> 2010 MS3 - Appearance > Exterior
 Old 12-25-2016, 01:47 PM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
Default Looking for brightest white led bulb!
I need to replace my license plate bulbs and was reading and searching and they all seem to promise a lot. I bought the cs kit over 2 years ago and my license plate bulbs went out due to a car hit in the back bumper. So im in the search for a really white bright light for my license plate. I looked into superbrightleds.com, carid, phillips, cree etc...
Can anybody here recommend me a really good bulb that is really white bright?
Do they obligated have to be canbus in order to work?
The roads here don't have such good illumination and cops start to mess if your plate is not properly illuminated. Thankjs in advance for your support
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
 Old 12-25-2016, 01:53 PM   #2
You don't need to pay a lot to get bright bulbs.
Just get some quality ebay/Amazon bulbs.
Aaronsled are good, they are on Amazon.
Sent from my Pixel XL
g00s3y (12-25-2016)
 Old 12-25-2016, 01:59 PM   #3
eliwwjd's Avatar
Thanks guy! Listen are these aaronsled bulbs really brite white, I mean really brite white?
Do our bulbs need to be canbus?
Thanks for the answers!
 Old 12-25-2016, 02:15 PM   #4
I have them for my reverse lights and they are super bright. Much brighter than VLEDs.
And no, i don't think so.
 Old 12-25-2016, 02:26 PM   #5
eliwwjd's Avatar
Sorry for sounding noob but is vleds a brand or what bulbs are these?
 Old 12-25-2016, 02:27 PM   #6
It's an brand. They are quite expensive.
 Old 12-25-2016, 03:27 PM   #7
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
VLED's are just like monster HDMI cables...
Expensive as hell, and the same or better can be found for much much less. But people think brand name means everything.
 Old 12-25-2016, 05:23 PM   #8
kenghk's Avatar
Posts: 34   (View Stats)
kenghk is just really nicekenghk is just really nicekenghk is just really nicekenghk is just really nice
VLed makes superior products and should be considered, Philips zevo bulbs from Canadian tire are also very good. You can also ordering from the retrofit source and expect near OEM quality components. I've had all three of these and lots of Amazon/eBay stuff and there is no comparison. You get what you pay for and automotive lighting is no exception. Go to hidplanet if you need more insight.
Sent from my SM-G900W8 using Tapatalk
kenghk is offline   Reply With Quote
 Old 12-25-2016, 06:46 PM   #9
I tried VLEDs and they weren't superior and it was just overpriced. And Don't you need to be in Canada to go to Canadian Tire. OP is in Puerto Rico, that's pretty far from Canada. I have tried Retrofitsource and Morimoto for my reverse lights.
And there was no comparison to the led i got from Amazon to the other more expensive. The Amazon were brighter, they had an superior design compared to the others.
 Old 12-25-2016, 08:28 PM   #10
eliwwjd's Avatar
I saw a pair of philips xtreme vission 360 for $18.95 a pair, which is not bad considering the brand and quality. I also have a 25.00 dollar credit from carid, so when i checked their bulbs, they are a lumen authorized dealer. They have regular 40 & 50 w bulbs and plazma 400 lumens bulb but it is 1.7 inches long.
Hey can you direct me straight to the amazon link from where you bought them? I looked but i saw many different sellers. Thanls for the help once again.
 Old 12-26-2016, 12:10 AM   #11
RazoE's Avatar
Posts: 181   (View Stats)
RazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond repute
Get some circuit boards and splice them with a 194 connector and you're good to go. I got mine for around $1 each from VLEDs when they had them on clearance.
I also used reflective aluminum tape to amplify the output.
I chose regular white (5000k), as opposed to bluish white (6000k).
-2008 Mazdaspeed3
Corksport Stage II SRI - boost tubes - Dual VTA BPV / CP-E TMIC / HKS 3" CBE / JBR shifter bushings - Reverse gate - Modified Raider air dam for TMIC / COBB cold air box - AP V3 / Autotech HPFP / Damond short shift plate / Optima yellow top / Mazdaspeed lowering springs and camber arms / Black Gen Pu wheels
RazoE is offline   Reply With Quote
 Old 12-26-2016, 08:54 AM   #12
sleeveless's Avatar
Posts: 462   (View Stats)
sleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the world
JDM astar is great on amazon
2012 black Mica MS3
sold
06 Mazdaspeed 6
LED turns, front switchbacks, 7000 lumen fogs, fancy boost gauge, dipped ms3 wheels
sleeveless is offline   Reply With Quote
 Old 12-31-2016, 09:04 PM   #13
FastblackS2K's Avatar
Posts: 23   (View Stats)
FastblackS2K is just really niceFastblackS2K is just really niceFastblackS2K is just really niceFastblackS2K is just really niceFastblackS2K is just really nice
I've had good luck with DDM Tuning products. Some of the LEDs can get expensive but I think they all have good warranties?
I personally bought like a 20 pack of LEDs off of eBay for like $10 haha. Bright enough for me and I have a lot of extras (which is good b/c it's eBay shit).
FastblackS2K is offline   Reply With Quote
 Old 01-01-2017, 12:33 AM   #14
mcburtonsoft's Avatar
Posts: 5   (View Stats)
mcburtonsoft is an unknown quantity at this point
I've had good experiences with Diode Dynamics. I have their interior lights in my speed and had reverse and cargo lights from them when I had my F150.
2010 Mazdaspeed3
Autotech HPFP Internals | CNT High Flow Cat DP | Cobb Accessport V3 / Stratified Tune | Corksport RMM, SRI, TIP, SSP and Shifter Bushings | Damond PMM/TMM | JBR 125 FSB & 250 RSB | Moog End Links |
1990 Mazda MX5
Flyin Miata Short Shifter | K&N Hot Air Intake | Pacomotorsports 3" Lift Kit
"I watched a kid have an epic meltdown in the cereal aisle. But I'm taking his side, Cheerios are not Fruit Loops. His mom was being unfair."
mcburtonsoft is offline   Reply With Quote
Brightest reverse leds for MS6 mrQQ MazdaSpeed 3/6 - Car Audio & Electronics 2 06-02-2014 01:31 PM
White on White Rota Grids 18x8,5 boosted_out 2010 MS3 - Wheels & Tires 21 04-15-2012 06:47 AM
Motor Trend ranks the industry's best and brightest with annual Power List Haltech Automotive News 0 12-20-2011 05:40 PM
Headlight out... it's not the bulb Eazy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 02-11-2009 12:57 AM
Page generated in 0.33505 seconds with 27 queries
