> VersaTune
  • 1 Post By distortion
 Old 05-21-2016, 01:40 PM   #1
desync0's Avatar
Posts: 51   (View Stats)
desync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to behold
Default Stock HPFP
Just wanted to double check before I flashed the 91 tune that it's ok to run it on a 100% stock genpu?
It'll be a awhile before I get HPFP internals installed.
desync0 is offline   Reply With Quote
 Old 05-21-2016, 02:10 PM   #2
AnubisFSU's Avatar
Posts: 117   (View Stats)
AnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond repute
Before you install any mods please read your welcome pm...
2010 Mazdaspeed3 Tech
JBR Power Path Stage II / Double Adjustable Short Shifter / Solid Shifter Bushings
Cobb Accessport v3 / XLE BPV / Cobb Knob
Damond Motorsports License Plate Tow Mount / EGR Delete
Ultimate Racing Test Pipe
Autotech Fuel Pump Internals
CP-E XFlex Stage2 RMM
Stratified Stage 3 93oct OTS+
AnubisFSU is offline   Reply With Quote
 Old 05-21-2016, 02:46 PM   #3
desync0's Avatar
I have, this isn't my first day here.... There's a reason I haven't touched any intake or exhaust parts yet.
If you'd like to point out the specific thread where it's not recommended to run the "For stock or near stock" tune on a stock pu, be my guest though.
 Old 05-21-2016, 03:05 PM   #4
distortion's Avatar
Posts: 66   (View Stats)
distortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud of
You didn't mention which map specifically so I assume you mean one of the OTS Cobb maps. As longs as the map notes say the map is for an otherwise stock vehicle (intake and stock CDFP) you should be fine. Cobb has a couple of maps that don't require internals in the description.
I'd recommend looking at one of Stratified Tuning's Flash maps though - they can be configured for a stock car and the drivability will be much improved over a Cobb OTS.
2011 Black Mica W/Tech Package
Cobb AP|CP-E HPFP|Corksport SRI/TIP|Corksport TMIC|UR Test Pipe|Corksport Cold Air Box|Corksport Rear Sway Bar|JBR Shifter Bushings|Corksport RMM|Techna Fit Stainless Brake Lines|Ultraguage|Stratified E85
distortion is offline   Reply With Quote
 Old 05-21-2016, 03:08 PM   #5
desync0's Avatar
Cobb doesn't make maps for Versatuner lol
But I will be going with Stratified when I install real mods.
 Old 05-21-2016, 03:10 PM   #6
distortion's Avatar
Lol, wasn't paying attention to the thread location. My bad.
desync0 likes this.
Whats a stock hpfp with stock internals worth? mutiger93gt MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 01-15-2012 08:14 AM
Page generated in 0.27316 seconds with 23 queries
