> Sonic Tuning
Like Tree7Likes
Closed Thread
 Old 04-16-2013, 04:40 AM   #161
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
BlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the world
Groaned at 32 Times in 11 Posts
Also for installation of coilovers instead of going through the hassle of undoing the rear end links(unless your changing them out) just undo the sway bar brackets! Makes for just as easy of an install
RichTuned
Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG
11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected
4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected
BlueDmnSpeed is offline
 Old 04-16-2013, 12:46 PM   #162
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
Sonic Tuning,
Can you comment on your shocks? Whether it's in-house or sourced from another manufacturer?
If it's in-housed, how's the quality?
Say Chi Sin Lo is offline
 Old 04-18-2013, 11:37 PM   #163
madspd6's Avatar
Posts: 1,009   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
Groans: 31
Originally Posted by sonic tuning View Post
Any detail where the clunks are coming from?
Make sure the spring are compressed, so that it's not loose. We had few folks had rubbing with their current wheel set due to the car height being low.
PM us more information, we will get them resolved!
I'm fully rolled and with some camber i can tuck tire right until it hits the bump stops. no rubbing. its at low speeds over smaller bumps that i hear clunks. i went over everything again and i still get them, front and rear. its less annoying now that i have 4 pretty solid motor mounts.
im still playing with swaybar endlinks to see if that was causing it. the awr's have quite a bit of adjustability.
Velocity Red Mica 06 Speed6 (ricer) #834
Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary.
Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights.
madspd6 is offline
 Old 04-21-2013, 08:40 PM   #164
Mazdaspeed3KHP's Avatar
Posts: 273   (View Stats)
Mazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond repute
I hear clunks in the rear now going over bumps, I think its the perch but idk. Is there any specific way of installing the perch? I got it on max low with both locking rings tight at the top. I know the perch rests on this bolt within the whole assembly at the top, I think thats what's causing the noise because it shifts when hitting bumps.. but idk.
Also if I wanted it more low in the back could I remove both locking rings to get more of a drop or would that be a bad idea? Currently my fronts can go alot lower than the rear, but im satified with the front, the back is just a tad higher in mm..
Mazdaspeed3KHP is offline
 Old 04-23-2013, 11:06 AM   #165
narezzaspeed3's Avatar
Posts: 171   (View Stats)
narezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the world
Groaned at 5 Times in 1 Post
hello sonictuning,
how do i become part of the GEN2 speed sonic tuning coil GB for may? :]
I'm in no rush as well, sonictuning is the best option i have, otherwise its ksports (and every single asshole in this forum says ksport is a bad choice. lol)
narezzaspeed3 is offline
 Old 04-23-2013, 11:18 AM   #166
madspd6's Avatar
Groans: 31
I think the bolt is actually supposed to go through the perch in your case.
madspd6 is offline
The Following User Says Thank You to madspd6 For This Useful Post:
thatsmrgimp2u (05-05-2013)
 Old 04-23-2013, 11:52 AM   #167
Oh shit no way maybe that's why, fuck I hope the perch doesn't break
 Old 04-24-2013, 11:58 AM   #168
sonic tuning's Avatar
Posts: 129   (View Stats)
Originally Posted by jreiden1 View Post
any news of next group buy?
We just received news for the shipment, they should be here around 20th of May.
Mine do this too when I go fast, but If im going super slow theres no noise down the driveway. Sometimes going around cul-de-sacs as well if I hit a bump. My endlinks werent "even" from side to side, but they are even top to bottom on each side. They will make more noises than stock, it says that on corksports website in their instructions for their endlinks.
Maybe sure you adjust them while the car is loaded, easier if you jack it up and load it on a ramp. Or alignment rack would work too!
Sonic Tuning,
The inner are Made in Japan, we tested 4-5 different type of shocks. This had the best seal from all of our testing.
Make sure the bolt go through the rear perch, not on top of it.
Originally Posted by narezzaspeed3 View Post
hello sonictuning,
Please PM your contact info over, Name, Email and phone number And I will put your name on the list.
That is correct!
Sonic Tuning
18938 Bonanza Way
Gaithersburg, MD 20879
www.sonictuning.com
sonic tuning is offline
 Old 04-24-2013, 12:05 PM   #169
Thanks for answering.
 Old 04-24-2013, 09:26 PM   #170
Got my stuff all figured out now, seems to be pretty solid, I will post a review and picture later this week!
The Following 2 Users Say Thank You to Mazdaspeed3KHP For This Useful Post:
PapaSmurf (05-14-2013), sonic tuning (04-25-2013)
 Old 04-25-2013, 07:38 AM   #171
Looking forward to your pictures and the review!
Glad everything is resolved.
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
The Following User Says Thank You to sonic tuning For This Useful Post:
nybe0010 (05-15-2013)
 Old 04-25-2013, 11:29 AM   #172
I'm looking forward to your review too, thanks in advance!
 Old 05-04-2013, 03:07 PM   #173
shadesofgray19's Avatar
Posts: 794   (View Stats)
Will you be providing end links for the ms6 this time around?
shadesofgray19 is offline
 Old 05-05-2013, 04:44 PM   #174
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
This was a noob mistake on my part, but just so others dont have the same issue...
Make sure that when you are setting spring preload either the entire front half of the car is in the air, or your sway bar endlinks are disconnected from the strut. i set my preload one side at a time and didnt pay attention to the sway bar, so they were super loose for a while. like three inches too loose. Made me think all sorts of crazy stuff was happening.
Now that everything is dialed in how i want it.... These are amazing. I have zero complaints about daily driving characteristics and im at 7/8 clicks (f/r). Love these coils. Thanks sonic tuning!
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline
 Old 05-14-2013, 12:11 PM   #175
^ I did the same thing! I still have issues when going slow or over bumps going slow in the front right side. I'm pretty sure it’s the endlink either not tight enough or not measured out right. I had the preload so low that the height of the car was super low. I do think that Sonic should provide shorter springs for the front to match how low the rear can go. My fronts are maxed out and there is still two to 1 1/2 finger gap. The rear I had maxed out and it was like 1 finger to 1/2 a finger. The option to go low is nice that's why the shorter spring would be better. I think the ride height is perfect with the way I have it now. I am waiting for my friend to get the pictures we took off his camera and then I will post them up. Car handles really well, even with bald stock tires.
I did notice in the front that when you are maxed out, you will still have an inch of threads showing between the top two collars and the bottom collar. From what I understand, when the coilovers are maxed out, there should be no threads showing, but I could be wrong. I tried threading the top collar down and it is too tight to even use a hammer to hammer down on.
When you are installing the rear you don’t have to remove the sway bar completely. Just loosen the 4 14mm bolts that hold the sway bar up and let it swing down to release the pressure on the spring carrier piece. I did have one issue with one of my sway bar bolts, I think I made it too tight and now when I loosen the bolt it doesn’t come out and when you tighten it goes tight and then loose again, so be careful with those.
Tools that I didn’t have that would have made this install a breeze:
Huge steel mallet to get front struts out. I used 2x4s and a hammer. Ended up going through like 4 piece of wood because I split them. I hammer each side for like an hour.
PB BLASTER is a MUST. It is also a MUST to spray everything the night before!
BREAKER BARS, short and long to break tight ass bolts such as the rear perch bolt, and bottom endlink bolt.
Power snap on drill to save time, it might save you a good 30 mins if not more.
Overall,
Take your time; it took me a good three days to get everything installed and then another 2 weeks to get everything properly installed. These coilovers are really really good quality. The struts are super beefy at the bottom compared to k sport which I like. 12 way adjusting is perfect for noobs like me that don’t want to fiddle with a knob for 5 mins.
What I really loved about the Rear adjustment is that I could jack up the car and squeeze my arm in the wheel well and adjust the damper. All other coils have you adjust from the trunk which is a pain in the ass.
On the rear strut, I forgot to put the OEM ugly cover back over the top of the strut, but it’s not really needed unless you are going to drive in the snow or extreme weather. I might throw them on winter time.
I am very satisfied with all the customer support sonic has provided me while attempting this install. I kept called and called and they helped me through the most difficult parts of the install. Great coilovers!! Highly recommended!!!
 Old 05-14-2013, 12:42 PM   #176
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Wei,
Did y'all come out with a how-to or directions for install yet?
Would be nice so everyone knows exactly what they need to do to install these correctly.
Sent from your girlfriends tapabedroom
860whp/677wtq
2.7 V6 Ecoboost
PapaSmurf is offline
 Old 05-14-2013, 12:57 PM   #177
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
Wei,
I'm working on one. It's pretty straight forward and easy if you've done coilovers before. The only difference is the rear spring collars, you have to remove a subframe bolt in order to get it installed, that was the only pain in the ass and not because of the coilovers itself, but the bolt was just really hard to get off. Otherwise it's a 3 hour install with height adjustment. I've been on these for a few days and I can say it's leaps and bounds above the H&R coilovers. I've almost got these dialed in, just need to fine tune it, but the ride is nice and the handling is amazing. Now I just need some new tires lol
Grumpyjap is offline
 Old 05-14-2013, 04:38 PM   #178
PapaSmurf's Avatar
Awesome, I've only done h&r coils on a gen1 before. I'm sure it won't be that much different to install on a gen2. Won't be doing it till end of July, beginjg of August.
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-14-2013, 05:45 PM   #179
Grumpyjap's Avatar
Yeah basically the same as the H&Rs height adjustment is different, damper adjustment obviously and spring preload. Oh and drilling the hole bigger on the front upper strut mount. All in all a really good set of coilovers. I can;t wait to get these on the track
 Old 05-15-2013, 03:32 AM   #180
PapaSmurf's Avatar
What's different about the damper adjustment and spring preload?
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-15-2013, 08:26 AM   #181
Grumpyjap's Avatar
There was no adjust ment for them on the H&R. Just height adjustment
The Following User Says Thank You to Grumpyjap For This Useful Post:
PapaSmurf (05-15-2013)
 Old 05-15-2013, 08:35 AM   #182
PapaSmurf's Avatar
Guess I'll figure it out, Ive never done either, but I know the damper adjustment you just spin the thing on top to what you want. Not sure about the spring preload.
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-15-2013, 10:31 AM   #183
Grumpyjap's Avatar
Preload is kind of tricky, too much it will be bouncy too little and it will be soft. Whenever you do damper adjustment always remember to turn it to full hard then go softer from there.
 Old 05-15-2013, 10:56 AM   #184
PapaSmurf's Avatar
quick recap on how to pre load? lol
Drumea88 likes this.
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-15-2013, 11:02 AM   #185
Can you elaborate more on how these Sonics Tuning coilovers are better than the H&R coilovers in your opinion? Thanks!
 Old 05-21-2013, 07:43 PM   #186
Status? Also, any word on including end links for the ms6?
;@superskaterxs With your power, what is the squat like with 5k springs in the rear on hard launches?
 Old 05-21-2013, 07:50 PM   #187
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
squat is def reduced like crazy. havent had any problems breaking anything with these on if thats whats your asking!
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
superskaterxes is offline
 Old 05-22-2013, 06:25 AM   #188
Pseudonym's Avatar
Posts: 1,429   (View Stats)
are endlinks even necessary for a 6?
Cobb AP JBR SSP/SSB's
HTP 3 Incher Forge V2 BPV
eBay Test Pipe
SCUBA TUNED
Pseudonym is offline
 Old 05-22-2013, 09:33 AM   #189
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
@superskaterxes; Get ur shipment yet man? I'm so damn anxious waiting for these damn things. I feel like a crack head going through withdrawal. Needz moar lowz nahw!
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline
The Following User Says Thank You to Ray Danger 2020 For This Useful Post:
780mps3 (05-22-2013)
 Old 05-22-2013, 01:18 PM   #190
Must Have Teh 10's!
end links are needed whenever you drop the car, its just a function of the suspension geometry that you should account for.
almost! i think they are at customs right now.
The Following 4 Users Say Thank You to superskaterxes For This Useful Post:
780mps3 (05-22-2013), jreiden1 (05-23-2013), Ray Danger 2020 (05-22-2013), thatsmrgimp2u (05-22-2013)
 Old 05-22-2013, 03:57 PM   #191
Ur killing me man
K04 POWER FIGURES
S360 POWER FIGURES
 Old 05-28-2013, 08:17 PM   #192
Cleared custom today! Should have the shipment end of this weekend or early of next week!
Will post the new group buy thread soon.
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
 Old 05-28-2013, 09:02 PM   #193
How many sets for ms6?
 Old 05-28-2013, 09:27 PM   #194
We have 12 sets coming in, few of them are paid and reserved.
If you are interested in locking in a set for your self please contact us ASAP!
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
 Old 05-28-2013, 09:33 PM   #195
Been waiting so long. It's killing me...lol
K04 POWER FIGURES
S360 POWER FIGURES
 Old 05-28-2013, 09:46 PM   #196
Shorty_Meeks's Avatar
Posts: 64   (View Stats)
Shorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these parts
Groaned at 116 Times in 29 Posts
I need these
Shorty_Meeks is offline
 Old 05-28-2013, 09:53 PM   #197
I need these
Once again I need these
Last edited by Shorty_Meeks; 05-28-2013 at 09:53 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-29-2013, 01:09 AM   #198
Pseudonym's Avatar
Would end-links help with too much camber at all?
eBay Test Pipe
SCUBA TUNED
 Old 05-29-2013, 11:43 AM   #199
trixms3's Avatar
Posts: 424   (View Stats)
trixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the world
No.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Sonic Tuning CO's//JBR rear camber arms//JBR 3.5" WP//Cobb FMIC piping w/ Treadstone TR6 core//Turbosmart dual port bpv//Autotech HPFP//(unbranded) DP//straight pipe axleback// Cobb AP V3// FREEKTUNE
trixms3 is offline
 Old 05-29-2013, 03:42 PM   #200
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Any thoughts from people that actually push their car?
I understand they're a new product, but I am looking for opinions on weekend warrior activities(especially 3's) Auto-x, twisties, etc
helmetface is offline
sonic tuning (05-29-2013)
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f596/gb-v2-sonic-tuning-coilovers-137331/
GB V2: Sonic Tuning Coilovers!!! - Mazdaspeed Forums This thread Refback 01-17-2014 10:27 AM
If interested. Coil overs GB available at MSF - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-05-2013 08:58 PM
GB: Sonic Tuning Coilovers!!! sonic tuning Sonic Tuning 142 03-03-2014 03:55 AM
Anyone in Wilmington, DE area with Sonic Tuning Coilovers? MPSpd3 MazdaSpeed 3/6 - Suspension & Brakes 5 11-05-2012 06:51 PM
Sonic Tuning Coilovers superskaterxes MazdaSpeed 3/6 - Suspension & Brakes 181 07-17-2012 06:08 AM
Sonic Tuning ST8s MS3inDC Wheels & Tires - BLACK 7 09-07-2011 09:50 AM
Page generated in 0.60318 seconds with 36 queries
