Mazdaspeed Forums
-   HTP (Hi-Tuned Performance) (http://www.mazdaspeedforum.org/forum/forum/f579/)
-   -   TIP with bracket doesn't fit (http://www.mazdaspeedforum.org/forum/forum/f579/tip-bracket-doesnt-fit-148158/)
soul.survivor 06-16-2013 04:23 PM
2 Attachment(s)
I got the TIP with the bracket on top for the stock grommet/spacer. It does not fit. The bracket ends up rubbing the threads on the stud where it's supposed to bolt up. I installed it without the spacer because there's no way it was going to get close enough to bolt it down. The bracket should be offset toward the engine, not sitting on top of the TIP.
MZRSPEED 06-16-2013 08:41 PM
Did you email them about it first? They have awesome customer service, no doubt they would have taken care of you.
HTP 06-17-2013 07:14 AM
Line up the mounting tab and then rotate the inlet into the turbo coupler. If you install the inlet into the turbo coupler and clamp it first then it may not line up.
Matt
soul.survivor 06-17-2013 09:31 AM
Thanks for the reply.
I placed the inlet into the coupler without clamping it and rotated it all around. The bpv and intake pipes were up against the radiator hoses and other stuff before the tab was even close to being correct.
Page generated in 0.15758 seconds with 11 queries
