> HTP (Hi-Tuned Performance)
Like Tree110Likes
 Old 11-21-2012, 09:19 AM   #1
HTP
HTP's Avatar
Posts: 210   (View Stats)
Neutral  -1 score
Default Meth Tank Interest
We have made several different size tanks that fit on the drivers side underneath the headlight. These have a inconspicuous remote fill and all tanks include a level sensor. We have designed these so that the pump mounts directly to the tank making it a nice compact easy direct bolt on setup. I'd like some feedback on the tank sizes (to simplify production) and material of construction (to ease worrisome minds). I will post pics a little bit later.
Tank sizes we have fit: 1gal, 1.5gal, 2gal & 3gal
Material of construction: .125" 5052 Aluminum with type III black hard anodizing
Cost is a factor in hard anodizing of larger parts so therefore we'd like to reduce the selection of sizes to significantly cut this cost.
Why do these tanks need to be hard anodized? For ease of manufacturing we have chosen to make these out of aluminum. Methanol will attacks aluminum's protective oxide layer over time causing corrosion. For the last 2 years we have tested this on an uncoated tank running a 50/50 mix and have zero corrosion. We are coating the tanks just as a precaution if anyone uses a stronger mix of meth. Better safe than sorry.
Why not just make it out of stainless? If this is what people have an interest in than I certainly will. Stainless does raise production cost so that's a factor.
Thanks for any feedback or questions.
Matt
The Following 28 Users Say Thank You to HTP For This Useful Post:
3starmagnum (10-05-2013), 86AmishMs3 (11-26-2012), aromig (06-21-2015), atvfreek (11-21-2012), BigRedSpecial (11-21-2012), breakfstincluded (11-22-2012), Ckmazdaspeed3 (06-23-2013), CWP_MS3 (01-23-2013), deadlandxtreme (11-21-2012), Dmurray06 (11-21-2012), doubleflusher (11-22-2012), El_Diablo (11-21-2012), Enki (10-28-2013), faeker (01-20-2013), KevMS6 (11-25-2012), MattJackson86 (08-30-2013), MS3-a(sore)ASS-rex (11-21-2012), ms3blackmica (05-19-2013), Pointless (11-21-2012), Sid3wayS (11-21-2012), speed14 (12-20-2012), taf0422 (11-22-2012), Todd98SE (11-21-2012), Tokay444 (11-21-2012), trancehead (05-16-2013), uncorked11 (01-02-2013), Vansquish (11-22-2012), xdm88 (11-26-2012)
 Old 11-21-2012, 09:59 AM   #2
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
If it'll fit I'd like the three gallon... no reason not to go bigger (for me anyway... would it interfere with FMIC piping?)
You say the pump mounts directly to the tank; what pumps do you have in mind - DO, Snow, or something else? What type of remote fill will it include (IE, hard neck like the windshield wash reservoir, or flexible tube? What diameter, etc)?
Needed: Driver mod
The Following 4 Users Say Thank You to BigRedSpecial For This Useful Post:
bstover17 (11-21-2012), Dmurray06 (11-21-2012), Enki (10-28-2013), UnknownSuperhero (11-21-2012)
 Old 11-21-2012, 10:01 AM   #3
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Make atleast 1 big fucking trunk mount version!!!!!!!!
TEAM LUXURY
 Old 11-21-2012, 10:02 AM   #4
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
Groans: 82
Woohoo! Finally. Would your mounting location interfere with Oil catch cans or CAIs?
spinyard likes this.
 Old 11-21-2012, 10:09 AM   #5
Dmurray06's Avatar
Posts: 3,279   (View Stats)
size isn't to big of a concern to me as long as their is a level sensor. As for pump mounting. If you included a flat piece of metal mounted to the tank, we can just drill out own holes and mount it that way. Or it could come pre drilled with several different holes to accommodate the most commen meth pumps. Also, the remote fill tube would be the cats ass, as their isn't much out their for that.
As for the cost of the tank, I don't know what the cost stainless vs. aluminum is but for a bolt on tank with filler and pump mounting location. $250 +/- is where I'd be at. If stainless is at or around that I'd buy it, as most highly modified cars, especially the ones that relay on meth as a fuel, run more than 50/50.
 Old 11-21-2012, 10:12 AM   #6
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
Just curious what the cost difference is between the alum with hard anodizing and the SS?
Is there any chance the anodizing would wear off after a long period of exposure?
If the level is easily checked, and easily refilled I would suggest one size that is guarnteed not to interfere with OCC or FMIC routing. Just the largest that will fit in there.
Of course it all depends on how expensive it would be for you to have multiple sizes. If it isn't that big of a deal then you could make different ones. But initially I would say just go with what will def work to start generating some sales (and please the mob).
Is the level sensor dip stick like? Or is it compatable with electronic sensors that some kits use? Or is it a low level warning light that can be run to the cab?
Finally for pump mounting, maybe have a bracket that bolts up to a mounting plate that is sized for different pumps. (Tank to plate, plate to pump) Or offer a universal undrilled plate. I just wouldn't want anyone to risk effing up the tank itself.
Koke382 likes this.
The Following 2 Users Say Thank You to UnknownSuperhero For This Useful Post:
Koke382 (10-16-2013), Todd98SE (11-21-2012)
 Old 11-21-2012, 10:33 AM   #7
Groans: 56
That is what I was trying to say. Biggest size that won't cause interference for most setups.
Also, lots of people (myself included) run 100% meth; something to consider when choosing material.
One last question... Can I have it by Christmas?
Koke382 likes this.
Needed: Driver mod
The Following 2 Users Say Thank You to BigRedSpecial For This Useful Post:
Koke382 (10-16-2013), UnknownSuperhero (11-21-2012)
 Old 11-21-2012, 10:46 AM   #8
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
what about injection molding for one size that fits all MS3's in some sort of stock location?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
El_Diablo (11-21-2012), taf0422 (11-22-2012)
 Old 11-21-2012, 11:41 AM   #9
Ziggo's Avatar
Posts: 3,843   (View Stats)
I've always thought someone should make a decent pump/tank combo that would fit in the spare tire well. Might even work cross platform too, alot of cars run those little space saver tires.
Zigatapatalka
Davsetz likes this.
Ask Me About My:
 Old 11-21-2012, 11:49 AM   #10
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
make sure you put the port on the bottom toward the back of it. that way when you go WOT, all the meth goes there and pumps dont starve and people dont blow up
deadlandxtreme likes this.
The Following 4 Users Say Thank You to TWOptSL0W For This Useful Post:
ArcticSpeed3 (11-22-2012), BigRedSpecial (11-21-2012), deadlandxtreme (11-21-2012), Easter Bunny (11-21-2012)
 Old 11-21-2012, 06:30 PM   #11
HTP
HTP's Avatar
You say the pump mounts directly to the tank; what pumps do you have in mind - DO, Snow, or something else? What type of remote fill will it include (IE, hard nec like the windshield wash reservoir, or flexible tube? What diameter, etc)?
Most of the pumps are the same and/or have the same mounting bracket. It will be very easy to include a plate for those needing a custom mounting solution. We will be carrying Devils Own components and offering complete packages soon. We will be catering mostly to those wanting direct port injection.
The remote fill is aluminum with a vented cap connected by a 1" flexible hose. This is for ease of installation and the varying headlights on a gen 1.
I do a 3 gal for the Cobalts, why not for the speed 3. I will make a limited number of them.
It won't interfere with the catch cans that mount in that area, not sure about CAI's. My guess would be no, but I will factor that and make changes if necessary.
The cost difference between aluminum and stainless isn't so much the cost of materials, but time. The labor costs of stainless are almost a third more than aluminum. I estimate the difference being about $35-40.
The electronic level sensor is the same that's offered in most kits. They will be included with every tank. We place the sensor at a nice and safe level so that if the low level indicator comes on you will still be at a safe level.
I don't forsee the hard anodizing ever wearing through even with straight meth.
We actually just tried to buy some injection molding equipment. We want to do as much in house as we can.
Matt
Oni likes this.
The Following 10 Users Say Thank You to HTP For This Useful Post:
aromig (06-21-2015), atvfreek (11-21-2012), BigRedSpecial (11-21-2012), Dmurray06 (11-21-2012), Pointless (11-27-2012), Sid3wayS (11-21-2012), taf0422 (11-22-2012), Todd98SE (11-21-2012), uncorked11 (01-02-2013), xdm88 (11-26-2012)
 Old 11-21-2012, 06:58 PM   #12
Sid3wayS's Avatar
Groans: 97
Well post up when you got them on sale, ill definetly buy one of the limited quantity.
TEAM LUXURY
The Following User Says Thank You to Sid3wayS For This Useful Post:
 Old 11-21-2012, 07:06 PM   #13
atvfreek's Avatar
Posts: 7,787   (View Stats)
I'm definitely interested as well. Down in the fender definitely works for me. I already have a kit, pump etc, so I would mostly just be looking for the tank and bracket
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 11-21-2012, 07:18 PM   #14
bstover17's Avatar
Posts: 586   (View Stats)
Groans: 228
Im not near ready for needing meth but I am interested!
2010 MAZDASPEED 3
 Old 11-22-2012, 12:20 AM   #15
Todd98SE's Avatar
Posts: 1,077   (View Stats)
I would love this as I'm pending on my meth kit install. Just bought a bunch of metal to fab brackets so this solution would save me a massive headache. Thin wall stainless would be preferred.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following User Says Thank You to Todd98SE For This Useful Post:
Boostman07 (11-15-2013)
 Old 11-22-2012, 12:45 AM   #16
KevMS6's Avatar
Posts: 316   (View Stats)
Could be interested in this too...
Tuned with by
 Old 11-22-2012, 06:09 AM   #17
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Please forgive my ignorance but will this be made to work with the genpu aswell?
 Old 11-22-2012, 06:36 AM   #18
ledfootrob's Avatar
Posts: 195   (View Stats)
ledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the world
Subbed for interest
ledfootrob is offline   Reply With Quote
 Old 11-22-2012, 07:06 AM   #19
Voltwings's Avatar
Posts: 3,713   (View Stats)
Will you be offering nozzles, elbows, controllers... For an all in 1 or is this simply a tank/pump combo?
Also, I previously had a methanol tank mounted in this location (it's in the trunk now) and I had mine sitting VERY low, which would have interfered with fmic pipes (I had an ETS at the time) but mounting slightly higher I could see that it would easily clear fmic pipes and a CAI, there is a lot of space in that fender well.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 11-22-2012, 08:44 AM   #20
Groans: 56
I'm in the same situation. Hurry up and take my money!
Needed: Driver mod
 Old 11-25-2012, 07:58 PM   #21
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
This thread dead too?
2009 CWP Speed3
 Old 11-25-2012, 08:45 PM   #22
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I really wish @HTP; would quit teasing use and get some finished products. Please finish your 3.5 and 4 inch full intakes. IFK how much longer I can wait
Sent from galaxy Nexus vis CM10
SleeperHatch likes this.
Damond Built Speed 6
SleeperHatch (11-25-2012)
 Old 11-26-2012, 05:31 AM   #23
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
If my input matters any, I would prefer the new tank to replace the stock washer bottle with a larger one. I have an oil cooler under the driver-side headlight with a fan and it takes up much of the room.
There a few of us local Toronto guys waiting for the 4" intakes, if that motivates you any.
Thanks.
Fueled by the haters.
 Old 11-26-2012, 07:26 AM   #24
Voltwings's Avatar
Thanks.
Not to thread jack but living in south Houston i've been meaning to add one of those, got any pics / instal thread? Thanks.
Past:
-Sold-
-Sold-
Current:
 Old 11-26-2012, 07:30 PM   #25
HTP
HTP's Avatar
Thanks.
The feedback has been very motivating for us! Thanks for all the support!
Matt
The Following 6 Users Say Thank You to HTP For This Useful Post:
breakfstincluded (11-26-2012), Celestspeed3 (11-26-2012), Dmurray06 (11-26-2012), Pointless (11-27-2012), Todd98SE (11-26-2012), uncorked11 (01-02-2013)
 Old 11-26-2012, 07:32 PM   #26
Dmurray06's Avatar
Matt
Thanks @HTP; for developing parts that no other does, and moving this platform in the right direction.
The Following 8 Users Say Thank You to Dmurray06 For This Useful Post:
breakfstincluded (11-26-2012), Celestspeed3 (11-26-2012), HTP (11-26-2012), Pointless (11-27-2012), sleepyspeed6 (10-15-2013), Todd98SE (11-26-2012), uncorked11 (01-02-2013), xdm88 (11-26-2012)
 Old 11-26-2012, 11:23 PM   #27
xdm88's Avatar
Posts: 279   (View Stats)
xdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the world
I feel this is a good way to express my experience with them. Good things come to those who wait. I personally have seen what Matt is capable of, not just the fantabulous fab work he does each day with that magic wand of his, but in creating parts like many have said, which are needed for this platform and he thinks of ways to create them more cost efficient.
There is something great about a company that asks what their customers would like to see in a product they are developing. Shows they understand the passion the end user has for placing a quality part in their car and how much they (HTP) care about satisfying them 100% by encouraging input.
Thanks for each of your parts these past two years and for the countless good ideas and subtle changes you've made to upcoming items. Here's to an amazing tank coming out!
P.s. (Anodized aluminum 2 gal tank will suffice (:
and don't think Katie is void in the process, her hands get just as dirty some days haha )
2009 ms3 black mica
2007 ms6 liquid platinum metallic
xdm88 is offline   Reply With Quote
The Following 2 Users Say Thank You to xdm88 For This Useful Post:
HTP (11-27-2012), Todd98SE (11-26-2012)
 Old 12-03-2012, 11:30 AM   #28
Groans: 56
Any updates?
Needed: Driver mod
 Old 12-17-2012, 11:08 PM   #29
Matrix311's Avatar
Posts: 2,133   (View Stats)
bump any updates? I just went big turbo and upgraded my nozzle and i currently use my washer fluid reservoir which goes through METH really fast. I need a 2nd tank badly.
 Old 12-18-2012, 07:59 AM   #30
El_Diablo's Avatar
Groans: 769
Half tempted to make an extended washer fluid tank out of aluminum or stainless. I love the looks of a FMIC but I think on a DD, meth and a a TMIC might be a better solution. With that being said I should be able to completely fill either fender with a tank and never have to worry about interference
Its either that or keep waiting I guess.
 Old 12-20-2012, 09:28 AM   #31
Groans: 56
Needed: Driver mod
 Old 12-20-2012, 09:32 AM   #32
Groans: 82
^ My thoughts exactly!
 Old 12-20-2012, 12:08 PM   #33
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
Done.
The Following 7 Users Say Thank You to CosmicArkie For This Useful Post:
chaser27 (10-28-2013), Code Monkey (12-21-2012), deadlandxtreme (12-21-2012), Dmurray06 (01-02-2013), magicka (12-20-2012), ms3blackmica (05-19-2013), uncorked11 (01-02-2013)
 Old 01-02-2013, 08:15 AM   #34
Groans: 82
Originally Posted by CosmicArkie View Post
Done.
Perfect! Now when do these go on sale? That is the exact spot I was trying to find a tank to fit.
 Old 01-02-2013, 03:42 PM   #35
If you have to ask, you can't afford it.
And if I tried to produce it to break even, you
couldn't afford it.
And if you could afford it, I'd be making about fifteen cents an hour.
Did I mention I spent waaaaaaay too much time on it?
The Following 3 Users Say Thank You to CosmicArkie For This Useful Post:
BigRedSpecial (01-03-2013), deadlandxtreme (01-03-2013), Dmurray06 (01-02-2013)
 Old 01-02-2013, 04:12 PM   #36
Dmurray06's Avatar
couldn't afford it.
10 dorra?
CosmicArkie (01-02-2013)
 Old 01-02-2013, 04:52 PM   #37
HTP
HTP's Avatar
Now that the holidays are outta the way, and our new intakes hitting the streets this week, the meth tanks are next. Thanks for having patience with us.
Matt
The Following 8 Users Say Thank You to HTP For This Useful Post:
BigRedSpecial (01-03-2013), bstover17 (01-02-2013), CtrlAlt1337 (02-12-2013), deadlandxtreme (01-03-2013), Dmurray06 (01-02-2013), faeker (01-20-2013), Micha (02-13-2013), UnknownSuperhero (01-23-2013)
 Old 01-02-2013, 10:17 PM   #38
Matt
Sorry to threadjack, Matt
Now, back to our regularly scheduled program.
 Old 01-03-2013, 06:30 AM   #39
Groans: 56
Thank you!
Needed: Driver mod
 Old 01-23-2013, 07:22 AM   #40
Groans: 82
Are we shooting for a Feb release @HTP; ?
The Following User Says Thank You to deadlandxtreme For This Useful Post:
gdawg25 (09-07-2014)
best way to seal 100% meth tank?? seanmiller09 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 08-04-2010 08:17 PM
Page generated in 0.57823 seconds with 42 queries
