> HTP (Hi-Tuned Performance)
Like Tree39Likes
 Old 08-10-2012, 08:39 AM   #121
HTP
HTP's Avatar
Posts: 210   (View Stats)
anyone have this with the JBR 3.5" intake? the intake is right up against one of the ecu connectors, afraid I'll have to move the ecu from the side of the batt tray. It looked so good
Hey Philip,
Can you post a couple of pics of the JBR "wide path" intake to show what's hitting? Even at 3.5 inches, there should be no issues with anything rubbing. For intakes that may wandering off the "path" though, I think we've got a simple solution for you which will make relocating the ECU from the battery tray unnecessary. If you could post some pics that would be great. Thanks!
Katie
The Following 5 Users Say Thank You to HTP For This Useful Post:
802MS3 (08-10-2012), Meder (08-11-2012), rfinkle2 (08-10-2012), triphop631 (08-10-2012), xdm88 (08-15-2012)
The Following User Says NO Thank You to HTP For This Un-useful Post:
JBR (08-10-2012)
 Old 08-10-2012, 11:57 AM   #122
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Sure I will post pics when I get a chance. My seup is slightly different than most though, a 3071 with the 2.75" inlet mounted in the stock location.
'08 CWP MS3 w/ T3 3071r
Micha (02-17-2013), triphop631 (08-10-2012)
 Old 08-11-2012, 11:26 AM   #123
Zbrit00x's Avatar
Posts: 541   (View Stats)
Zbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the world
heres some pics gt3071 like @802MS3 but my inlet is the regular 4'' , I have the @jbarone 3.5 intake love it, I have the @HTP tray and love it. Using both in conjunction with one another I had to relocate my ecu since the farthest ecu connector ( the one that would end up on the bottom circled red) would not allow me to connect the harness to the ecu. In another picture circled in red you will notice black electrical tape (on intake). Thats when the ecu was mounted to the tray, it had a tight fit and was compressing both the battery tray and against intake but it was on (ecu wire harness still not on).
A possible fix or revision if htp so chooses to can be seen in this next picture. There is about .75-1 inch of room on the side away from the ecu ( depending on how much you can push the fuse box harness down/ out of the way). Doing this would just mean the bolt holes on the tray would need slight relocation, doesnt look like much else would need changing.
2010 ms3-sold
ww evo x -385/360
Zbrit00x is offline   Reply With Quote
The Following 4 Users Say Thank You to Zbrit00x For This Useful Post:
802MS3 (08-11-2012), Easter Bunny (08-11-2012), MattJackson86 (08-11-2012), rfinkle2 (08-11-2012)
 Old 08-11-2012, 12:01 PM   #124
Why the groan @jbarone don't need to ba a dick.
rfinkle2 and Deldran like this.
The Following 7 Users Say Thank You to Easter Bunny For This Useful Post:
08.5MS3 (08-11-2012), Deldran (08-13-2012), jamesr242 (08-20-2012), Meder (08-11-2012), Micha (01-17-2013), rfinkle2 (08-11-2012), Standsideways (08-11-2012)
 Old 08-11-2012, 12:28 PM   #125
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Lol brownie's calling out vendors
The Following 3 Users Say Thank You to helmetface For This Useful Post:
86AmishMs3 (09-11-2012), BPASPEED (08-11-2012), Standsideways (08-11-2012)
The Following 4 Users Say NO Thank You to helmetface For This Un-useful Post:
08.5MS3 (08-11-2012), Ckmazdaspeed3 (08-14-2012), Easter Bunny (08-20-2012), Monotonous ONE (08-16-2012)
 Old 08-11-2012, 12:52 PM   #126
HTP
HTP's Avatar
On the Gen 1 there is a wire harness that runs between the strut tower and the battery tray not allowing it to be moved over any further. The Gen 2's don't have that harness there so there is room to move the tray over but we opted for a part that fit both cars.
Can someone see if moving the ecu towards the brake booster to the rear holes on the tray will work? If so then ill start putting two extra holes for those that need to push the ECU back.
Thanks
Matt
The Following 7 Users Say Thank You to HTP For This Useful Post:
08.5MS3 (08-11-2012), 802MS3 (08-11-2012), Easter Bunny (08-11-2012), Micha (01-17-2013), rfinkle2 (08-11-2012), Voltwings (08-20-2012), xdm88 (08-15-2012)
 Old 08-11-2012, 02:10 PM   #127
Zbrit00x's Avatar
Thanks
Matt
from what I remember the ecu wiring harness would not extend but il check after work. I thought about making extra holes ( in a lower triangle fashion) and mounting the ecu diagonally, but got too lazy and went to town with zip ties and rubber grommets!
2010 ms3-sold
ww evo x -385/360
 Old 08-11-2012, 02:55 PM   #128
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
@jbarone always has a problem if someone mentions anything to do with a product he makes and it isnt complete praise.
Fuck you jbarone, and fuck your shitty camber kits, funky odd feeling shift knobs and useless egr block off kits...and your mom.
Meder is offline   Reply With Quote
The Following 7 Users Say Thank You to Meder For This Useful Post:
Deldran (08-17-2012), jamesr242 (08-20-2012), Micha (02-17-2013), mikespeed3 (08-11-2012), SleeperHatch (08-11-2012), Standsideways (08-11-2012), Todd98SE (09-01-2012)
The Following 5 Users Say NO Thank You to Meder For This Un-useful Post:
codykemmet (08-15-2012), dereeek (08-17-2012), Monotonous ONE (08-16-2012), p057 (08-20-2012), shadesofgray19 (08-18-2012)
 Old 08-11-2012, 04:08 PM   #129
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
About time someone else agrees with me
Galaxy SIII
2009 CWP Speed3
The Following 6 Users Say Thank You to SleeperHatch For This Useful Post:
Deldran (08-17-2012), dpolseno41 (08-11-2012), Micha (01-17-2013), mikespeed3 (08-11-2012), Standsideways (08-11-2012), Todd98SE (09-01-2012)
 Old 08-13-2012, 08:53 PM   #130
bewsted's Avatar
Posts: 2,456   (View Stats)
Kids.....the tray is nice....but slow down before you start gagging ..
EWG K04...GETSUM!
 Old 08-13-2012, 08:54 PM   #131
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Nut swinger just hopped on-board.
Meder (08-27-2012)
 Old 08-14-2012, 11:00 AM   #132
bewsted's Avatar
I like Htp.....
EWG K04...GETSUM!
The Following User Says Thank You to bewsted For This Useful Post:
rfinkle2 (08-16-2012)
 Old 08-15-2012, 09:19 PM   #133
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
@HTP come on with that speed 6 tray I want a reason to replace my Cpe tip with one of yours but I refuse to buy a metal tip without a small battery.
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
The Following User Says Thank You to Captain KR For This Useful Post:
Stealth01 (08-20-2012)
 Old 08-16-2012, 02:37 PM   #134
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
This is partial my fault. I was supposed to let him use my wife's car for spec. Some things fell though and I was no able to drop it off to him for the day. Hopefully I will be able to get over there soon to assist him.
sorry Will
2008 MS3 gt
470hp/463tq on GT35r at 29psi
The Following 2 Users Say Thank You to burn813 For This Useful Post:
Micha (01-17-2013), silvapain (08-17-2012)
 Old 08-16-2012, 07:14 PM   #135
Captain KR's Avatar
Groans: 391
No biggie I still wuv you I just hope @HTP doesn't mind me thrashing on some of their parts when they hook a nigga up.....
Killah Built
The Following 2 Users Say Thank You to Captain KR For This Useful Post:
 Old 08-17-2012, 10:58 AM   #136
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
This might be an option for a battery if you are looking for a AGM
D5100 | XS Power | Real Power, Unreal Performance
can be had for ~250 via the web.
says 750CA cant find a CCA rating for it. but i would think with a CA that high the CCA should be enough at least in my area
Damond Built Speed 6
 Old 08-17-2012, 08:14 PM   #137
HTP
HTP's Avatar
@greenespeed MS6 battery tray is designed, hopefully we will have a six in the shop next week to finalize mounting.
Matt
Captain KR likes this.
BigjohnB20 (08-20-2012), Captain KR (08-17-2012), greenespeed (08-18-2012), Micha (01-17-2013), xdm88 (08-23-2012)
 Old 08-17-2012, 08:50 PM   #138
Captain KR's Avatar
Groans: 391
Matt
So I should ask for Matt when this releases and I call
Killah Built
burn813 (08-17-2012), greenespeed (08-18-2012)
 Old 08-20-2012, 07:18 AM   #139
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
Groans: 82
Figured I would post a pic of my weekend install. HTP tray and ECU relocation.
 Old 08-20-2012, 07:52 AM   #140
HTP
HTP's Avatar
Just curious, any reason you didn't use the mounting on the battery tray for the ECU?
Thanks
Matt
 Old 08-20-2012, 08:00 AM   #141
Groans: 82
Thanks
Matt
I would have but I wanted to mount the ECU in front so I could have a large open surface to mount my meth tank. I already have the mount fabbed up to mount to the tank and then it will use your stock holes and hardware to mount it where the ECU should go. If it wasn't for that, it would have been super easy to use your supplied parts and mount location to bolt the ECU to the outside of the box.
The Following User Says Thank You to deadlandxtreme For This Useful Post:
HTP (08-20-2012)
 Old 08-20-2012, 08:01 AM   #142
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
I relocated my battery because couldnt fit my optima in the stock tray (too small in all dimensions and i didnt care to get a new one that fit. Fuck mazda for using odd sizes)
I don't particularly like having my battery relocated. I'd rather have it up front. I have just enough room for a tiny battery, and I dont need much else other than that since I don't have a big car stereo or anything...
Waiting to hear about MS6 trays!
HTP likes this.
p057 is offline   Reply With Quote
 Old 08-20-2012, 08:17 AM   #143
HTP
HTP's Avatar
Totally understand. Thanks for the quick reply!
BTW, we will be releasing direct bolt in MS3 Meth tanks within the next 2 weeks. Just in time for the cooler weather! lol
Matt
MattJackson86 (08-21-2012), Voltwings (08-20-2012), xdm88 (08-23-2012)
 Old 08-20-2012, 08:19 AM   #144
Groans: 82
Thumbs up
Matt
Very good to hear! Keep me posted and most likely put me on the pre-order list. LOL.
Thank you for the wonderful product.
xdm88 (08-23-2012)
 Old 08-20-2012, 08:58 AM   #145
Voltwings's Avatar
Posts: 3,713   (View Stats)
Matt
Dammit haha I already have your 3" Tip and love it, saw this thread and instantly went and bought the battery tray and thought to myself "Man, HTP makes some bad ass stuff for crazy prices... im pretty much going to have to buy anything they let out." Now i see this ^^ haha you guys are killing me!
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 08-22-2012, 03:57 PM   #146
HTP
HTP's Avatar
Update:
All battery trays produced/shipped after 8/14/12 have an extra set of holes to push the ECU back if needed for your setup. Very few people will need this but we wanted our product to be as compatible with other manufacturers products as possible.
Thanks
Matt
The Following 10 Users Say Thank You to HTP For This Useful Post:
08.5MS3 (08-22-2012), 802MS3 (08-24-2012), BPASPEED (08-22-2012), Easter Bunny (08-22-2012), MattJackson86 (08-22-2012), Meder (08-27-2012), Micha (01-17-2013), SleeperHatch (08-22-2012), Voltwings (08-22-2012), xdm88 (08-23-2012)
 Old 08-22-2012, 04:30 PM   #147
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
Matt
2 weeks!!??!! WTF!!??!!
The Following User Says Thank You to CosmicArkie For This Useful Post:
 Old 08-22-2012, 04:32 PM   #148
BPASPEED's Avatar
Posts: 1,891   (View Stats)
Groans: 60
I see what you did there ^^^^^^
The Following User Says Thank You to BPASPEED For This Useful Post:
Micha (01-17-2013)
 Old 08-22-2012, 04:34 PM   #149
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Update:
Thanks
Matt
So just move all 4 bolt holes back towards firewall? What distance and I will just make the holes myself as I got an early one.
MattJackson86 is offline   Reply With Quote
 Old 08-22-2012, 05:33 PM   #150
HTP
HTP's Avatar
The rear bolt holes will now be the front bolt holes on the ECU. Simply bolt your ECU to the tray using those 2 holes then mark and drill the rear holes using a 5/16" drill bit. The 5/16" drill bit is slightly larger than the holes on the ECU to allow use of the isolators. I will have Katie post up some pics tomorrow.
Did your ECU have interference with anything?
Matt
 Old 08-22-2012, 05:50 PM   #151
No interference with the CPE inlet, but I hope to be moving to a larger inlet shortly. Im loving the new battery tray!
HTP likes this.
 Old 08-22-2012, 06:18 PM   #152
lulz @Raider
burn813's Avatar
Matt
Are you going to play where's Waldo with those pics too?
HTP likes this.
2008 MS3 gt
 Old 08-27-2012, 07:50 AM   #153
HTP
HTP's Avatar
Thanks to @burn813 I now have a MS6 in my possession. MS6 battery trays will be available before the weeks end.
Matt
The Following 6 Users Say Thank You to HTP For This Useful Post:
08.5MS3 (08-27-2012), burn813 (08-27-2012), Easter Bunny (08-27-2012), Micha (01-17-2013), silvapain (08-27-2012), xdm88 (08-29-2012)
 Old 08-27-2012, 08:56 AM   #154
lulz @Raider
burn813's Avatar
Lol.... My wife said you better be gentle with her damn car! Lol glad I could help ya Matt!
2008 MS3 gt
Micha (02-17-2013)
 Old 08-27-2012, 10:55 AM   #155
lulz @Raider
burn813's Avatar
Hey Matt @HTP are you going to text me those pics?
2008 MS3 gt
Micha (02-17-2013)
 Old 08-27-2012, 04:42 PM   #156
Captain KR's Avatar
Groans: 391
Matt
Can a nigga get a pm or mention when they are ready
Killah Built
 Old 08-27-2012, 05:07 PM   #157
HTP
HTP's Avatar
Soooo, a JO party with a bunch of homeless dudes in her car is outta the question???
I sure will text you pics of the JO party! :-)
Last edited by HTP; 08-27-2012 at 05:07 PM. Reason: MSF Database - Automerged Doublepost
burn813 (08-27-2012), Easter Bunny (08-29-2012), Micha (01-17-2013), xdm88 (08-29-2012)
 Old 08-27-2012, 05:30 PM   #158
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
PM sent for 2 trays plus other things to be considered for a CDN GB. Thanks.
-- Mario Andretti --
The Following User Says Thank You to Fobio For This Useful Post:
HTP (08-28-2012)
 Old 08-27-2012, 05:53 PM   #159
lulz @Raider
burn813's Avatar
Dick
HTP likes this.
2008 MS3 gt
HTP (08-27-2012), Micha (02-17-2013)
 Old 08-27-2012, 07:22 PM   #160
HTP
HTP's Avatar
Absolutely!
Thanks
Matt
Battery Tray DJBY 2010 MS3 - Engine, Transmission & Driveline 4 08-23-2011 06:10 PM
bsd.. windage tray a must ? jracer MazdaSpeed 6 - Engine, Transmission & Driveline 3 05-15-2010 09:38 AM
Windage tray is done! ptperformance MazdaSpeed 6 - Engine, Transmission & Driveline 0 02-28-2009 07:08 PM
Page generated in 0.59780 seconds with 39 queries
