> VersaTune
Like Tree9Likes
  • 3 Post By Steve@VersaTune
  • 1 Post By 06Speed6
  • 1 Post By SpeedRebirth
  • 1 Post By superskaterxes
  • 2 Post By SpeedRebirth
 Old 03-21-2013, 08:59 AM   #1
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Default VersaTuner 1.8.5 Released
VersaTune is pleased to announce the release of VersaTuner 1.8.5.
VersaTuner 1.8.5 includes the following features:
Gen1 Mazdaspeed3, Mazda3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda6 MPS, Mazdaspeed Atenza, CX-7
New tuning tables related to boost control and load targeting, fuel specific gravity, volumetric efficiency, idle rpm and timing, knock retard limit, and gear ratios.
Increased the allowed load values for the CL-OL transition load tables to 4.0.
Gen2 Mazdaspeed3, Mazda3 MPS, Mazdaspeed Axela, CX-7
New tuning tables related to boost control and load targeting, fuel specific gravity, volumetric efficiency, idle rpm and timing, and knock retard limit
These new tables allow better control of boost, scaling of fuel injection to accommodate E-85, better control of idle stability, and control of maximum KR.
Steve
Lead Tuner
The Following 9 Users Say Thank You to Steve@VersaTune For This Useful Post:
06Speed6 (04-04-2013), Code Monkey (11-03-2014), JTMS3 (04-04-2013), KevMS6 (03-24-2013), kish89 (03-23-2013), mituc (03-22-2013), Mizzle (03-24-2013), rfinkle2 (04-04-2013), SpeedRebirth (03-21-2013)
 Old 03-22-2013, 02:02 PM   #2
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
This release is epic. Opens up the possibility of throwing in new transmissions and different fuels without having to mess with the MAF cal.
There wasn't much going on with the Versatuner, but when it did...
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 03-22-2013, 02:32 PM   #3
The extra tables also make it much easier to tune 3 ports @mituc;
mituc (03-22-2013)
 Old 03-22-2013, 02:52 PM   #4
mituc's Avatar
Groans: 111
Yep, I figured, I was waiting for those tables since you first mentioned them.
Now that I replaced my failed thermostat (i was so lucky to figure it out while temps were still near freezing), after this spring blizzard will be over I'll have to come back to you to take another look at my current tune (and the damage I've done to it).
I don't think we can get more power out of this car on pump gas but maybe we can make it more reliable and consistent.
 Old 03-22-2013, 03:00 PM   #5
I also think your car is a great candidate for a Boost Dial. It will improve response and smooth out boost
mituc (03-22-2013)
 Old 03-23-2013, 05:44 AM   #6
kish89's Avatar
Posts: 292   (View Stats)
kish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the world
Am I the only one who wants boost PID so bad?
I mean that shouldn't be to complicated to calculate, manifold absolute pressure - ~14.5PSI or real atmospheric pressure = boost , right?
It would be so much easier to compare logs..
06 MS6, Versatuner, Stratified Tuned
BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter
Autotech HPFP internals, Forge V1 BPV
Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe
Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP
NGK Iridium IX one step colder plugs, CPE SafeSeals & studs
Custom FMIC with 2.5" piping and Treadstone TR8 IC
SnowPerfomance WMI, Stratified Guardian Angel
Eibach pro kit lowering springs
kish89 is offline   Reply With Quote
 Old 03-24-2013, 11:48 AM   #7
mituc's Avatar
Groans: 111
The manifold absolute pressure is the RIGHT thing you want to compare and take as point of reference when working on a tune. Boost will also do since the barometric pressure doesn't vary too much and some consider it a fixed value (14.60-14.7psi/100-101.5kpa).
Boost = MAP-BARO, you can always log them both, export the logs into an excel sheet and calculate the boost. Visually you can always extract 100kpa/14.5psi (rounded values) from the MAP and you have an idea of what boost you're running. When you compare logs you do it in excel anyway, so it's easier to do that there rather than while logging and trying to get as many PID values in one second.
 Old 03-24-2013, 12:00 PM   #8
KevMS6's Avatar
Posts: 316   (View Stats)
Installed the update
Tuned with by
 Old 03-24-2013, 12:16 PM   #9
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
How does this now compare to what's available from competitors?
 Old 03-24-2013, 01:29 PM   #10
mituc's Avatar
Groans: 111
Mizzle: I think this question can be answered by a tuner only, maybe @Lex?
However, I think in therms of control it is closer and closer to the AP (but still pretty far behind), and considering the following:
- rpm range up to 8k rpm;
- load range up to 4.0;
- the possibility to change gear ratios
it allows even more control for extreme applications with rebuilt transmissions and different gear ratios, high RPM engines (I'm not sure if anyone revved up to 8k just yet, I think everybody stopped at 7.5k max), with stupid big turbo's.
However, you can reach load 3 even with a 3076, so the fact that one can control more exactly what happens above 7k rpm and load 2 may be quite useful for some people.
 Old 03-24-2013, 01:46 PM   #11
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
What functions in AP do you see as superior compared to VT? Other than the fact that you dont need a laptop in the car for AP.
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 03-24-2013, 06:16 PM   #12
Mizzle's Avatar
Groans: 324
I'm not quoting other products in a vendor thread.
I just wanna know what it's lacking in comparison to other products or what people need/want so far.
 Old 04-04-2013, 02:50 AM   #13
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I still want rail pressure control and radiator fan control, otherwise I believe it has everything worth having.
2006 Mazdaspeed 6
 Old 04-04-2013, 08:05 AM   #14
Explain what you mean by rail pressure control? There are three fuel pressure target tables in gen 1 and six in gen2.
Steve
Lead Tuner
 Old 04-04-2013, 08:39 AM   #15
I spy their site often and with this latest update, they have just about everything the AP offers now.
I'd really like gen2 support and would give it a whirl.
I can say that their forum is great and Steve seems to be really active there and Lex never hesitates to help out on here if needed, so it is a definite competitor.
Rad fan operation must be a wicked bitch to get control of because neither Cobb nor Versatune has been able to get those tables to work (not cracking on either company, considering I can barely work my climate control using the buttons)..
Lex (04-04-2013)
 Old 04-04-2013, 10:01 AM   #16
Gen2 support was launched in February.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Lex (04-04-2013), rfinkle2 (04-04-2013)
 Old 04-04-2013, 10:03 AM   #17
I can haz versatune in the US?
Lex (04-04-2013)
 Old 04-04-2013, 10:04 AM   #18
Anywhere in the world on any MZR DISI 2.3l turbo vehicle.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
 Old 04-04-2013, 10:20 AM   #19
What file format are logs saved?
Live tracing is available?
 Old 04-04-2013, 10:32 AM   #20
Groans: 33
Examples:
MAF Cal 1.vtlog
MAF Cal 1.csv
WOT4 11-20 1.vtlog
WOT4 11-20 1.csv
You can name them whatever you want. You get a popup dialog window asking you to name your logfile. Coversion to csv files is done with a single push of a button, it also asks you what format the csv file is to be saved as:
"Standard comma separated value file"
"Virtual Dyno compatible CSV"
"MIcrosoft Excel compatible CSV"
Up to 12 values can be viewed live in "Dashboard" at the same time
Mazdaspeed6 -06
290 AWHP / K04
 Old 04-04-2013, 10:53 AM   #21
Logs can be saved in .vtlog xml format for viewing in the built in VersaTuner log viewer or .csv for import into a variety of apps including VirtualDyno.
Live tracing is not available yet.
Here is a shot of the VersaTuner log viewer. It's a little busy when viewed on a laptop (which is what I took the pic from), but on a large desktop display it's really nice.
You can turn the axes on and off and zoom in and out to get up close and personal with the log data.
Steve
Lead Tuner
 Old 04-04-2013, 10:58 AM   #22
Here is a shot of the real time logging screen.
Current values as well as min/max values are shown.
Audio alerts can be triggered per PID based on configurable thresholds. (KR >2.0, BAT > 70C, MAP > 254 kPa, etc.)
Units can be customized per PID for Metric or Imperial.
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
Mizzle (04-04-2013), rfinkle2 (04-04-2013), SpeedRebirth (04-04-2013)
 Old 04-04-2013, 12:17 PM   #23
Speeeeeed
06Speed6's Avatar
I guess I should say full fuel control on the high pressure side and support for aftermarket rail pressure sensors. Sorry I was tired and screwed that post all up. Versatune does have rail pressure control, considering that I beta tested it I should know lol.
2006 Mazdaspeed 6
The Following 2 Users Say Thank You to 06Speed6 For This Useful Post:
rfinkle2 (04-04-2013), superskaterxes (04-04-2013)
 Old 04-04-2013, 01:47 PM   #24
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
this log is meager compared to the ones @cld12pk2go; is used to looking at haha
i have the ONLY upgraded PnP rail pressure sensor available for our platform if anyone is interested in using it. i paid a pretty penny for it and did a ton of testing with cobb before we figured out that a ton of equations needed to be modified to get it to work.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
cld12pk2go (04-04-2013), rfinkle2 (04-04-2013)
 Old 04-04-2013, 02:13 PM   #25
Yes, we have a plug and play pressure sensor that we've tested with too.
The problem with increasing fuel pressure is that flow is proportional to the square root of pressure differential across the orifice. To double stock flow, you need 4x the pressure. The gains of increasing rail pressure from 1800 to 2500 PSI is only 17.8% more flow. The real solution for high rpm power is larger injectors.
Steve
Lead Tuner
 Old 04-04-2013, 04:49 PM   #26
Speeeeeed
06Speed6's Avatar
Ide personally take even +5% more flow, and that is 5% that Cobb gave up on.
Right now we dont even have a way to properly tune bigger injectors. I think Aviator79 has the only set and he is running them as a bolt on. He has Rons old set which I think are rated at +15% flow but the company said +25% is possible.
2006 Mazdaspeed 6
Last edited by 06Speed6; 04-04-2013 at 04:49 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-04-2013, 04:57 PM   #27
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
The Versatune log plot didn't look too bad (way better than Virtual Dyno's plot). I am just very comfy with my Excel templates...
 Old 04-04-2013, 05:08 PM   #28
The pnp sensor is a $92 OEM part. All of the fuel pressure axes need to be rescaled which is difficult to do since the table data is non-linear.
Steve
Lead Tuner
Realgib3 (04-04-2013)
 Old 11-03-2014, 01:42 PM   #29
Groans: 33
V1.9 just got released and i think you AP guys would love this update
Torque Limit Disable - FINALLY!!! You can now disable all torque limiters, including traction control and torque vectoring due to steering angle sensor (SWAS) input. This feature is enabled via a new check box in Tune Customizer.
MegaSpool - A Mazdaspeed/Mazda MPS tuning first. Now even the biggest turbos can be fully spooled at launch. MegaSpool provides configurable timing retard during Launch Control and No-Lift-Shift. This feature is configured in Tune Customizer.
rfinkle2 and Mazdazilla6 like this.
Mazdaspeed6 -06
290 AWHP / K04
The Following 4 Users Say Thank You to SpeedRebirth For This Useful Post:
f15ms6 (11-26-2014), Mazdazilla6 (11-03-2014), rfinkle2 (11-03-2014), Volcom8190 (11-03-2014)
VersaTuner for Gen1 CX-7 released today Steve@VersaTune CX-7 > Turbo Induction & ECU Tuning 48 10-01-2013 02:02 AM
VersaTuner 1.7 Released! Steve@VersaTune MazdaSpeed 3/6 - ECU Computer Tuning 8 05-03-2012 07:20 PM
VersaTuner 1.7 Released! Ugnius@VersaTune VersaTune 0 04-25-2012 11:39 PM
VersaTuner Version 1.6.0 released Steve@VersaTune VersaTune 0 12-16-2011 01:05 PM
VersaTuner for Gen1 MS3 and 3 MPS Released steve12345 MazdaSpeed 3/6 - ECU Computer Tuning 13 10-28-2011 06:23 AM
Page generated in 0.49572 seconds with 30 queries
