> VersaTune
  • 1 Post By
 Old 11-17-2016, 03:09 PM   #1
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I wonder if someone else has any logs with this turbo, I helped a guy in Germany a while ago and found that the boost control with this turbo was very challenging. I got it sorted eventually but I wonder if it was just a particular case due to some wastegate arm preload or other install issue or if they are all the same.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Cobb AP "stock" tune Turbo PSI tc0308 Gen2 MS3 General Discussion 10 03-07-2013 05:09 PM
K&N Intake and Sidewinder SURE turbo inlet pipe require tune for speed 3? jwilson0514 Mazdaspeed3/6 General Discussion 17 12-04-2012 08:29 PM
K&N Typhoon + Turbo Inlet Pipe = safe with no tune? ChicagoMike 2010 MS3 - Engine, Transmission & Driveline 21 08-05-2011 11:50 AM
Turbo upgrade without a custom tune ganque MazdaSpeed 3/6 - Turbo Induction 6 07-30-2010 04:36 PM
Anyone fine tune there shifter and tune out a second gear grind? stevessvt MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-21-2009 12:06 AM
Page generated in 0.23462 seconds with 21 queries
