| HTP (Hi-Tuned Performance) HTP (Hi-Tuned Performance) is dedicated to providing the automotive community with quality performance products and the highest level of customer service and support. Whether you're local or overseas, we like to approach each customer as though they're sitting right in front of us at the shop. Whether you're a long time customer or if you're new to HTP, we look forward to having the opportunity to prove our commitment to quality and service. |
![]() | | #121 | ![]() |
![]() Join Date: Jun 2011 Location: McMinnville OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
| Not Ranked : 0 score
__________________ 2009 Mazdaspeed3 GT - Crystal White Pearl ETS tmic / CorkSport intake / Synchronic diverter valve / Cobb short shifter / solid shifter bushings / 385gram titanium shift knob / CorkSport interior LEDs / CorkSport LED fog lights / COBB AP / COBB catless DP/ JBR Mounts / CorkSport rear sway bar / NGK 1 step cooler plugs / Autotech HPFP internals / 30% Tint / Dareman Stubby |
| The Following User Says Thank You to Dareman For This Useful Post: | Jester2552 (07-22-2016) |
![]() | | #122 | ![]() |
Groans: 143
| Neutral : +1 score Got my tank in the mail yesterday. Looks like everything made it in one piece. Thanks.
| The Following User Says Thank You to MD1032 For This Useful Post: | JgamB (07-21-2016) |
![]() | | #123 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2014 Location: In full orbit.
Rep Power: 489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Neutral : +1 score Just wanna update this......We are 100% shipped!!! Thank you to everyone who purchased a tank. We learned a ton during this process and it will help us bring the platform more products at a quicker and more efficient pace. We really appreciate everyone's patience throughout this and hope that the quality of the product was worth the wait. If anyone has questions during the install please contact us directly via phone, email, etc, and we'd be happy to assist. |
| The Following 9 Users Say Thank You to Matt@HTP For This Useful Post: | CMajor (07-28-2016), Code Monkey (07-28-2016), Dareman (07-28-2016), JSmith (08-03-2016), MD1032 (07-28-2016), MS3Shadow (07-28-2016), neganox (07-28-2016), therza2169 (07-28-2016), willix231 (07-28-2016) |
![]() | | #124 | ![]() |
![]() Join Date: Sep 2012 Location: Omaha,Nebraska
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
Sent from my LG-H810 using Tapatalk
__________________ Corksport Sri+Tip, Cobb FMIC, Turbosmart BPV, NGK 1 step colder Plugs,Cobb accessport v2,Cobb RMM,cobb shift weight, Megan racing test pipe, Racing beat catback exhaust, Labonte wmi controller with cooling mist pump,stratified 91 octane & e85 ots tunes,Mazdaspeed oem coilovers,CS camber plates,whiteline ALK, whiteline bumpsteer kit, whiteline poly bushings, JBR rear sway bar, SPC rear camber arms,Gtspec mid chassis Aluminum brace, Gt spec rear cross member Brace with V brace addition,Wilwood 4 pot BBk+hawk DTC 60 with DBA 4000 rotors(F),Stoptech high carbon rotor(R), stoptech street performance pads(R), Stoptech stainless steel braided brake line(FxR), Enkei Rpf1 17*8.8 +30, Aluminum hubcentric rings, Work Rs open ended lug nuts, Hankook Rs3 245/40/17 | |
![]() | | #125 | ![]() |
![]() Join Date: Feb 2016 Location: Central Texas
Rep Power: 0 ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Wish i would have seen this sooner. Please, please tell me another batch of these sweet tanks are going to be made??? |
![]() | | #126 | ![]() |
| Raider's Ohio Bottom Bitch ![]() Join Date: Oct 2012 Location: Cincinnati, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 106
| The Following User Says Thank You to therza2169 For This Useful Post: | CMajor (08-04-2016) |
![]() | | #127 | ![]() |
| Not Ranked : 0 score Another batch is in the works! As of right now they will be exactly the same as the previous batch. Anyone have feedback that got in on the last run??? - Matt |
![]() | | #128 | ![]() |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Not Ranked : 0 score That fill port you made worked out well...with a little help from a bracket. Dunno if anyone else would be interested in something similar but I can share if you would like. Maybe add a 5th support for the pump? Think tab front and back to zip tie through in the event the 4 bolts back out. |
![]() | | #129 | ![]() |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score More cat stickers.
__________________ Official CatDickRacing Sales Rep - All products backordered. |
| The Following 2 Users Say Thank You to neganox For This Useful Post: | Code Monkey (08-04-2017), KiwiFlavor (08-08-2017) |
![]() | | #130 | ![]() |
| +1 on cat stickers And I didn't have any problem with fill port. Sent from my Nexus 6P using Tapatalk
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken Last edited by MS3Shadow; 08-04-2017 at 06:05 AM. |
![]() | | #131 | ![]() |
![]() Join Date: May 2012 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 62
| Not Ranked : 0 score Just hope it doesn't take 3 years this time around. I'd be a proud owner!
__________________ 12' black mica w/tech: BNR S4 V2; CM STG 2 WMI; DAMOND TB SPACER; GUARDIAN ANGEL V3; KOZMIC OCC; CP-E SAFE SEALS; DAMOND EGR DELETE; WHITEWIDOW INTAKE GASKET; Cobb AP V3 CP-E Xcel XL SRI; CP-E 4" TIP; CP-E Catted DP; CP-E Cat-back exhaust; CP-E TMIC; Cobb BPV; JBR EBCS; Cobb RMM; CorkSport HPFP internals; JBR turbo hoses; NGK (6510) LTR7IX-11 Iridium IX Spark Plugs; JBR short shifter; JBR Small battery tray; Optima 51r Battery Rice--CorkSport interior lights and carbon fiber hood scoop ETH/METH tune by Stratified in progress |
![]() | | #132 | ![]() |
Damn, I still have a care package here for you. Address still the same?
Well let's not lump concept time into that. lol We've had almost no feedback on these which was very discouraging. We already started the next batch and so far the only change i'm implementing is a slight change to the low level indication. | ||
![]() | | #133 | ![]() |
You guys heard the man. Give some feed back if you have one installed. My only concern is the kozmic vented occ I have may be in the way. Anyone have some good pics of this tank installed?
__________________ 12' black mica w/tech: BNR S4 V2; CM STG 2 WMI; DAMOND TB SPACER; GUARDIAN ANGEL V3; KOZMIC OCC; CP-E SAFE SEALS; DAMOND EGR DELETE; WHITEWIDOW INTAKE GASKET; Cobb AP V3 CP-E Xcel XL SRI; CP-E 4" TIP; CP-E Catted DP; CP-E Cat-back exhaust; CP-E TMIC; Cobb BPV; JBR EBCS; Cobb RMM; CorkSport HPFP internals; JBR turbo hoses; NGK (6510) LTR7IX-11 Iridium IX Spark Plugs; JBR short shifter; JBR Small battery tray; Optima 51r Battery Rice--CorkSport interior lights and carbon fiber hood scoop ETH/METH tune by Stratified in progress Last edited by flyhigh; 08-04-2017 at 02:50 PM. Reason: fixed quote | |
![]() | | #134 | ![]() |
| Not Ranked : 0 score My address has changed. I'll PM you. As far as the tank goes, everything fit like a glove on mine and it sure as shit isn't moving anywhere with its like.. what.. 6 mounting points to the frame? Mass produce meth tanks and underroute piping to go with the DM manifold kit and you'll have yourself a nice market chunk. Hopefully you see my subtle suggestion.
| The Following User Says Thank You to neganox For This Useful Post: | KiwiFlavor (08-08-2017) |
![]() | | #135 | ![]() |
| I couldn't use the other mounting location on the frame, since i couldn't get to them. And i had to remove some cables to make it flush to the back side of the brace. It think it's because of my tech package that i had additional wires there. Sent from my Nexus 6P using Tapatalk
![]() | | #136 | ![]() |
Groans: 106
| Not Ranked : 0 score No problems with the studs backing out, but I haven't checked them in the ~6 months installed. |
![]() | | #137 | ![]() |
Thanks! | |
![]() | | #138 | ![]() |
Groans: 143
| Not Ranked : 0 score Interesting that loctite on the pump studs was mentioned...I took one look at the tank as-received and immediately loctited my studs to the tank...had zero issues with anything backing off as a result. Mine fit perfectly and I never had any issues with it. That is why you didn't hear from me. In my opinion nothing about the design needs to be changed. I was able to resell the tank for more than I bought it for originally.
![]() | | #139 | ![]() |
![]() Join Date: Jun 2016 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score I'd be interested in a gen 2 version
__________________ 2012 Velocity Red Mica MS3 Tech For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now Handling: JBR .250 RSB w/ billet brackets. So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver. |
![]() | | #140 | ![]() |
![]() Join Date: May 2017
Rep Power: 0 ![]() ![]() Thanks: 3
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score When is the next genpu order starting? Sent from my iPhone using Tapatalk
__________________ BNR S4,htp 3.5" intake,grimmspeed ebcs,damond egr delete,damond trilogy mounts,cpe catted dp,cpe, triton cbe,treadstone tr8 core,treadstone fmic piping,bosh 3 bar map,aem wmi kit,aem wb failsafe,autotech internals,jbr occ ![]() |
![]() | | #141 | ![]() |
![]() Join Date: Apr 2014 Location: Tualatin, Oregon
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Any update on when this will be available? Wife wants to steal the money I set aside for this on new kitchen backsplash. |
![]() | | #142 | ![]() |
![]() Join Date: Apr 2013 Location: wi
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score Is this still going to happen? How much longer?
__________________ 2008.5 gtx fmic dm pd Manley |
![]() | | #143 | ![]() |
| Not Ranked : 0 score @Matt@HTP; is too busy making me a coolant reservoir tank for an LSA.
| Display Modes | |
| in tank meth?? | david001wj | 2010 MS3 - Fuel, Nitrous & Water Injection | 7 | 06-19-2013 07:16 AM |
| Venting meth tank | f-castrillo | 2010 MS3 - Fuel, Nitrous & Water Injection | 17 | 04-19-2012 01:49 AM |
