> VersaTune
  • 1 Post By Steve@VersaTune
 Old 12-16-2011, 01:05 PM   #1
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Default VersaTuner Version 1.6.0 released
Hi everybody,
VersaTune is proud to announce the release of VersaTuner version 1.6.0.
It includes the following changes:
  • Automatic recovery flashing! No need to contact our support team if a flash fails due to faulty drivers or loose connections. VersaTuner detects an incomplete flash and recovers automatically.
  • CSV (comma separated values) exporting for logs. Analyze your logs in Microsoft Excel, plot graphs or use them in other software.
  • Special CSV format compatible with Bradford Barnhill's Virtual Dyno app. You can estimate the actual horsepower and torque gains of your tunes and compare them with your friends' numbers.
  • New dashboard/logging parameters: Fuel pressure sensor voltage and Desired fuel rail pressure
  • Corrected table names, axis definitions and descriptions for multiple tables.
  • Extended the allowed value range for multiple tables.
  • Added support for AEM 3.5 bar MAP.
  • Added more speed limiter tables, the speed limiter can now be raised where it's allowed.
  • Possibility to select/deselect all parameters in the log viewer.
  • Numerous bugfixes.
Alpha Wolf likes this.
Steve
Lead Tuner
The Following 10 Users Say Thank You to Steve@VersaTune For This Useful Post:
06Speed6 (12-17-2011), Docnox (01-15-2012), laxplayermjd (12-19-2011), manselainen (12-19-2011), mayer (12-16-2011), ms3blackmica (12-24-2012), Ms3_Miami (12-21-2011), rfinkle2 (12-16-2011), rigor (12-16-2011), SPEED6 KILLAH (12-16-2011)
VersaTuner for CX-7 steve12345 CX-7 > Turbo Induction & ECU Tuning 50 07-07-2012 08:42 AM
New Alternative: VersaTuner Karmat MazdaSpeed 3/6 - ECU Computer Tuning 53 02-03-2012 09:12 AM
VersaTuner for Gen1 MS3 and 3 MPS Released steve12345 MazdaSpeed 3/6 - ECU Computer Tuning 13 10-28-2011 06:23 AM
VersaTuner - My Review - UK Spec Car Dave. MazdaSpeed 3/6 - ECU Computer Tuning 9 06-01-2011 11:07 AM
Page generated in 0.22590 seconds with 20 queries
