> HTP (Hi-Tuned Performance)
Like Tree47Likes
 Old 03-03-2013, 08:42 PM   #281
shadesofgray19's Avatar
Posts: 794   (View Stats)
Anyone install the 3.5 on an ms6 with cp-e fmic? I'm concerned there is not enough room since the hot pipe on the fmic goes down the driver side.
@HTP;
 Old 03-03-2013, 09:52 PM   #282
Micha's Avatar
Posts: 3,436   (View Stats)
Originally Posted by Boosten Ya(josh) View Post
Thanks Katie at @HTP; for everything and the suckers.
YOU ARE WHAT YOU EAT.
Boosted Beluga (03-03-2013)
 Old 03-03-2013, 11:40 PM   #283
razorscs's Avatar
Posts: 391   (View Stats)
razorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the world
Originally Posted by DamagedGoods View Post
Anyone with a Speed 6 have to notch the battery tray to get it to fit? (on a K04)
Mine just didn't want to cooperate without modifying the tray.
I had to with the BNR, no way it was fitting. Easy to do though and turned out fine.
Sent from my Nexus 7 using Tapatalk 2
2007 MS6- BNR S3, HTP 3" Intake, 3 Bar MAP, DO Meth, CP-E Catted DP, Autotech Internals, SRI, ETS TMIC, Sure Sidewinder, Sure Charge Tubes, Lex tuned, BC Coils, Sure RMM, JBR SSP, Dreadnaught, Whiteline RSB
2008 Mazdaspeed3- Totalled!
razorscs is offline   Reply With Quote
 Old 03-05-2013, 07:33 AM   #284
Speedie6's Avatar
Posts: 1,838   (View Stats)
@HTP;
Well, that is what I'm going to be doing. I have to get a custom unit due to my stupid Steed Speed manifold. But, based on preliminary looks using the one I got at first, I believe it will fit. I will be getting the unit in soon.
EDIT: See the picture above, the hole to the wheelwell is clear.
 Old 03-11-2013, 06:37 AM   #285
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Anyone else have a problem with the aem filter slipping off?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 03-11-2013, 07:35 AM   #286
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I am not having any trouble. Using the supplied clamp my filter is not going anywhere.
 Old 03-11-2013, 08:30 AM   #287
Groans: 50
Ether the clamp slips off or filter will slip off. I feel if the bead roll on that part of the intake wasn't there then I wouldn't have a problem.
08 Mazdaspeed 3
 Old 03-11-2013, 09:20 AM   #288
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
No issues at all.
tappy-tap-tappytalk
Mods: stock
 Old 03-11-2013, 09:29 AM   #289
KusteLokal's Avatar
Posts: 2,664   (View Stats)
Groans: 124
The bead roll is there to prevent slipping
Sent from GalaxyS3
1995 Miata 1.8
2006 MS6 Sold
 Old 03-11-2013, 09:43 AM   #290
Groans: 50
I know but for me it's causing the slippage.
08 Mazdaspeed 3
 Old 03-11-2013, 09:53 AM   #291
KusteLokal's Avatar
Groans: 124
Hmmmm, @HTP; any ideas? Also try posting a vid of the filter slipping off and call them.
Sent from GalaxyS3
1995 Miata 1.8
2006 MS6 Sold
 Old 03-11-2013, 10:02 AM   #292
Groans: 50
I'll do that. If aem added an additional 1/2" to their coupler it would also be fine. I'm going to try some sandpaper to scuff it up.
08 Mazdaspeed 3
 Old 03-11-2013, 10:05 AM   #293
Karmat's Avatar
Posts: 1,179   (View Stats)
I believe the MS6 that we used to test fit had a replacement battery that was a bit smaller and that's what may have thrown our measurements off. We will be verifying everything next week and coming up with a solution.
Matt
Updates?
2002 Corvette Z06 (Black)
The Following User Says Thank You to Karmat For This Useful Post:
DamagedGoods (03-11-2013)
 Old 03-11-2013, 10:06 AM   #294
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Now, to be clear, I'm not running the HTP intake, but I do run the AEM on my Cobb intake which has just a lip about 0.75" deep to attach the filter with, no bead or anything.
Since the HTP has a bead, and there's no air pressure or anything pushing against it, what's causing it to come off?
Seems like (guessing here!) it would have to be not on far enough to have the bead on the other side of the clamp, or it's vibrating so bad that the filter is being shaken off. Or both...
I dunno. I know you know how to turn a wrench Boosten!! Curious to see what's decided
340hp / 371tq
Boosted Beluga (03-11-2013)
 Old 03-11-2013, 11:03 AM   #295
Groans: 50
It doesn't go on far enough cause the lip you said ^^^ the clamp slips off the filter if I clamp it where it should be or if I clamp it on the other side the whole filter slips off. If I clamp it on the bead then the vibes makes it come loose.
Maybe heating it up to get it a little tacky?
My friend suggested I try degreaser to take the oil film off.
I'm using my pepboys special for now till I figure something out.
08 Mazdaspeed 3
 Old 03-11-2013, 11:16 AM   #296
Groans: 50
IMO a bead roll is not needed on an intake at least for the filter side as air is being sucked in. No boost is going threw it.
The turbo side yes cuz there is no support braket for the intake.
Don't get me wrong I love the intake but the stupid filter. Lol
08 Mazdaspeed 3
Last edited by Boosted Beluga; 03-11-2013 at 11:16 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-11-2013, 11:19 AM   #297
Cyclops's Avatar
Posts: 290   (View Stats)
Cyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the world
What size do you have? The filter on my 3" isn't going anywhere.
2008.5 Mazdaspeed 3 GT True Red
BNR S3. HTP Full 3.5" Intake. Self Ported Intake Mani. CorkSport Catless DP. UR Test Pipe. CXRacing Piping w/ TR8. GFB Respons BPV. Autotech HPFP. Stratified 3 Port EBCS. Stratified Guardian Angel. 3 Bar MAP Sensor w/ PnP Harness.
Cyclops is offline   Reply With Quote
 Old 03-11-2013, 11:23 AM   #298
Groans: 50
3.5"
08 Mazdaspeed 3
 Old 03-11-2013, 11:27 AM   #299
fredricktsang's Avatar
Posts: 459   (View Stats)
fredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the world
filter on my 3" hasn't moved an inch since installing it about a month ago
fredricktsang is offline   Reply With Quote
 Old 03-11-2013, 11:44 AM   #300
HTP
HTP's Avatar
Posts: 210   (View Stats)
Sent from GalaxyS3
I would try and wipe off that oil residue that is on the AEM filter. I don't like how they have the residue on there, but that's how they are shipped from AEM. Clean it off with some brake/parts cleaner, let dry, then make sure the filter is pushed on all the way.
Originally Posted by Karmat View Post
Updates?
We are still trying to make schedules work to get a local MS6 in here. Not a whole lot of them in the area, but it should be this week.
We put the bead there for long term functionality. Over time the rubber on the filter gets hard and the filter will wanna work its way off. We have seen this happen many times over the years so we would rather be proactive than reactive.
Matt
Boosted Beluga (03-11-2013), El_Diablo (03-12-2013), Pointless (04-11-2013)
 Old 03-11-2013, 11:47 AM   #301
Groans: 50
Thank you Matt. Yes I agree with you on being proactive but me being me I would buy a new filter before the rubber would dry out. But as I said, that's just the way I am.
08 Mazdaspeed 3
 Old 03-12-2013, 09:25 AM   #302
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Worst case, cut the bead off.
 Old 03-12-2013, 04:23 PM   #303
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
The ms6 will be in this weekend, promise!!
2008 MS3 gt
470hp/463tq on GT35r at 29psi
HTP (03-13-2013)
 Old 03-16-2013, 07:53 PM   #304
HTP
HTP's Avatar
Originally Posted by JDW1 View Post
I got mine to fit doing my own batt tray relocation, just had to move it ~1" back. It's snug but you can do it with out buying a tray.
In order to use a bigger intake on the 6, you will need either a smaller battery or a battery relocation. I just installed the 3" and it fit with a few changes. I had to slide the battery back but that may be due to the duralast battery that's longer than stock
Attachment 93524
Sent from GalaxyS3
I had the same problem. I could force it to fit, but it rubbed off a bunch of the powdercoating. Here is my 3" with the stock battery:
There is TONS of room with the group 51R battery tray from HTP though. I highly recommend picking up the 51R tray if you're installing one of these. Here is a picture with the HTP 51R tray:
Updates?
For those of you that have a MS6 with our full 3" intake with the stock battery, we had a MS6 in today to figure out the problem and solution. The problem turns out to be nothing other than me screwing up and not realizing that our test car had a replacement battery that didn't represent the size of the stock battery. This led us to advertise that it fit the MS6 when it in fact does not fit without modifying or moving the stock tray.
I worked on a solution today that will move your battery back while securely mounting your stock tray. We will be sending out the fix to those that we know have a MS6, and once the fix is verified, will be including it with the intakes for the MS6.
I apologize for the problems you guys incurred trying to make this fit. I will post up some pics of the fix once I refine it tomorrow.
Thanks
Matt
The Following 20 Users Say Thank You to HTP For This Useful Post:
Boosted Beluga (03-16-2013), burn813 (03-16-2013), cymen (03-16-2013), DamagedGoods (03-16-2013), djuosnteisn (03-26-2013), Dmurray06 (03-17-2013), El_Diablo (03-18-2013), Funkster777 (03-17-2013), JDW1 (03-18-2013), KevMS6 (03-26-2013), KusteLokal (03-17-2013), maisonvi (03-16-2013), memin (04-12-2013), Micha (03-16-2013), Pointless (04-11-2013), psychophyr (04-22-2013), sidekick (03-16-2013), silvapain (03-17-2013), spals (07-08-2014), TiGraySpeed6 (03-16-2013)
 Old 03-16-2013, 08:14 PM   #305
Groans: 50
Great customer service right there.
08 Mazdaspeed 3
The Following 4 Users Say Thank You to Boosted Beluga For This Useful Post:
cymen (03-16-2013), El_Diablo (03-18-2013), Micha (03-16-2013), sidekick (04-13-2013)
 Old 03-16-2013, 08:23 PM   #306
lulz @Raider
burn813's Avatar
Not many companies would take blame for something that happened with a product, let alone make a part to fix the issue and send it out to previous customer.... That is badass!!
2008 MS3 gt
The Following 6 Users Say Thank You to burn813 For This Useful Post:
Boosted Beluga (03-16-2013), cymen (03-16-2013), djuosnteisn (03-26-2013), El_Diablo (03-18-2013), Micha (03-16-2013), Pointless (04-11-2013)
 Old 03-17-2013, 06:50 AM   #307
Sweetsandman's Avatar
Posts: 334   (View Stats)
Sweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the world
The makers of my intake "sure" wouldn't...can't wait to replace it with an HTP this summer! Just can't decide if I want a 3" or a 3.5"
I Tapped that
'08 Cobalt SS - 334whp- SOLD
'09 WRX - Stage 1 - SOLD
'12 Mazdaspeed3
Sweetsandman is offline   Reply With Quote
 Old 03-17-2013, 07:07 AM   #308
lulz @Raider
burn813's Avatar
I Tapped that
Are you rocking a stock turbo? If so.... The 3in is prolly the biggest you want to go
2008 MS3 gt
 Old 03-17-2013, 10:37 AM   #309
Groans: 50
I have a 3.5" on stock turbo. I love it. Pulls hard up top and holds more boost.
08 Mazdaspeed 3
 Old 03-17-2013, 10:44 AM   #310
Given the option, I'd pick the 3.5"
The K04 is only gonna flow what it can, so anything you can do to make it's life easier is gonna help. Being sure that it's never ever starved for air flow is a good start, and a fat solid wall of air is a good thing.
340hp / 371tq
Boosted Beluga (03-17-2013), El_Diablo (03-18-2013)
 Old 03-17-2013, 02:27 PM   #311
Groans: 50
Exactly. Why limit the k04 when you have an option to let it breath better.
08 Mazdaspeed 3
 Old 03-26-2013, 12:15 AM   #312
erobi014's Avatar
Posts: 90   (View Stats)
erobi014 has a reputation beyond reputeerobi014 has a reputation beyond reputeerobi014 has a reputation beyond reputeerobi014 has a reputation beyond reputeerobi014 has a reputation beyond reputeerobi014 has a reputation beyond reputeerobi014 has a reputation beyond reputeerobi014 has a reputation beyond reputeerobi014 has a reputation beyond reputeerobi014 has a reputation beyond reputeerobi014 has a reputation beyond repute
What colors are available for powder coating. I am debating on whether to get the 3" or 3.5" intake. Only trying to see over 300 with stock turbo. It seems that some people have trouble dialing the 3.5" in. Any suggestions?
Sonic Tuning Coilovers/JBR Fully Mounted/JBR Rear Sway Bar/Moog Rear End-links/HTP 3.5" Intake/HTP Battery Tray/Forge V1 BPV/Autotech Internals/Cobb Accessport/Grimmspeed EBC/Varrstoen ES221/CP-E TMIC/CPE TBE
erobi014 is offline   Reply With Quote
 Old 03-26-2013, 06:01 AM   #313
Groans: 50
The 3.5" is fine. 2 maf cals and I'm good. They have a lot of options for powder coating.
08 Mazdaspeed 3
 Old 03-26-2013, 08:40 AM   #314
Speedie6's Avatar
@HTP;
When I first replied to you, for some idiotic reason, I was thinking the pipe went down the hole to the wheelwell. I haven't the slightest idea why I was thinking that, I've taken my hot pipe on and off many times for various reasons. So I know better. Guess I'm just stupid.
So, anyway, I got my custom version of the HTP due to the fact that that I've got a nonstandard Steeedspeed turbo manifold. It is hitting my CPE hot pipe. But, I believe the problem is that it is now too long. If I have HTP shorten it again, it'll fit fine. And, probably the regular version will already fit with the CPE. I think that when I had mine elongated, I had it elongated too much. At any rate, for pictures, see here:
My 3.5" intake isn't long enough for my Steedspeed manifold
 Old 03-26-2013, 11:48 AM   #315
Exactly why I have been hesitant to buy the 3.5" intake and asked the question.
 Old 03-27-2013, 10:11 AM   #316
Speedie6's Avatar
Well, HTP has been easy to work with to accommodate my nonstandard needs. I'm sure that after the next pass, it'll fit perfect with the CPE FMIC.
 Old 04-01-2013, 01:57 PM   #317
Domino81's Avatar
Posts: 5,081   (View Stats)
I got my HTP tray and 3" full intake kit a few days back. Love the quality and the finish. I wish you guys made more shit... Not like I need an extra excuse to spend money. Bastards...
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
The Following 2 Users Say Thank You to Domino81 For This Useful Post:
El_Diablo (04-01-2013), HTP (04-01-2013)
 Old 04-11-2013, 06:56 PM   #318
erobi014's Avatar
Just got my 3.5" intake and tray in today. Can't wait to install.
blkspeed307 and faeker like this.
The Following 2 Users Say Thank You to erobi014 For This Useful Post:
HTP (04-12-2013), psychophyr (04-22-2013)
 Old 04-14-2013, 04:00 PM   #319
erobi014's Avatar
Installed. Will take better pics when the weather is better.
The Following 3 Users Say Thank You to erobi014 For This Useful Post:
HTP (05-08-2013), psychophyr (04-22-2013), SpeedRebirth (04-14-2013)
 Old 04-15-2013, 04:23 PM   #320
erobi014's Avatar
Better pics of the intake. It sounds badass during boost. Overall, best part I have gotten so far.
HTP (04-15-2013), Micha (04-19-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f579/intakes-now-available-134325/
JBR Wide path VS Cobb SRI+TIP? This thread Refback 01-28-2013 08:55 AM
Out of stock intakes!!!!!! Toymachinespeed 2010 MS3 - Turbo Induction 26 07-30-2011 06:34 AM
CorkSport SRI Intakes CorkSport CorkSport 3 08-04-2010 03:54 PM
Page generated in 0.60209 seconds with 38 queries
