> 2010 MS3 - Appearance > Exterior
 Old 10-11-2018, 06:44 PM   #1
ONiX's Avatar
Posts: 3   (View Stats)
ONiX is an unknown quantity at this point
Default New Ebay Headlights - Different Turn Signal Placement?
Hello. I have a 2010 MS3 and I was looking into ordering new headlights because mine have some pretty bad condensation. However, I noticed that on my car the turn signal has the bulb coming through the bottom of the reflector, rather than the ones I was looking at that have the bulb pointing forwards, like the low beam and high beam. My question is if they would fit? I'm assuming they will, but I just wanted to ask first to make sure since they seem shorter in a way? Also, I'm concerned with the quality of the actual projector and the headlights I plan on getting since they are ebay, so if anyone has any other recommendations I'd greatly appreciate it. Thanks !
Original headlights. Notice the turn signal bulb socket can't be seen from the picture of the rear of the light.
Original
Headlights I was looking into getting. Turn signal socket is visible from the rear of the headlight.
Aftermarket
ONiX is offline   Reply With Quote
 Old 01-29-2019, 08:25 AM   #2
ThizSpeed3's Avatar
Posts: 253   (View Stats)
ThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond repute
Original
Aftermarket
i have these i will have to double check now, ok from lookin at my picture the turn signal bulb has a under slot and the far small bulb is extra and you can hook up if you want too via wire tap, i did not hook mine up.
ThizSpeed3 is offline   Reply With Quote
how to: turn signal resistors? 2012speed3 2010 MS3 - How-To's 27 06-05-2019 08:19 AM
Driver's turn signal - flashes on alarm but doesn't work with turn signal? xcoldricex MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 03-23-2014 08:50 PM
Auctions: eBay Find of the Day: 1988 Mitsubishi Galant Sigma has world's strangest turn signal stalk Haltech Automotive News 0 09-24-2012 04:50 PM
Led Turn Signal Question Feargod69 MazdaSpeed 3/6 - Appearance 10 12-31-2010 11:47 PM
Page generated in 0.25685 seconds with 22 queries
