> VersaTune
Like Tree47Likes
 Old 05-09-2016, 09:24 AM   #41
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Hmmmm
davychronic likes this.
2007 Mazdaspeed3 GT
Mazdazilla6 (05-09-2016)
 Old 05-09-2016, 11:06 AM   #42
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Don't be a bitch.
The Following 5 Users Say Thank You to Enki For This Useful Post:
Juschiln19 (05-09-2016), KiwiFlavor (05-10-2016), Mazdazilla6 (05-09-2016), nindoja (05-09-2016), SofaKingAwesome (05-10-2016)
 Old 05-09-2016, 12:12 PM   #43
Juschiln19's Avatar
Posts: 160   (View Stats)
Juschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of light
SWEET!!! 2 MORE!!!
06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly
Juschiln19 is offline   Reply With Quote
 Old 05-09-2016, 12:52 PM   #44
Hmmmm
 Old 05-09-2016, 01:25 PM   #45
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
If I jump in, will someone smart help answer my dumb/annoying questions about boost control? I can take care of the basics obviously (MAF cal, AFR, timing, etc).
'08 CWP MS3 w/ T3 3071r
Mazdazilla6 (05-09-2016), Thepedigree13 (05-10-2016)
 Old 05-09-2016, 01:40 PM   #46
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
You might want to sit down, because this will be shocking...
Versatune will help answer your questions.
Yes, the guys that make the software.
I know, that doesn't happen with the other guys.
Or you can bug Enki.
-Wetz
QFT
The Following 6 Users Say Thank You to xfeejayx For This Useful Post:
802MS3 (05-09-2016), Code Monkey (05-12-2016), KiwiFlavor (05-10-2016), Mazdazilla6 (05-09-2016), nindoja (05-09-2016), Thepedigree13 (05-10-2016)
 Old 05-09-2016, 02:02 PM   #47
Enki's Avatar
802MS3 (05-09-2016), Code Monkey (05-12-2016), Mazdazilla6 (05-09-2016), MD1032 (05-09-2016), Thepedigree13 (05-10-2016)
 Old 05-09-2016, 04:32 PM   #48
desync0's Avatar
Posts: 51   (View Stats)
desync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to behold
Tax return is in, just waiting until I sign my mortgage renewal, hopefully friday and I'll more then likely jump in.
So if there's people on the fence, once more after me and it's $100 off..... *nudge*nudge*
desync0 is offline   Reply With Quote
The Following 2 Users Say Thank You to desync0 For This Useful Post:
Juschiln19 (05-09-2016), Mazdazilla6 (05-09-2016)
 Old 05-10-2016, 09:33 AM   #49
aackthpt's Avatar
Posts: 1,450   (View Stats)
Michigan state residents will be charged 6% Michigan sales tax.
*shakes fist* Damn you, motor city!
2013 'speed3, silver
Stage Bro
The Following User Says Thank You to aackthpt For This Useful Post:
Mazdazilla6 (05-10-2016)
 Old 05-10-2016, 04:27 PM   #50
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Someone's gotta pay to fix these F'kd up roads. I'm pretty sure all 4 shocks are blown out on my MS3 from hitting pot holes.
desync0 likes this.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Mazdazilla6 (05-10-2016), xfeejayx (05-10-2016)
 Old 05-10-2016, 05:16 PM   #51
Just 1 more to go to get $100 off!
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
 Old 05-10-2016, 08:25 PM   #52
nindoja's Avatar
Posts: 2,395   (View Stats)
Yo @desync0; time to pony up and get this thing rolling.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 05-10-2016, 10:43 PM   #53
desync0's Avatar
Email sent.....
nindoja likes this.
The Following User Says Thank You to desync0 For This Useful Post:
Juschiln19 (05-11-2016)
 Old 05-11-2016, 08:02 AM   #54
aackthpt's Avatar
I'm lucky enough to spend most of my time on roads that I would probably class as the better in the area. Also, mad pothole dodging skills. Actually it was hilarious because last year on the Dragon I was dodging every crack in the road etc... spending more energy on that than going quickly.
Michigan sales tax: Where does the revenue go? And what could an increase mean for road funding? | MLive.com
Looks like most of sales taxes go to schools, but I'm going to assume "General Fund" and "Revenue Sharing" probably mean "Hookers and Blow" where much more goes than to the roads. I'm still surprised about the schools thing though, I fully expected most of it to go to Hookers and Blow.
I'm strongly considering getting in on this as well.
Stage Bro
 Old 05-11-2016, 08:35 AM   #55
We have reached the $100 discount level!
Steve
Lead Tuner
The Following 5 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (05-12-2016), Juschiln19 (05-11-2016), Mazdazilla6 (05-11-2016), SpeedRebirth (05-11-2016), Tomas (05-11-2016)
 Old 05-11-2016, 09:24 AM   #56
nindoja's Avatar
*Frantically refreshing email and PMs*
desync0 likes this.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
 Old 05-11-2016, 05:55 PM   #57
We should have coupon codes out tomorrow. We had to make some changes to the website to handle them.
Sent from my SM-G935V using Tapatalk
nindoja and desync0 like this.
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (05-12-2016), judderod (05-12-2016), Mazdazilla6 (05-11-2016)
 Old 05-12-2016, 11:39 AM   #58
Codes sent!
desync0 likes this.
Steve
Lead Tuner
Enki (05-12-2016), Mazdazilla6 (05-12-2016)
 Old 05-12-2016, 11:47 AM   #59
nindoja's Avatar
Codes sent!
Paid up and now I get to wait for USPS.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
 Old 05-12-2016, 11:50 AM   #60
For all of you who are converting from a boost based tuning solution to VT, please make sure you set your load tables correctly!
Load targeting logic explained
nindoja likes this.
Steve
Lead Tuner
Code Monkey (05-12-2016), Enki (05-12-2016)
 Old 05-12-2016, 03:28 PM   #61
Be sure to check you spam folder for the download link. The download link emails often get flagged as spam or a threat because they have a link to an executable.
Steve
Lead Tuner
 Old 05-12-2016, 04:33 PM   #62
desync0's Avatar
Now the fun game of waiting for a tracking number, and watching my package travel all 500mi to go 20mi. lol
 Old 05-14-2016, 10:04 AM   #63
Barry's Avatar
Posts: 3   (View Stats)
Barry is an unknown quantity at this point
hi i would like to buy 2 versa software please, could you get in contact with me please to arrange the next step and i have also emailed you guys with my information, speak to you soon.
cheers
barry
Barry is offline   Reply With Quote
 Old 05-14-2016, 11:21 AM   #64
Got my cable today. I finished transferring my tune over from atr yesterday. Car started right up for me!
Just one question, I downloaded VT from the email on my computer. I tried to download from the same link on my tablet but when I open it up on my tablet it's still the demo. I thought I got rid of the demo version but maybe I didn't?
desync0 likes this.
 Old 05-14-2016, 11:37 AM   #65
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
You may need to uninstall the demo version before installing the new one. Had to do that when I was swapping between test versions.
-06 MS6
-Corn fed 07 MS3 - Sold
Mazdazilla6 (05-14-2016)
 Old 05-14-2016, 03:31 PM   #66
For those of you that have multiple licenses:
Install License 1
copy C:\Program Files (x86)\VersaTune\VersaTuner 1.x\ to a new location
create a handy desktop link to the new folder location\versatune.frontend.exe
uninstall license 1
Install License 2
Both installs will share the same local tune and log database.
We are working on multi-VIN support.
xfeejayx likes this.
Steve
Lead Tuner
Enki (05-14-2016), MD1032 (05-16-2016), nindoja (05-14-2016), SpeedRebirth (05-15-2016), xfeejayx (05-14-2016)
 Old 05-14-2016, 05:17 PM   #67
xfeejayx's Avatar
Groans: 78
Install License 1
uninstall license 1
Install License 2
You mean I don't have to use different logins anymore?! Yeeesss!
-Wetz
QFT
 Old 05-14-2016, 10:18 PM   #68
nindoja's Avatar
Yup, it works. I did it slightly differently. You can select "options" when installing and select a different install directory. You still need to create a new desktop shortcut, but it works the same way.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
xfeejayx (05-16-2016)
 Old 05-16-2016, 07:52 AM   #69
xfeejayx's Avatar
Groans: 78
Does your way share the same log and tune folder?
I'm going to have to be careful doing this so I don't lose historical logs and tunes along the way.
@Steve@VersaTune; It's possible I will someday try to flash a car with the wrong exe open. Will this cause any issues? I expect it'll say "wrong vin, dumbass" before I flash, verbatim.
-Wetz
QFT
 Old 05-16-2016, 07:59 AM   #70
The local tune and log database is shared between installs for the same local user. It is in C:\Users\yourname\AppData\Roaming\VersaTune\VersaTuner
If you try to flash with the wrong exe, you will get an error stating that the vehicle is incompatible with the current version of VersaTuner.
Steve
Lead Tuner
nindoja (05-16-2016), xfeejayx (05-16-2016)
 Old 05-16-2016, 08:01 AM   #71
judderod's Avatar
Posts: 47   (View Stats)
judderod has a spectacular aura aboutjudderod has a spectacular aura aboutjudderod has a spectacular aura about
Groaned at 8 Times in 5 Posts
To be able to send PMs your post count must be 15 or greater.
Steve - Thanks that's all purchased as of last week. Any idea when I will get the cable or do you have a tracking number?
judderod is offline   Reply With Quote
 Old 05-16-2016, 08:13 AM   #72
PM Sent.
Steve
Lead Tuner
 Old 05-17-2016, 01:44 PM   #73
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Hoping to have money left after bills this Friday otherwise I'm stuck waiting till Black Friday.
On Order:
Coming Soon:
DIY Projects:
 Old 05-17-2016, 06:10 PM   #74
GAMISTAD's Avatar
Posts: 25   (View Stats)
GAMISTAD is on a distinguished road
PM Sent.
I am interested how do I pay the $100. via pay pall. Besides since the number has been met do I still get the discount. My plan is to run e 85 or meth injection
thanks
Games
GAMISTAD is offline   Reply With Quote
 Old 05-17-2016, 07:28 PM   #75
thanks
Games
Send us an email with real name, forum handle, and paypal email address. We will send you an invoice for the deposit. Once we receive payment for the deposit, we will send you the coupon code to purchase VersaTuner or VersaTuner+VersaLink at the group buy discounted price. The coupon code price will reflect the $100 deposit that has already been paid. First post has the details.
Steve
Lead Tuner
Mazdazilla6 (05-17-2016)
 Old 05-20-2016, 07:10 AM   #76
Group Buy ends Sunday. Get in while you can!
Steve
Lead Tuner
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
desync0 (05-20-2016), DingoDave (05-22-2016), Enki (05-20-2016), Mazdazilla6 (05-20-2016)
 Old 05-20-2016, 04:07 PM   #77
If you're on the fence don't hesitate, this is a great deal! I'm absolutely loving VT thus far!
desync0 likes this.
 Old 05-20-2016, 10:59 PM   #78
NCspecV81's Avatar
Posts: 2,867   (View Stats)
I want in but I can't commit/pay until Friday the 27th. Can I still be in this?
2013 CWP and Stock
Enki (05-20-2016)
 Old 05-21-2016, 05:13 AM   #79
If you can do the $100 deposit by Sunday, you don't have to make the final purchase till May 30th.
desync0 likes this.
Steve
Lead Tuner
Enki (05-21-2016), NCspecV81 (05-21-2016)
 Old 05-21-2016, 07:55 AM   #80
broda's Avatar
Posts: 375   (View Stats)
Hopefully I can pick it up and be able to actually sell my AccessPort due to all the nonsense lol
desync0 likes this.
AP vs Versatuner smileyIV MazdaSpeed 3/6 - ECU Computer Tuning 17 06-07-2018 07:36 PM
Versatuner GB aviator79 CX-7 > General Lounge + New Member Welcome 5 03-12-2013 01:10 PM
VersaTuner for CX-7 steve12345 CX-7 > Turbo Induction & ECU Tuning 50 07-07-2012 08:42 AM
Page generated in 0.58967 seconds with 37 queries
