KW Coilover V1 V2 V3 Amazing Price & Free Shipping!!! http://farm9.staticflickr.com/8425/7...35254281_o.jpg Advantages of a KW coilover spring strut at one glance: Optimally adjusted KW suspension for any car class and any use – comfortable, sporty or performance-oriented High-quality components for long durability Innovative technology of the independent adjustable rebound- and compression damping Use of twin-tube technology, therefore independent adjustment of the damping forces for target-oriented influence of the car body vibrations and drive dynamics Pre-set suspension with all component parts, vehicle-specific certificate and plain assembly instruction For each vehicle class and for every operational use, KW offers the optimal adjusted suspension, from comfortable, to sporty or performance-oriented. This demanding objective can only be achieved with the innovative, patented KW technology with an individually adjustable rebound- and compression damping. For this reason, we base our damping developments on twin-tube technology. With our 2-way pressure valve technology two, basically incompatible characteristics – dynamics & driving comfort – can be uniquely combined. KW Variant 1 inox-line – Perfect Street Performance http://www.kw-suspension.com/images/...rke_img_01.jpg Sporty Handling with factory pre-set damping The ideal system for customers wishing to rely on the experience of our engineers to set the damper setting, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety. The user is then free to decide the best height setting for their use and preference. Optimally pre-set Sporty harmonious damping technology Stainless steel technology "inox-line"* Individually height-adjustable Lowering range approved by the German Technical Control Board (TÜV) Fully finished complete solutions High-quality component parts for long durability KW Variant 2 inox-line – Perfect Street Performance http://www.kw-suspension.com/images/...2_image_01.jpg Sport Handling with adjustable rebound damping This system intended for the experienced driver who does not only wish to determine the individual lowering of his vehicle, but also wishes to carry out setup adjustments. The adjustable rebound damper allows adjusting the pitch and roll behaviour of the vehicle and therefore the driving pleasure can be adapted to the own requirements. Damping technology with individually adjustable rebound inox-line* stainless steel technology Individually height adjustable Adjustment parameters approved by the German Technical Control Board (TÜV) Fully finished complete solution High-quality components for long durability Comprehensive documentation for easy use KW Variant 3 inox-line – Perfect Street Performance http://www.kw-suspension.com/images/...3_image_01.jpg State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed. Damping technology with individually adjustable rebound- and compression technology inox-line* stainless steel technology Individually height adjustable Adjustment parameters approved by the German Technical Control Board (TÜV) High-quality components for long durability Infinitely variable rebound damping adjustment 14-way adjustable compression damping Unique, individually working damping force adjustment Comprehensive documentation for easy use Application: 10275006 Mazda Mazda 3 (BK) KW Coilover Kit V1 15275006 Mazda Mazda 3 (BK) KW Coilover Kit V2 35275006 Mazda Mazda 3 (BK) KW Coilover Kit V3 10275018 Mazda Mazda 3 (BL) Hatchback + Sedan excl. MPS-Mazdaspeed KW Coilover Kit V1 15275018 Mazda Mazda 3 (BL) Hatchback + Sedan excl. MPS-Mazdaspeed KW Coilover Kit V2 35275018 Mazda Mazda 3 (BL) Hatchback + Sedan excl. MPS-Mazdaspeed KW Coilover Kit V3 10275010 Mazda Mazda 3 MPS-Mazdaspeed (BK) KW Coilover Kit V1 15275010 Mazda Mazda 3 MPS-Mazdaspeed (BK) KW Coilover Kit V2 35275010 Mazda Mazda 3 MPS-Mazdaspeed (BK) KW Coilover Kit V3 10275019 Mazda Mazda 3 MPS-Mazdaspeed (BL) KW Coilover Kit V1 35275019 Mazda Mazda 3 MPS-Mazdaspeed (BL) KW Coilover Kit V3 15275005 Mazda Mazda 6 (GG/GY) Sedan, 2WD KW Coilover Kit V2 15275007 Mazda Mazda 6 (GG/GY) Wagon, 2WD KW Coilover Kit V2 |
Do you guys install them too? I live like 40 min away from Gaithersburg |
| All times are GMT -7. The time now is 05:55 PM. |
