> 2010 MS3 - Appearance > Exterior
 Old 09-20-2014, 08:24 PM   #1
Wildchild76's Avatar
Posts: 92   (View Stats)
Wildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant future
Groaned at 6 Times in 2 Posts
Default Got a second chance
So I install paint protection film. When I bought my 11 speed, everything was mint except for the front bumper, so I couldn't install PPF on it. I was bummed. The other day I ran over a small barrier stop and f-d up my rocker panel, fender and bumper. So long story short, I've got it all fixed thanks to State Farm and now I was able to instal the paint protection film on it, so it will stay looking new.
Autotech Internals, HTP 4" Intake, OCC, BSD, Oil pan baffle,egr delete, Turbosmart Bpv, AP 3, JBR 88 Duro Mounted & Shifter Bushings, CP-e DP, CS Catback, CS front and rear sway bars, JBR rear camber arms, CS BBK w/ EBC Yellows, Koni Yellows w/ GC Coilovers, Stoptech slotted rotors w/EBC yellow stuff pads, Braided brake lines, DOT 5 fluid, CPe FMIC, CPe Turbo Mani, Precision BB 5858, Tial 44mm WG, JM Fab v1 IM, Cobb EBCS, Rolling on XXR 527s wrapped in Toyo R888's, Purple Drank Tuned Waiting to be installed: SP63 5th & 6th PI
Wildchild76 is offline   Reply With Quote
 Old 09-23-2014, 04:35 PM   #2
Got my baby back from the body shop finally! So you know what the first thing I had to do.... Wash it!!
 Old 09-23-2014, 10:57 PM   #3
Lbspeed's Avatar
Posts: 234   (View Stats)
Lbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the worldLbspeed is the leader of the world
By ppf do you mean a clear bra? If not is ppf comparable? I bet you're happy since you bought used!
Stage 2 all day bruh
Lbspeed is offline   Reply With Quote
 Old 09-24-2014, 10:50 AM   #4
Yes. Ppf is paint protection commonly called clear bra
 Old 09-24-2014, 11:03 AM   #5
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I thought this was going to be a meaningful thread, maybe you had a bad accident and survived becasue of the engineering that went into the car. Or some kind of life-threatening heroics.
Nope, it's about paint.
Blue Pu.
Easter Bunny (09-30-2014)
 Old 09-25-2014, 01:05 AM   #6
Lbspeed's Avatar
The title does make it seem that way...
 Old 09-30-2014, 10:16 AM   #7
Lbspeed's Avatar
I've been wondering about the clear bra, if you keep it on there for a few years, won't it be discolored compared to the rest of the car when you take it off? @Wildchild76;
 Old 09-30-2014, 10:26 AM   #8
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
I use to work at a ppf and window film shop. Some ppf film will turn yellow after about 3 years but if you use a high end brand such as lumar or 3m it should take much longer to discolor
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
Do I chance it spoof3r Gen2 MS3 General Discussion 11 09-03-2011 05:07 PM
Any MS3 or MS6 that had a chance to run a G35/37? SayNoToPistons Street Racing Stories ( Bench Racing ) 33 05-06-2009 10:40 AM
Page generated in 0.28173 seconds with 24 queries
