| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
9Likes ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score VersaTuner 1.8.5 includes the following features: Gen1 Mazdaspeed3, Mazda3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda6 MPS, Mazdaspeed Atenza, CX-7 New tuning tables related to boost control and load targeting, fuel specific gravity, volumetric efficiency, idle rpm and timing, knock retard limit, and gear ratios. Increased the allowed load values for the CL-OL transition load tables to 4.0. Gen2 Mazdaspeed3, Mazda3 MPS, Mazdaspeed Axela, CX-7 New tuning tables related to boost control and load targeting, fuel specific gravity, volumetric efficiency, idle rpm and timing, and knock retard limit Increased the allowed load values for the CL-OL transition load tables to 4.0. These new tables allow better control of boost, scaling of fuel injection to accommodate E-85, better control of idle stability, and control of maximum KR. |
| The Following 9 Users Say Thank You to Steve@VersaTune For This Useful Post: | 06Speed6 (04-04-2013), Code Monkey (11-03-2014), JTMS3 (04-04-2013), KevMS6 (03-24-2013), kish89 (03-23-2013), mituc (03-22-2013), Mizzle (03-24-2013), rfinkle2 (04-04-2013), SpeedRebirth (03-21-2013) |
Groans: 111
| Not Ranked : 0 score This release is epic. Opens up the possibility of throwing in new transmissions and different fuels without having to mess with the MAF cal. There wasn't much going on with the Versatuner, but when it did...
| Not Ranked : 0 score The extra tables also make it much easier to tune 3 ports @mituc;
| The Following User Says Thank You to Lex For This Useful Post: | mituc (03-22-2013) |
Groans: 111
Now that I replaced my failed thermostat (i was so lucky to figure it out while temps were still near freezing), after this spring blizzard will be over I'll have to come back to you to take another look at my current tune (and the damage I've done to it). I don't think we can get more power out of this car on pump gas but maybe we can make it more reliable and consistent.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() Join Date: Sep 2011 Location: Croatia (Europe)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 265
| Not Ranked : 0 score Am I the only one who wants boost PID so bad? I mean that shouldn't be to complicated to calculate, manifold absolute pressure - ~14.5PSI or real atmospheric pressure = boost , right? It would be so much easier to compare logs..
__________________ 06 MS6, Versatuner, Stratified Tuned BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter Autotech HPFP internals, Forge V1 BPV Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP NGK Iridium IX one step colder plugs, CPE SafeSeals & studs Custom FMIC with 2.5" piping and Treadstone TR8 IC SnowPerfomance WMI, Stratified Guardian Angel Eibach pro kit lowering springs |
Groans: 111
| Not Ranked : 0 score The manifold absolute pressure is the RIGHT thing you want to compare and take as point of reference when working on a tune. Boost will also do since the barometric pressure doesn't vary too much and some consider it a fixed value (14.60-14.7psi/100-101.5kpa). Boost = MAP-BARO, you can always log them both, export the logs into an excel sheet and calculate the boost. Visually you can always extract 100kpa/14.5psi (rounded values) from the MAP and you have an idea of what boost you're running. When you compare logs you do it in excel anyway, so it's easier to do that there rather than while logging and trying to get as many PID values in one second.
![]() Join Date: Sep 2011 Location: SCOTLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
| Not Ranked : 0 score Installed the update
__________________ Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft Tuned with by |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score How does this now compare to what's available from competitors? |
Groans: 111
| Not Ranked : 0 score Mizzle: I think this question can be answered by a tuner only, maybe @Lex? However, I think in therms of control it is closer and closer to the AP (but still pretty far behind), and considering the following: - rpm range up to 8k rpm; - load range up to 4.0; - the possibility to change gear ratios it allows even more control for extreme applications with rebuilt transmissions and different gear ratios, high RPM engines (I'm not sure if anyone revved up to 8k just yet, I think everybody stopped at 7.5k max), with stupid big turbo's. However, you can reach load 3 even with a 3076, so the fact that one can control more exactly what happens above 7k rpm and load 2 may be quite useful for some people.
Groans: 33
| Not Ranked : 0 score What functions in AP do you see as superior compared to VT? Other than the fact that you dont need a laptop in the car for AP.
Groans: 324
| Not Ranked : 0 score I'm not quoting other products in a vendor thread. I just wanna know what it's lacking in comparison to other products or what people need/want so far. |
| Not Ranked : 0 score I still want rail pressure control and radiator fan control, otherwise I believe it has everything worth having.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | rfinkle2 (04-04-2013) |
(Thread Starter) | Not Ranked : 0 score Explain what you mean by rail pressure control? There are three fuel pressure target tables in gen 1 and six in gen2. |
| Not Ranked : 0 score I spy their site often and with this latest update, they have just about everything the AP offers now. I'd really like gen2 support and would give it a whirl. I can say that their forum is great and Steve seems to be really active there and Lex never hesitates to help out on here if needed, so it is a definite competitor. Rad fan operation must be a wicked bitch to get control of because neither Cobb nor Versatune has been able to get those tables to work (not cracking on either company, considering I can barely work my climate control using the buttons).. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Lex (04-04-2013) |
(Thread Starter) | Not Ranked : 0 score Gen2 support was launched in February. |
(Thread Starter) | Not Ranked : 0 score Anywhere in the world on any MZR DISI 2.3l turbo vehicle. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | rfinkle2 (04-04-2013) |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
Groans: 33
| Not Ranked : 0 score Examples: MAF Cal 1.vtlog MAF Cal 1.csv WOT4 11-20 1.vtlog WOT4 11-20 1.csv You can name them whatever you want. You get a popup dialog window asking you to name your logfile. Coversion to csv files is done with a single push of a button, it also asks you what format the csv file is to be saved as: "Standard comma separated value file" "Virtual Dyno compatible CSV" "MIcrosoft Excel compatible CSV" Up to 12 values can be viewed live in "Dashboard" at the same time
| The Following User Says Thank You to SpeedRebirth For This Useful Post: | rfinkle2 (04-04-2013) |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score Logs can be saved in .vtlog xml format for viewing in the built in VersaTuner log viewer or .csv for import into a variety of apps including VirtualDyno. Live tracing is not available yet. Here is a shot of the VersaTuner log viewer. It's a little busy when viewed on a laptop (which is what I took the pic from), but on a large desktop display it's really nice. You can turn the axes on and off and zoom in and out to get up close and personal with the log data. |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here is a shot of the real time logging screen. Current values as well as min/max values are shown. Audio alerts can be triggered per PID based on configurable thresholds. (KR >2.0, BAT > 70C, MAP > 254 kPa, etc.) Units can be customized per PID for Metric or Imperial. Last edited by Steve@VersaTune; 04-04-2013 at 11:17 AM. |
| The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post: |
![]() | | #23 | ![]() |
| Not Ranked : 0 score I guess I should say full fuel control on the high pressure side and support for aftermarket rail pressure sensors. Sorry I was tired and screwed that post all up. Versatune does have rail pressure control, considering that I beta tested it I should know lol.
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | rfinkle2 (04-04-2013), superskaterxes (04-04-2013) |
![]() | | #24 | ![]() |
this log is meager compared to the ones @cld12pk2go; is used to looking at haha i have the ONLY upgraded PnP rail pressure sensor available for our platform if anyone is interested in using it. i paid a pretty penny for it and did a ton of testing with cobb before we figured out that a ton of equations needed to be modified to get it to work.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | cld12pk2go (04-04-2013), rfinkle2 (04-04-2013) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes, we have a plug and play pressure sensor that we've tested with too. The problem with increasing fuel pressure is that flow is proportional to the square root of pressure differential across the orifice. To double stock flow, you need 4x the pressure. The gains of increasing rail pressure from 1800 to 2500 PSI is only 17.8% more flow. The real solution for high rpm power is larger injectors. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Ide personally take even +5% more flow, and that is 5% that Cobb gave up on. Right now we dont even have a way to properly tune bigger injectors. I think Aviator79 has the only set and he is running them as a bolt on. He has Rons old set which I think are rated at +15% flow but the company said +25% is possible.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 04-04-2013 at 04:49 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #27 | ![]() |
The Versatune log plot didn't look too bad (way better than Virtual Dyno's plot). I am just very comfy with my Excel templates...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score The pnp sensor is a $92 OEM part. All of the fuel pressure axes need to be rescaled which is difficult to do since the table data is non-linear. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | Realgib3 (04-04-2013) |
![]() | | #29 | ![]() |
Groans: 33
| Not Ranked : 0 score V1.9 just got released and i think you AP guys would love this update ![]() Torque Limit Disable - FINALLY!!! You can now disable all torque limiters, including traction control and torque vectoring due to steering angle sensor (SWAS) input. This feature is enabled via a new check box in Tune Customizer. MegaSpool - A Mazdaspeed/Mazda MPS tuning first. Now even the biggest turbos can be fully spooled at launch. MegaSpool provides configurable timing retard during Launch Control and No-Lift-Shift. This feature is configured in Tune Customizer.
| The Following 4 Users Say Thank You to SpeedRebirth For This Useful Post: |
| VersaTuner for Gen1 CX-7 released today | Steve@VersaTune | CX-7 > Turbo Induction & ECU Tuning | 48 | 10-01-2013 02:02 AM |
| VersaTuner 1.7 Released! | Steve@VersaTune | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 05-03-2012 07:20 PM |
| VersaTuner 1.7 Released! | Ugnius@VersaTune | VersaTune | 0 | 04-25-2012 11:39 PM |
| VersaTuner Version 1.6.0 released | Steve@VersaTune | VersaTune | 0 | 12-16-2011 01:05 PM |
| VersaTuner for Gen1 MS3 and 3 MPS Released | steve12345 | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 10-28-2011 06:23 AM |
