> HTP (Hi-Tuned Performance)
Like Tree39Likes
 Old 07-12-2012, 04:32 PM   #81
Any recommendations on a decent group 51r battery?
m249saw (07-12-2012)
 Old 07-12-2012, 05:47 PM   #82
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
^This.
Something that will start at -15°F temps.
 Old 07-12-2012, 08:47 PM   #83
HTP
HTP's Avatar
Posts: 210   (View Stats)
^This.
The 51R battery has more than enough cold cranking amps to get you started on the coldest days. This battery was a stock battery in Honda's.
We have also had the most trouble free performance from just your standard batteries available at your local part houses. We have a local battery vendor that sells these units in their own label for a great discount, so check your area for similar specialists. The dry cell batteries also work well but require more attention if the car is going to sit for any period of time. Once their dead they are hard to bring back. Regardless which vendor you go with we have tested all the variations for fitment with our tray and all fit just fine. More pictures and release info tomorrow.
Matt
802MS3 (07-13-2012), m249saw (07-12-2012), rfinkle2 (07-13-2012)
 Old 07-12-2012, 08:49 PM   #84
m249saw's Avatar
Posts: 718   (View Stats)
m249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the world
I already set my alarm
Sent telepathetically to my Razr Maxx
2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck.
m249saw is offline   Reply With Quote
 Old 07-13-2012, 07:00 AM   #85
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
The first one that comes to mind is the Optima yellow top. The 51 series is what we run in the Civics/Integras. It always seemed to hold up. I've never ran one but I've always seen the commercials for the Die Hard battery and it's ability to start in harsh conditions.
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following 2 Users Say Thank You to SFWD 1934 For This Useful Post:
HTP (07-13-2012), rfinkle2 (07-13-2012)
 Old 07-13-2012, 07:12 AM   #86
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
ORDERED!!!
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following User Says Thank You to skeurton For This Useful Post:
HTP (07-13-2012)
 Old 07-13-2012, 07:19 AM   #87
Originally Posted by skeurton View Post
ORDERED!!!
Me too.
HTP (07-13-2012)
 Old 07-13-2012, 09:21 AM   #88
m249saw's Avatar
Once my knuckles stop bleeding from this Cobb FMIC install ill be putting in my order
The Following 2 Users Say Thank You to m249saw For This Useful Post:
deadlandxtreme (07-13-2012), rfinkle2 (07-13-2012)
 Old 07-13-2012, 12:49 PM   #89
HTP
HTP's Avatar
Default Battery Trays are Now Available!
Happy Friday the 13th! Our new battery tray is now available here!
This tray is designed for 51R batteries and comes with a complete hardware kit for the ECU and battery tray.
We've modified our original design to include several extra mounting holes on the side for mounting a boost controller or anything else you may have a need for (not shown in photos).
See the install guide here.
Shown with a standard 51R battery (not included)
Shown with an Optima D51R Yellow Top (not included)
rfinkle2 and magicka like this.
The Following 11 Users Say Thank You to HTP For This Useful Post:
802MS3 (07-18-2012), BPASPEED (07-13-2012), burn813 (07-13-2012), Ckmazdaspeed3 (07-18-2012), Downmented (07-23-2012), Micha (10-07-2012), NoRegrets (07-14-2012), rfinkle2 (07-13-2012), skeurton (07-13-2012), uncorked11 (08-17-2012), xdm88 (07-17-2012)
 Old 07-13-2012, 12:51 PM   #90
BPASPEED's Avatar
Posts: 1,891   (View Stats)
Groans: 60
Pure sex. Nice job HTP!
who cares how i sent it!
 Old 07-15-2012, 07:45 AM   #91
m249saw's Avatar
Ordered yay!
 Old 07-15-2012, 10:44 AM   #92
When you guys get a chance, could you post up your battery choice?
 Old 07-15-2012, 11:55 AM   #93
m249saw's Avatar
Me thinks Im gonna just do an Autozone 51R. Im going to call Interstate Battery tomorrow for a price.
The Following User Says Thank You to m249saw For This Useful Post:
rfinkle2 (07-15-2012)
 Old 07-17-2012, 08:04 PM   #94
After reading as much battery info as I could stand, it seems that anything made by Johnson Controls gets the best consumer ratings.
(also, if searching for group 51r batteries by vehicle, the 2006 acura rsx type s takes this model)
Per Advance Auto Parts q&a, Johnson Controls makes the following battery:
I decided to go with this battery (20% online coupon first link):
Get 20% Off Parts - Advance Auto Parts
51r battery 2nd link:
Buy AutoCraft Gold Battery, Group Size 51R, 500 CCA 51R-2 at Advance Auto Parts
A relevant thread here:
Who makes the best car batteries - Bob Is The Oil Guy
The Following 9 Users Say Thank You to rfinkle2 For This Useful Post:
802MS3 (07-18-2012), Downmented (07-23-2012), Etipp98 (07-17-2012), kgb (07-18-2012), silvapain (07-18-2012), skeurton (07-18-2012), smoogs12 (07-17-2012), warlord (08-11-2012), xdm88 (07-17-2012)
 Old 07-18-2012, 04:35 PM   #95
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Thanks for the link Fink!!
Here is mine installed, Thanks HTP!
The Following 3 Users Say Thank You to Etipp98 For This Useful Post:
08.5MS3 (07-20-2012), 802MS3 (07-18-2012), rfinkle2 (07-18-2012)
 Old 07-18-2012, 08:41 PM   #96
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
^grab a real camera and show us what it actually looks like
jk thanks for the pics
'08 CWP MS3 w/ T3 3071r
 Old 07-18-2012, 08:43 PM   #97
Etipp98's Avatar
Yeah sorry for the cruddy phone pics
 Old 07-18-2012, 10:35 PM   #98
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Mine arrives tomorrow. Probably just going to get a costco battery (Interstate) for $65.
MattJackson86 is offline   Reply With Quote
The Following 2 Users Say Thank You to MattJackson86 For This Useful Post:
BPASPEED (07-18-2012), rfinkle2 (07-19-2012)
 Old 07-18-2012, 10:39 PM   #99
skeurton's Avatar
I checked out the link earlier and it said the battery was $115.99, but now it looks like it's on sale for $99.99. There's also another coupon code you can use until July 28th:
Take 15% off this item when you spend over $100, plus receive a $50 coupon off of a future purchase of $100 or more. Enter code JL28 during checkout. Online only.
2011 MAZDASPEED 3
 Old 07-18-2012, 10:51 PM   #100
bstover17's Avatar
Posts: 586   (View Stats)
Groans: 228
Damn I want this and a jbr intake! Too many mods note enough monies.
2010 MAZDASPEED 3
 Old 07-18-2012, 11:24 PM   #101
BPASPEED's Avatar
Groans: 60
Same here on the shipping, i will probably go with an Optima yellow.
 Old 07-20-2012, 05:05 PM   #102
Any installed pics of this? In the process of mine and the ECU wiring harness is a mess. Removed the wiring support bracket and the wires still dont want to get into place cleanly. Even removed some of the electrical tape and its still messy. Just wondering what others did. If I need to remove more tape and take it all the way back (including removing the white plastic wire protector)???
 Old 07-20-2012, 05:10 PM   #103
BPASPEED's Avatar
Groans: 60
I read here that people have removed the white plastic part and had more slack to move the ECU around. Let me look around to see if i find the post.
Found the thread. Post # 356 http://www.mazdaspeedforum.org/forum/foru...ml#post1497393
The Following 2 Users Say Thank You to BPASPEED For This Useful Post:
m249saw (07-20-2012), MattJackson86 (07-20-2012)
 Old 07-20-2012, 05:27 PM   #104
HTP
HTP's Avatar
Removing the white plastic protector and separating the power and ground battery wires and then re-taping with electrical tape is the cleanest way to do it. You can even put some extra wire loom where the white plastic piece goes to clean the look up even more.
Be sure to mount the tray with all 3 mounting points. Install instructions will be emailed and be available on our website.
The Following 7 Users Say Thank You to HTP For This Useful Post:
08.5MS3 (07-20-2012), BPASPEED (07-20-2012), MattJackson86 (07-20-2012), Micha (02-17-2013), rfinkle2 (07-20-2012), skeurton (07-20-2012), Voltwings (08-20-2012)
 Old 07-20-2012, 06:06 PM   #105
All installed, and honestly its a great kit. Really well made and fitment is perfect. Had no issues with bolt holes not lining up or anything like that. Couple tips to help:
1) Install the tray and then the ECU. There is tons of room, thanks to the slimmer battery , to install and bolt up the ECU after the tray is installed. One of the tray bolts is under the ECU and installing it is only really possible with the ECU not there (learnt that the long way). Also you will see how the white washer should be installed without losing them, as you have to hold one of the washers as you push the bolt through. If you do this out of the car, and then ever remove the ECU, all washers get lost unless you put them in the correct way (as they would fall into the tray).
2) I would definitly do what HTP suggest and remove all the electrical tape, white plastic etc, and then re-tape it up. I have yet to do this (no tape) but I will this weekend. It will just make the fitment of the ECU connector cleaner as they are taped tight.
Are the white plastic washers necessary? If so, I will need some more When I removed the ECU to install 3rd tray bolt, washer fell somewhere.
End result looks great, loads more room, and ECU is sitting nicely. I did this all without instructions in about an hour.
The Following 4 Users Say Thank You to MattJackson86 For This Useful Post:
BPASPEED (07-20-2012), Micha (02-17-2013), rfinkle2 (07-23-2012), skeurton (07-20-2012)
 Old 07-20-2012, 06:12 PM   #106
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Question... The 51r batteries arnt like the small Brails where if you dont start them every day they loose charge are they? Reason I ask is because I only drive my car on the weekends and want to make sure the car starts when I want it to.
TEAM LUXURY
 Old 07-20-2012, 06:18 PM   #107
HTP
HTP's Avatar
A standard replacement 51R will function just like the OEM battery. The 51R battery is an OEM battery for some Hondas.
Matt
Micha (02-17-2013), rfinkle2 (07-20-2012), Sid3wayS (07-20-2012), xdm88 (08-09-2012)
 Old 07-20-2012, 06:36 PM   #108
HTP
HTP's Avatar
Definitely install the tray before the ECU. The white nylon washer and isolator are for those concerned with their ECU being grounded to the tray. We have had no issues with running the ECU without the isolators. We will send you out more nylon washers tomorrow.
Tip:
Snapping the flanged isolator on the outside of the tray is the easiest way to do it. They will stay put unless you have the polished tray in which it will be helpful to spray them with an adhesive or a tiny dab of silicone. Center the flat nylon washer on the inside and stick the allen bolt through and secure the ECU to the tray.
Matt
MattJackson86 (07-21-2012), rfinkle2 (07-25-2012), xdm88 (08-09-2012)
 Old 07-20-2012, 06:39 PM   #109
BPASPEED's Avatar
Groans: 60
Thanks for the info man, ill be installing mine soon.
You can try unplugging the battery when not in use or getting a battery tender for it.
The Following 3 Users Say Thank You to BPASPEED For This Useful Post:
Micha (02-17-2013), rfinkle2 (07-25-2012), Sid3wayS (07-20-2012)
 Old 07-25-2012, 10:48 AM   #110
m249saw's Avatar
Just picked up an Optima yellow top to install in it.
Directions from HTP look pretty straight forward
 Old 07-25-2012, 11:15 AM   #111
rabble rabble
802MS3's Avatar
Groans: 221
I put mine in yesterday. looks great and I have tons of room now. really a great kit overall.
 Old 07-25-2012, 11:18 AM   #112
I could be wrong, but you may need the room this kit provides to get a 3" intake to fit properly (@ the very least it is going to rub the ecu).
m249saw (07-25-2012), Micha (02-17-2013)
 Old 07-25-2012, 01:58 PM   #113
bstover17's Avatar
Groans: 228
Yeah, thats kinda what I was getting at. I don't want to just have the ECU laying somewhere and thats the only drawback I can see on upgrading the intake to the JBR.
2010 MAZDASPEED 3
The Following User Says Thank You to bstover17 For This Useful Post:
 Old 07-31-2012, 03:01 PM   #114
m249saw's Avatar
NoRegrets and HTP like this.
The Following 8 Users Say Thank You to m249saw For This Useful Post:
802MS3 (07-31-2012), BPASPEED (08-09-2012), bstover17 (07-31-2012), Easter Bunny (08-02-2012), IMASA (07-31-2012), Micha (02-17-2013), rfinkle2 (08-02-2012), uncorked11 (08-17-2012)
 Old 08-02-2012, 11:56 AM   #115
Zbrit00x's Avatar
Posts: 541   (View Stats)
Zbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the world
Dam... No shipping!
2010 ms3-sold
ww evo x -385/360
Zbrit00x is offline   Reply With Quote
 Old 08-09-2012, 06:18 AM   #116
KRNAGE's Avatar
Posts: 120   (View Stats)
KRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond repute
Do you ship overseas?
Sent from my GT-I9100 using Tapatalk 2
06 Black MPS3 Sport Pack - Australia edition
Cobb AP (RichTune e85 / 98 maps) - Autotech HPFP Internals, JBR WP, CorkSport DP, Catback, Forge v1 BPV, Denso ITV22, PG FMIC Pipes JDM Core - TWM SS, PG Shift Weight, JBR Heavy Knob - JBR 88 Trilogy - JBR Rear Sway bar, Yellowspeed Coilovers, Centric Slotted/Drilled Rotors, Hawk HP+ pads, RX8 gen1 wheels - HTP Battery Tray - JBR EGR delete, JBR TB TIG - Spin-on oil convert - Polarised HU Screen
EXE-Crew
KRNAGE is offline   Reply With Quote
 Old 08-09-2012, 08:35 AM   #117
HTP
HTP's Avatar
We sure do! Send me a PM or an e-mail (sales@hitunedperformance.com) and I'll be happy to get some details for you. Thanks!
Katie
m249saw (08-09-2012), Micha (01-17-2013), xdm88 (08-09-2012)
 Old 08-09-2012, 09:10 AM   #118
It will be worth it. HTP's customer service is on point, and their products are oem quality.
HTP (08-09-2012), m249saw (08-09-2012), Micha (02-17-2013), xdm88 (08-09-2012)
 Old 08-09-2012, 02:49 PM   #119
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
Better than oem IMO
2008 MS3 gt
470hp/463tq on GT35r at 29psi
The Following 4 Users Say Thank You to burn813 For This Useful Post:
HTP (08-09-2012), Micha (02-17-2013), rfinkle2 (08-09-2012), Zbrit00x (08-10-2012)
 Old 08-10-2012, 07:38 AM   #120
rabble rabble
802MS3's Avatar
Groans: 221
anyone have this with the JBR 3.5" intake? the intake is right up against one of the ecu connectors, afraid I'll have to move the ecu from the side of the batt tray. It looked so good
Battery Tray DJBY 2010 MS3 - Engine, Transmission & Driveline 4 08-23-2011 06:10 PM
bsd.. windage tray a must ? jracer MazdaSpeed 6 - Engine, Transmission & Driveline 3 05-15-2010 09:38 AM
Windage tray is done! ptperformance MazdaSpeed 6 - Engine, Transmission & Driveline 0 02-28-2009 07:08 PM
Page generated in 0.62541 seconds with 35 queries
