| HTP (Hi-Tuned Performance) HTP (Hi-Tuned Performance) is dedicated to providing the automotive community with quality performance products and the highest level of customer service and support. Whether you're local or overseas, we like to approach each customer as though they're sitting right in front of us at the shop. Whether you're a long time customer or if you're new to HTP, we look forward to having the opportunity to prove our commitment to quality and service. |
![]() | | #81 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2014 Location: In full orbit.
Rep Power: 489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score Next week we will start to see these trickle back from anodizing, so not everyone will get dropped tracking at once. I will say that anodizing these on the inside with proper coverage has been a tricky. This is due to the smaller holes and making sure that there is no trapped air. We made design changes to aid in this process but it still required more attention on the coaters part and they aren't able to anodize as many at a time as we were quoted. I went and met with them early this week and got them to agree to running these in smaller batches and even 1 at a time if we have to. I apologize for the wait, and thank you all for being patient. |
![]() | | #82 | ![]() |
| Not Ranked : 0 score I have my tank and it's installed. If you're frustrated with the wait, I can promise you the fit and craftsmanship make it all worthwhile. Here it is complete with the accessories and hardware 4 studs in the sturdy pump mount plate and some nylock nuts The grounds are integrated cleanly back to their stock location, and the other 4 bolts are in the frame rail. This isn't going anywhere. Ahhh, so easy to fill with that convenient neck. I got a tall transmission fill funnel from Napa and it stands in there unsupported. The hose headed off to the right is the ventilation line. I hacked a 3/4" segment out of my JBR cold pipe and slipped this 3 bung adapter in there (after I ground them down to get a clean spray pattern) And here you can see blurry in the foreground is the check valve and line headed up to a D12 nozzle. I'll be adding a D10 to that, and expect the pump will be near its limits. Installation is painless and logical. The welds are works of art. The mounting points align perfectly and are extremely solid. Yes, it was a long wait - but it's worth it. Edit: DO NOT FORGET IT'S 3/8 NPT COMING FROM THE TANK FEED - if you still want to use your push lock 1/8th npt stuff, you'll need an adapter as pictured above. I ordered one from Summit, then called Napa and they had it in stock - so I've got a spare reducer if anyone needs it.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) Last edited by JgamB; 06-20-2016 at 01:05 PM. |
| The Following 13 Users Say Thank You to JgamB For This Useful Post: | Boost_creep (06-21-2016), CMajor (06-20-2016), Code Monkey (06-20-2016), g00s3y (06-20-2016), Hush (06-20-2016), Jester2552 (06-21-2016), JSmith (06-20-2016), Matt@HTP (06-21-2016), MD1032 (06-21-2016), MS3Shadow (06-20-2016), nekret (06-20-2016), nindoja (06-20-2016), Shwaykid (06-20-2016) |
![]() | | #83 | ![]() |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score No filter? Are you concerned about possible debris or metal shavings in the tank that might make its way into the pump? Or was the tank clean as a whistle? Lol.
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning |
![]() | | #84 | ![]() |
![]() Join Date: Sep 2012 Location: Omaha,Nebraska
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
| Not Ranked : 0 score Nice. Glad to see it came out so clean
__________________ Corksport Sri+Tip, Cobb FMIC, Turbosmart BPV, NGK 1 step colder Plugs,Cobb accessport v2,Cobb RMM,cobb shift weight, Megan racing test pipe, Racing beat catback exhaust, Labonte wmi controller with cooling mist pump,stratified 91 octane & e85 ots tunes,Mazdaspeed oem coilovers,CS camber plates,whiteline ALK, whiteline bumpsteer kit, whiteline poly bushings, JBR rear sway bar, SPC rear camber arms,Gtspec mid chassis Aluminum brace, Gt spec rear cross member Brace with V brace addition,Wilwood 4 pot BBk+hawk DTC 60 with DBA 4000 rotors(F),Stoptech high carbon rotor(R), stoptech street performance pads(R), Stoptech stainless steel braided brake line(FxR), Enkei Rpf1 17*8.8 +30, Aluminum hubcentric rings, Work Rs open ended lug nuts, Hankook Rs3 245/40/17 |
| The Following User Says Thank You to willix231 For This Useful Post: | JgamB (06-22-2016) |
![]() | | #85 | ![]() |
| Not Ranked : 0 score There is no debris in these from the manufacturing process. All holes were laser cut before it was formed. They all were QC & pressure tested for leaks before they went to the anodizer. They also do 2 QC checks at their ISO facility. Any debris will be introduced when filling, so don't eat Taquitos above the funnel when you fill it. |
| The Following 14 Users Say Thank You to Matt@HTP For This Useful Post: | AwAfrican (07-16-2016), Boost_creep (06-21-2016), CMajor (06-27-2016), g00s3y (06-22-2016), Hush (06-21-2016), Jester2552 (06-21-2016), JgamB (06-22-2016), JSmith (06-21-2016), MD1032 (06-21-2016), MS3Shadow (06-21-2016), neganox (06-22-2016), nekret (06-21-2016), Thepedigree13 (06-22-2016), WetzMS3 (07-01-2016) |
![]() | | #86 | ![]() |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score Don't tell me how to live.
__________________ Official CatDickRacing Sales Rep - All products backordered. |
| The Following 10 Users Say Thank You to neganox For This Useful Post: | Boost_creep (06-22-2016), CMajor (06-27-2016), JgamB (06-22-2016), JSmith (06-22-2016), Matt@HTP (06-22-2016), MD1032 (06-22-2016), MS3Shadow (06-22-2016), Shwaykid (06-22-2016), Thepedigree13 (06-22-2016), WetzMS3 (07-01-2016) |
![]() | | #87 | ![]() |
| He didn't say anything about burritos. sent from my Nexus 6P
![]() | | #88 | ![]() |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score Just so you guys know, you should run solenoids with this tank. Isn't that right @JgamB;?
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
![]() | | #89 | ![]() |
Groans: 143
Dale's meth injection fun - pre vs. post TB and dual vs. single nozzle
__________________ 2007 Mazdaspeed3 GT | |
![]() | | #90 | ![]() |
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // | |
![]() | | #91 | ![]() |
| Not Ranked : 0 score My tank better include a smedium tshirt or some fancy cat laser etching. "Catsensual induction"
![]() | | #92 | ![]() |
We are working up some more shirts. That is a damn good idear. | |
![]() | | #93 | ![]() |
Too bad I relied on a check valve though.. lol. I would NOT recommend Devil's Own for that. As @MD1032; pointed out, they aren't all made equally. This is a much better option apparently, but I went with a solenoid
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| The Following User Says Thank You to JgamB For This Useful Post: | Boost_creep (06-22-2016) |
![]() | | #94 | ![]() |
| Not Ranked : 0 score @Matt@HTP;, any updates on Gen1 ship dates? I received the email that they will be coming back from anodizing soon, so I'm planning a July 11th install. Please tell me I will have it by then
![]() | | #95 | ![]() |
![]() Join Date: Aug 2013 Location: Mountain Home , ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
__________________ 2007 Black MS3 CorkSport Turbocharger, HTP 3" Intake, CorkSport Catless Downpipe, CorkSport Catless Testpipe, CorkSport Catback, Tial 38mm EWG, GrimmSpeed EBCS, Bosch 3 Bar MAP Sensor, Forge V1 BPV, Cobb AcessPort, CP-e Stage 2 RMM, JBR Rear Sway, Moog Endlinks, ETS TMIC, AT Internals, JBR IM/TB TIG, Bilstein B8s, Cobb Springs, Rays Gram Lights 57C6 18X8.5 ET45, 235/40 Ventus RS-3, Tuned by Nishan USAF 2W1 "Warheads on Foreheads" | |
![]() | | #96 | ![]() |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 582 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
![]() | | #97 | ![]() |
| Not Ranked : 0 score Got a handful going out today! |
![]() | | #98 | ![]() |
| Not Ranked : 0 score Gen 1 or two? Sent from my LG-H810 using Tapatalk
![]() | | #99 | ![]() |
| Not Ranked : 0 score These are Gen 2's. We are receiving more back from anodizing on Tuesday. |
![]() | | #100 | ![]() |
| i know one of those are mine, i got a email about it shipping soon.
![]() | | #101 | ![]() |
| Not Ranked : 0 score None of those boxes contain cat related items or candy with said meth tank. Pass.
![]() | | #102 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2010
Rep Power: 675 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
(Thread Starter) | Not Ranked : 0 score Original post updated with shipped orders. |
| The Following User Says Thank You to HTP For This Useful Post: | JSmith (07-11-2016) |
![]() | | #103 | ![]() |
| Not Ranked : 0 score Gen 1 not feeling the love Sent from my LG-H810 using Tapatalk
| The Following 2 Users Say Thank You to willix231 For This Useful Post: | Jester2552 (07-11-2016), Shwaykid (07-11-2016) |
![]() | | #104 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score Ill be the first one to buy one of these used when someone decides they dont want. I want something like this with the fill neck, no paint, and only 2 fittings 1/2 NPT one top one bottom so I can use it as a air to water intercooler tank. I just want plain aluminum. @HTP; do you have any beta units or incomplete or failures or something that can be made like this cheap ? I dont want all the finishes. |
![]() | | #105 | ![]() |
For use of an expansion tank? Should be no problem. Our CTSV expansion tank is the same as the Speed but with different mounting brackets and a Jabsco pump flange. | |
![]() | | #106 | ![]() |
how affordable can you make it without any finish or anything, my water core has no coating on it either nor the radiator so I see no need to coat the tank. I know its nice, but I need to save cost. I was going to have one fabbed locally, but if you got something we can work out thats close to the cost then I wont take my car to the shop. Depending on the capacity of the expansion tank I was even going to go for a second tank on opposite side, but one should be enough. I also though about putting an ice box in the passenger floor board but I already claimed the entire trunk for meth, audio, and battery. My system barely seems to hold a gallon and I think it heat soaks fast. I would like to add like 3 gal to it, but of course fitment is always a bitch on this car. I have a good spal fan on the heat exchange and the bosch pump with this kit: Water to Air Intercooler So im only using the core and heat exchange and hoses everything else i upgraded. So if you can lead some advice on this, then also i have 2.5" IC pipe feeding the 3" core inlet with 3" out going to stock TB which is smaller than the outlet. Should I reduce the outlet with some sort of weld on aluminum to restrict flow and slow it down? I get boost creep with the new air to water as it steadily climbs from 25 to 26.3+ boost till redline and never stops. I did not have this issue with my CPE Fmic, but now i got like 14 inches of intercooler piping opposed to several feet so I assume I lost pressure drop. | |
| The Following 2 Users Say Thank You to Nitr0EngiE For This Useful Post: | Boost_creep (07-15-2016), WetzMS3 (07-15-2016) |
![]() | | #107 | ![]() |
| Not Ranked : 0 score here is a picture of the setup |
| The Following 4 Users Say Thank You to Nitr0EngiE For This Useful Post: |
![]() | | #108 | ![]() |
| Not Ranked : 0 score When are rest of us getting our shipment? Sent from my LG-H810 using Tapatalk
![]() | | #109 | ![]() |
| Not Ranked : 0 score He just told me on the phone hes going on 2 week vacation and no orders will be filled during that time, so sometimes after that. their website says the same thing, shipping resumes 8/1 (FOR NORMAL ORDERS, not this item) |
![]() | | #110 | ![]() |
![]() Join Date: Oct 2012 Location: Austin, TX
Rep Power: 282 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 406
| Not Ranked : 0 score Makes me not feel so bad about not even having a meth kit yet.
__________________ 2008 Mazdaspeed3 GT JBR TRU 3.5 Aluminum WP // Corksport TBE // JBR OCC Stage 2 // AP v3 (Tweaked [by me] E40 Tune) // Autotech Internals // Stratified EBCS // TWM Full Replacement w/ Type R Knob // CP-e Stage 2 RMM // JBR/Damond Full EGR Delete // Synchronic DV // NGK 6510s // FMIC [TR8 w/ JBR Pipes] // CorkSport Adjustable Struts/Lowering Springs // Progress RSB Jet Black Wax (06/24/2017) Better compression than Silaramic (02/20/2016) |
![]() | | #111 | ![]() |
![]() | | #112 | ![]() |
| Not Ranked : 0 score Nah. I'm for sure going meth. This tank came around at a damn good price so I jumped on it.
![]() | | #113 | ![]() |
| i bought this before the meth kit as well. it's a good deal to not pass up.
![]() | | #114 | ![]() |
| Not Ranked : 0 score Won't be shipping anymore Tanks until 8/1? Fack!
![]() | | #115 | ![]() |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Not Ranked : 0 score If the log jam is the anodizing shop...then this shouldnt slow delivery down too much. |
![]() | | #116 | ![]() |
(Thread Starter) | Not Ranked : 0 score Matt is on vacation however I'm here processing all stocking orders and shipping out tanks as they come back. Have no fear. -Katie |
| The Following 9 Users Say Thank You to HTP For This Useful Post: | Boost_creep (07-19-2016), CMajor (07-19-2016), Dareman (07-19-2016), Jester2552 (07-20-2016), JgamB (07-20-2016), JSmith (07-20-2016), MD1032 (07-19-2016), MS3Shadow (07-19-2016), WetzMS3 (07-20-2016) |
![]() | | #117 | ![]() |
![]() Join Date: Jun 2011 Location: McMinnville OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
__________________ 2009 Mazdaspeed3 GT - Crystal White Pearl ETS tmic / CorkSport intake / Synchronic diverter valve / Cobb short shifter / solid shifter bushings / 385gram titanium shift knob / CorkSport interior LEDs / CorkSport LED fog lights / COBB AP / COBB catless DP/ JBR Mounts / CorkSport rear sway bar / NGK 1 step cooler plugs / Autotech HPFP internals / 30% Tint / Dareman Stubby |
| The Following User Says Thank You to Dareman For This Useful Post: | JSmith (07-20-2016) |
![]() | | #118 | ![]() |
| Neutral : +1 score
The last of the Gen 2 tanks came back from anodizing late on Friday, and Katie (Tank Girl) shipped them out Monday. The delivery driver told me they were racking up the Gen 1 tanks before he left with that delivery. We are plenty stocked, so I'm not sure why our website would say we aren't shipping. Email me a link where it says that please. | |
| The Following 3 Users Say Thank You to Matt@HTP For This Useful Post: |
![]() | | #119 | ![]() |
| Not Ranked : 0 score If I am wrong than its irrelevant, sorry for confusion, but i swear I saw on the site where it said closed until 8/1, I guess its possible I had you confused with another site (did not think so but possible). Either way it does not effect me so ill back out of here. Have a good day all! EDIT: @Matt@HTP; I apologize, I found what I was talking about and it was JMF, not HTP. so ignore me ! Last edited by Nitr0EngiE; 07-21-2016 at 10:15 AM. |
![]() | | #120 | ![]() |
| in tank meth?? | david001wj | 2010 MS3 - Fuel, Nitrous & Water Injection | 7 | 06-19-2013 07:16 AM |
| Venting meth tank | f-castrillo | 2010 MS3 - Fuel, Nitrous & Water Injection | 17 | 04-19-2012 01:49 AM |
