Mazdaspeed Forums
-   VersaTune (http://www.mazdaspeedforum.org/forum/forum/f573/)
-   -   SWAS issues (http://www.mazdaspeedforum.org/forum/forum/f573/swas-issues-200167/)
phate 03-24-2016 08:50 AM
SWAS issues
1 Attachment(s)
It happens, almost without fail, in big left handed turns where I'm straightening out and going full throttle. The 'Disable Torque Limiter' toggle is checked. I've attached logs, but here's a couple screenshots of the issue.
http://i64.photobucket.com/albums/h1...ps6x7zh05y.jpg
http://i64.photobucket.com/albums/h1...ps9khxy1jn.jpg
I've attached my tune file and 3 logs. The particular ranges I'm looking at in each of the logs:
1_31_57: 142-144s
1_38_58: 712-715
1_55_31: 732-754
@Steve@VersaTune;
@Ugnius@VersaTune;
I don't see anything in the tune that would cause it, so I'm curious what you guys think. Thanks for all your help!
Polish_Eagle 03-24-2016 03:32 PM
I've experienced this too, and I'm pretty sure I've mentioned before as well. Since the SWAS disable doesn't 100% work I still use the SWAS disable switch unfortunately.
Here's the link and also, when I was testing I had semi slick track tires which didn't slip: http://www.mazdaspeedforum.org/forum/foru...-issue-191048/
Oh, I also think you need to push the "DSC Off" button in the car so DSC isn't interfering. Try pushing that button and then taking logs to see if that helps. I know for me it didn't as I had my AFR's dip into the 9's and you can feel SWAS affecting things.
phate 03-24-2016 03:49 PM
DSC is most definitely always off, so not a worry about that. The SWAS sensor in ms6's controls part of the awd system. Unhooking it disables awd, so that's out of the question.
Steve@VersaTune 03-25-2016 05:26 PM
The ECU is definitely pissed off. It fuel cut at 142.626s in 1_31_57. RPMs are up and down. Were you spinning an inside wheel?
edit: same thing in 1_38_58. Sharp rpm rise then fuel cut.
Could also be a lateral G force limit induced torque reduction by the DSC module that the button doesn't mask.
phate 03-25-2016 06:25 PM
We may have occasionally spun an inside tire, but not every time. Sometimes I'll just wait until the wheel is nearly straight to apply more throttle, and it will still cut with throttle application.
We pull over 1g lateral, and it only happens after sustained cornering, not after quick maneuvers. All of my videos from Saturday were corrupt, so I don't have a good example (you can hear the car pop and stutter when it happens). If it is g-force induced, is there any hope of it getting tuned out?
Steve@VersaTune 03-25-2016 06:51 PM
I'm looking at it. I have an idea that I need to do some testing with.
phate 03-25-2016 07:15 PM
Quote:
Awesome, thanks. We autocross every 2 weeks or so during the season, so if you need testing done I can help with whatever you need.
xfeejayx 03-28-2016 06:54 AM
Leave it to phate to find a lateral G force limit.
In for testing if you need/want/would like a second car.
phate 03-28-2016 07:27 AM
http://www.kappit.com/img/pics/201501_2234_geidc_sm.png
phate 03-30-2016 11:05 AM
We're autocrossing on Sunday, again. Steve, if you would like us to try anything or capture anything specific in the data, let us know and we'll do it! I'll have my accelerometer logging this time around, so that data should be available, too.
Steve@VersaTune 03-30-2016 11:20 AM
Working on a new build for you with some new tables.
Steve@VersaTune 04-01-2016 06:17 AM
Sent you a link to a new VT to test. Check your spam folder if you don't see it.
Steve@VersaTune 04-03-2016 10:15 PM
Any improvement?
phate 04-04-2016 07:42 AM
Quote:
Originally Posted by Steve@VersaTune (Post 3041072)
Any improvement?
No, still cutting after long left handers. I'll send (or post) data logs and the tune file for you guys to check out. Long day yesterday, still went fast enough to take the class ;)
phate 04-04-2016 09:22 PM
1 Attachment(s)
Any improvement?
I've attached all of the logs from Sunday. Here's the summary (included in the .rar):
http://i64.photobucket.com/albums/h1...pswimbf0wa.jpg
Essentially, I took anything and everything that might be causing an issue out of the tune. Tune file included, please let me know if I missed any tables that you were thinking of.
You can see and hear in this video around 32s where it happens after the big left hander:
Enki 04-04-2016 09:34 PM
Christ almighty.
KCi 04-05-2016 04:26 AM
Off topic: The video log looks cool. What software / hardware is this?
phate 04-05-2016 07:13 AM
Quote:
Race Render 3 is the video software. It can handle time based data, so data logs are perfect to overlay. In my case, I have a GoPro taking video, VT logs exported to CSV format, and a GCDC 3-axis 2g accelerometer for the G-G plot (smoothed from 128Hz sample rate in this case).
phate 04-05-2016 02:48 PM
1 Attachment(s)
@mazdakaps you might need to download it again ;)
mazdakaps 04-06-2016 12:52 AM
Lol how did this happen? I only download it once. Oh well!!!
MS3Shadow 04-06-2016 09:05 AM
Quote:
If the downloader uses multi-threading to increase downloads, it'll appears as a another download for each connection.
sent from my Nexus 6P
xfeejayx 04-08-2016 01:56 PM
@Steve@VersaTune;
Weather depending, racing this weekend. Anything specific you want to see? Will attempt phate type log, but...slower.
Steve@VersaTune 04-08-2016 02:27 PM
Nothing right now. I am still looking. Thanks for the offer.
phate 04-11-2016 10:24 PM
@xfeejayx, have you gotten any cuts in either of the 6's?
@Steve@VersaTune, I'll be autocrossing again this coming Sunday, do you want me to test any tables or grab different fields in the data logs?
xfeejayx 04-12-2016 04:59 AM
Hadn't been looking. Was going to look specifically for it this past weekend, but got rained out.
Have an ax Saturday, and potentially one Sunday.
Steve@VersaTune 04-13-2016 12:57 AM
A beta is in the works. Should have something to you shortly.
phate 04-19-2016 10:10 AM
May have found the culprit and might owe the VT guys some beers for creating extra work. I popped a P2088 code a few weeks ago, but cleared it because it was pretty random. It came back after the car was cutting especially hard this weekend, so thought I better check it out...
http://i64.photobucket.com/albums/h1...psukoridxs.jpg
http://i64.photobucket.com/albums/h1...ps46dn1zwc.jpg
http://i64.photobucket.com/albums/h1...psvsev1h1o.jpg
I'll repin tonight and see how it goes.
xfeejayx 04-19-2016 11:13 AM
Just checked our logs from the weekend. No RTP reduction below 6k; slaloms, sweepers, whatever. I imagine this will address your issue.
phate 04-20-2016 05:12 PM
I reworked that connector and the car is pulling cleanly now in straight lines. Dragon this weekend, then another autocross the weekend after. I'm going to revert back to the current public release of VT and my old tune to test things out. Hopefully everything is fixed!
phate 05-02-2016 12:24 PM
I won't call yesterday's event conclusive, because there weren't any long left handers. But, the car pulled cleanly every time we asked for it :)
Next event in 2 weeks.
MSP6 05-03-2016 01:49 PM
Shouldn't you be Skyping with Fiat right now?? ;)
c_bye 05-03-2016 01:56 PM
I get this cut-off on sweeping turns on power as well.
I haven't done this, but I've heard you have to completely disable the SWAS sensor which is under the steering column but you need to remove all the shrouding to get to it.
What I've done is on startup hold the DSC button and that will disable both DSC and Traction Control. I've gotten good results this way, but you have to be careful of lift-off oversteer!
xfeejayx 05-03-2016 02:12 PM
You're likely just getting traction/stability control action mid corner when DSC is on. Most people probably don't even know what SWAS cut feels like. It's like turbo lag more than cut.
Don't have to hold button on MS6, just tap it. It does NOT disable SWAS cut.
Disabling that sensor does more than just disable SWAS, I think.
phate 05-03-2016 03:29 PM
Quote:
Done!
Check here. MS6 is a little different.
c_bye 05-03-2016 04:42 PM
Quote:
Originally Posted by phate (Post 3050754)
Done!
Ah I see, disregard what I said before then. I can only speak for the MS3.
Polish_Eagle 05-03-2016 04:54 PM
My 2011 MS3 suffers from powerless mid corner (rich AFR's and little power), once I straighten the wheel out I feel full power. I then disable my SWAS with the switch I wired in and the powerloss no longer happens.
Enki 05-03-2016 05:33 PM
Quote:
From what I remember, holding the button only turns on the lights for testing and doesn't actually fully disable anything. I've had my light come on simply because I hit the button too fast after starting it, no holding needed. Car didn't behave any differently either.
c_bye 05-03-2016 06:00 PM
Quote:
Right, like I said you have to physically unplug it under the dash for it to actually disable.
It was probably just me, but I did notice the back end stepping out a bit more on track than with both DSC off and traction control light on.
phate 05-24-2016 09:49 AM
3 Attachment(s)
No dice on the connector being the culprit. I flashed back to the pre-beta tune and autocrossed yesterday with a HUGE nascar style left handed oval. After straightening out into the next section, the car cut out just like it used to.
I'll work back through to see if I can find a fix. I'll start with the tables that became available in 1.10.11, then move to the tables available in 1.10.13.
Video of the course. Too much wind noise to hear the cut, this time.
xfeejayx 05-25-2016 06:18 AM
http://youtu.be/MuFV8qb6Ohk
I briefly looked at the logs from our last ax, didn't see any cut after the left sweeper. Will go through them in more detail.
Page generated in 0.22238 seconds with 11 queries
