? Or did I get lost.... I have a buddy at work just got the challenger the base model.. and when we line up at 40mph - 60mph - 80mph he pulls on me pretty good... but when I brake boosted those few times I stayed with him until I had to shift (5800 rpm) and the he pulls away like before. . Now I k ow he's got like 100 more hp but it peaks my interest that I stayed with him until shift when brake boosted correctly.... so goal to whoop a challengers ass he's stock... anyway that's why the request for Rolling Anti-lag really peaked my interest!!! It seems like ur talking more about launch control from a stop... I like a push botton to build boost while going any speed and let go and ENJOY :-)
So has anyone done this yet? Or is this where it's held up so far?
Thanks again for the helpful info
Last edited by Juschiln19; 04-21-2016 at 02:19 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-21-2016, 03:11 PM   #209
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Just a reminder, this is the Feature Request Thread, not the User guide/User Experience thread...
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Enki (04-21-2016)
 Old 04-21-2016, 04:10 PM   #210
And on that note I believe it's already been mentioned. But I would LOVE some sort of live graphing function similar to HP Tuners' histograms.
 Old 04-21-2016, 05:47 PM   #211
Juschiln19's Avatar
So there was no verdict... is there or is there NOT going to be a rolling anti-lag setup in the near future for vt that is activated by switch for Rolling races? stright forward setup... thanks
 Old 04-21-2016, 06:30 PM   #212
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
It should be possible. It is a lot of work to implement. I want to do it. It all takes time to implement.
High speed logging is ahead of that on the priority list.
Steve
Lead Tuner
Last edited by Steve@VersaTune; 04-21-2016 at 06:30 PM. Reason: MSF Database - Automerged Doublepost
The Following 8 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (04-21-2016), flylike2kites (04-22-2016), Juschiln19 (04-21-2016), Mazdazilla6 (04-22-2016), Micha (04-22-2016), mituc (04-21-2016), MS3Shadow (04-22-2016), SpeedyTurd (09-09-2016)
 Old 04-21-2016, 07:51 PM   #213
Juschiln19's Avatar
Ok thanks I appreciate it
 Old 04-22-2016, 11:57 AM   #214
Enki's Avatar
Feature request:
Ability to copy axis descriptor values (RPM, Load, etc) for pasting into spreadsheets, etc.
Even having to do it separate would be nice, or maybe a button that dumps the entire table with axis descriptors to clipboard or text file would be nice.
Micha (04-22-2016), ms6mil (09-13-2016), Ugnius@VersaTune (04-22-2016)
 Old 05-28-2016, 12:32 AM   #215
Would it be hard to incorporate a gauge screen for monitoring parameters? I don't mind just using the monitor how it is but the numbers are on the small side and I'd rather not get distracted trying to look at the smaller numbers. I was thinking something pretty basic similar to what torque has:
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
meicalnissyen (10-08-2016), Micha (05-30-2016), SpeedRebirth (05-28-2016)
 Old 05-28-2016, 01:35 PM   #216
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I feel the same, the numbers are very thin and small.
The Following 2 Users Say Thank You to jdmage_mx5 For This Useful Post:
Mazdazilla6 (05-28-2016), MS3Shadow (05-28-2016)
 Old 05-30-2016, 12:51 PM   #217
NCspecV81's Avatar
Posts: 2,867   (View Stats)
4 bar monitoring please. I believe @Enki; referred it to 4bar Auto PID.
2013 CWP and Stock
 Old 05-30-2016, 08:00 PM   #218
Polish_Eagle's Avatar
Posts: 408   (View Stats)
Can you not just use the new Boost PID? I could have sworn that PID covers all the various sensors now.
 Old 05-30-2016, 10:37 PM   #219
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Boost Pressure only works up to 22.5 psi. We noticed that when running 29psi lol. Changed to 3.5 bar pid and saw 30+ after additional tuning
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 05-31-2016, 06:47 AM   #220
Yeah stock sensor, but 3 bar or 3.5 bar will net you more than the stock 22.5 PSI
 Old 05-31-2016, 07:46 AM   #221
Groans: 33
Not when logging the "Boost Pressure" parameter.. doesn't matter what MAP sensor you have, it's maxed at 22.5. Probably a bug so lets hope it gets fixed
Mazdaspeed6 -06
290 AWHP / K04
 Old 06-02-2016, 12:56 PM   #222
NCspecV81's Avatar
What's the 4bar pid?
2013 CWP and Stock
 Old 06-20-2016, 02:49 PM   #223
Realgib3's Avatar
Posts: 2,443   (View Stats)
It's not a bug, it's because the ECU uses 1bit value from pressure, meaning maxed at 255 and since it's using kPa for pressure, 255kPa is the max that will be directly output from the ECU.
With that said, you can run an equation directly using the MapV variable the ECU puts out, and using your map sensor scalars, convert to actual boost pressure in Psi.
Enki (06-20-2016)
 Old 06-20-2016, 03:00 PM   #224
Enki's Avatar
It's not a bug, it's because the ECU uses 1 byte value from pressure, meaning maxed at 255 and since it's using kPa for pressure, 255kPa is the max that will be directly output from the ECU.
Fixed for you; 1 bit is either 0 or 1.
Realgib3 and g00s3y like this.
 Old 06-21-2016, 01:23 PM   #225
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
That is correct, MAP PID is 1 byte, so it maxes out at 255 kPa. Boost PID is based on MAP and BARO pressure, so it has the same limitation. We have additional PIDs for aftermarket MAP sensors, they are based on MAP volts and have the scaling constants hardcoded. This is an inconvenience for all those who want to use the boost PID with aftermarket sensors. We have plans to fix that by reading the scalars from the ROM before logging.
Realgib3 likes this.
Ugnius
Lead Developer
Ugnius@VersaTune is offline   Reply With Quote
The Following 5 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
Enki (06-21-2016), Mazdazilla6 (06-21-2016), mituc (06-21-2016), Polish_Eagle (06-21-2016), SpeedRebirth (06-21-2016)
 Old 09-09-2016, 02:59 PM   #226
torquemaniac's Avatar
Posts: 733   (View Stats)
Late to the party and not sure if its been requested, but ignition timing tuning past 2.0 load (extended the load axis to say 3.0)
2011 CX-7 AWD 2.3 turbo
 Old 09-09-2016, 04:00 PM   #227
Groans: 33
Timing is already tuneable to 4.0 and 8k rpm..
Mazdaspeed6 -06
290 AWHP / K04
 Old 09-09-2016, 06:31 PM   #228
WHAAAATTT...must be a MS3/MS6 exclusive again
@Steve@VersaTune; is it possible to extended the load and rpm axis for the ignition timing on the gen2 CX-7 platform (need so for the big turbo tuning)
 Old 09-09-2016, 06:39 PM   #229
Gen1 MS3 and MS6 only. It's on the to do list for Gen2. It's a big project.
Sent from my SM-G935V using Tapatalk
Steve
Lead Tuner
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (09-09-2016), Nliiitend1 (09-14-2016), SpeedRebirth (09-11-2016), torquemaniac (09-09-2016)
 Old 09-13-2016, 07:55 PM   #230
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Logs capturing name/revision of the tune would be helpful.
Also, I reconsidered the auto feature we discussed on Saturday. It would, indeed, be pretty awesome.
-Wetz
QFT
 Old 09-13-2016, 08:07 PM   #231
Already on the list.
xfeejayx likes this.
Steve
Lead Tuner
Mazdazilla6 (09-18-2016), Nliiitend1 (09-14-2016), SpeedRebirth (09-15-2016), xfeejayx (09-13-2016)
 Old 09-18-2016, 09:51 AM   #232
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Is there a feature to turn off the A/C compressor at WOT? Although, now that I think of it, that might be controlled by an entirely separate system.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-18-2016, 11:16 AM   #233
xfeejayx's Avatar
Groans: 78
Your car already does it.
-Wetz
QFT
Nliiitend1 (09-18-2016)
 Old 09-18-2016, 11:24 AM   #234
Thanks again for coming out to the midwest meet Steve! It was great to meet you and get to discuss stuff.
Nliiitend1 likes this.
Enki (09-18-2016), Nliiitend1 (09-18-2016), xfeejayx (09-18-2016)
 Old 09-18-2016, 12:20 PM   #235
It was great to meet so many of you. We definitely value your feedback and use it to improve VersaTuner.
Nliiitend1 and xfeejayx like this.
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
Mazdazilla6 (09-18-2016), Nliiitend1 (09-18-2016), xfeejayx (09-18-2016)
 Old 09-18-2016, 02:17 PM   #236
Fstrnyou's Avatar
Suggestion for FFS, instead of having a single set point for rpm, have the next rpm calculated based on gear ratio change (current gear vs next gear). That way it doesn't matter at what rpm you shift at, the engine will be right where you need it for the next gear. Which should also reduce clutch wear and tear.
Heck, why not do rev matching for downshifting? Under hard braking, ecu blips the throttle for the next gear.
I'm new to VT, so I might be sounding rediculously stupid regarding the capabilities of the software.
Other rides:
History:
 Old 09-18-2016, 03:56 PM   #237
But it already does this.....
 Old 09-18-2016, 04:08 PM   #238
Fstrnyou's Avatar
Thanks. Good to know, but this was answered almost 5 hours ago.
I no longer have an excuse why I barely lost an impromptu "race". Lol.
Other rides:
History:
 Old 09-18-2016, 04:21 PM   #239
This too is on my to-do list. I recently learned a lot about auto blip and rev matching from my work with an RX-8 SCCA team.
cshunter likes this.
Steve
Lead Tuner
The Following 7 Users Say Thank You to Steve@VersaTune For This Useful Post:
desync0 (09-20-2016), Enki (09-18-2016), flylike2kites (09-19-2016), nindoja (09-18-2016), Nliiitend1 (09-19-2016), SpeedRebirth (09-23-2016), xfeejayx (09-18-2016)
 Old 09-18-2016, 06:32 PM   #240
Enki's Avatar
Steve, please stop, I can only get so hard.
desync0 (09-20-2016), Mazdazilla6 (09-19-2016), nindoja (09-18-2016), phate (09-18-2016)
The Official AP v3 Landscape Request Thread hnda etr Cobb Tuning 41 03-18-2014 01:19 PM
atr feature request : dual monitor support someguyondrugs
Cobb ATR Support
7 11-26-2013 02:04 PM
Page generated in 0.60703 seconds with 35 queries
