> Sonic Tuning
 Old 05-23-2013, 06:27 PM   #1
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
Default Rear coil locking nut stuck, possibly front endlink question too
So since installation a few months ago I noticed I bit more body roll than what I had experienced with the stock suspension. I came to the conclusion that my rear springs were set too soft, so I dropped the lca's and lowered the spring perches about a half inch. Effectively reducing body roll after a quick test drive. Also raising the car a bit as well... So I go at the locking nut (on the shock) with pb blaster and fat man power and they will not budge. Looking at the nuts, I am pulling toward me, from the left (in case anyone says I'm going the wrong way). I have read about pulling them out completely and using tire irons, atf, heat, and more things that sound like a pain in the ass. I just don't want to damage these things and was wondering what recommendations you might have. The spanners are both bent now, I managed to hammer them back to almost being straight.
I'm getting a pretty gnarly clunk now from the front right when turning. Saturday I'm going to adjust the endlinks properly and replace my bushings. How do I make sure the bar is at its static position when adjusting the links? Or is it a guesstimate kind of thing?
Sent from my XT907 using Tapatalk 2
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
 Old 05-24-2013, 06:39 PM   #2
Any advice? Trying to tackle this again tomorrow.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 05-31-2013, 04:05 PM   #3
sonic tuning's Avatar
Posts: 129   (View Stats)
Give us a call on Monday, and we can go over it.
240.766-8388
Sonic Tuning
18938 Bonanza Way
Gaithersburg, MD 20879
www.sonictuning.com
sonic tuning is offline   Reply With Quote
 Old 05-31-2013, 05:09 PM   #4
I got it. Next day after the pb blasting it came right off. Also got the endlink thing worked out too. Thanks!
Sent from my XT907 using Tapatalk 4 Beta
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
The Following User Says Thank You to thatsmrgimp2u For This Useful Post:
sonic tuning (06-02-2013)
possibly front lip??? cgriffith Appearance - BLACK 27 12-24-2011 05:25 PM
WTF MS3 with a locking rear differential??? BobbleHead Mazdaspeed3/6 General Discussion 3 11-18-2011 11:34 PM
How do you get the front endlink off? pzr2874 MazdaSpeed 3/6 - Suspension & Brakes 5 04-30-2010 05:02 AM
Page generated in 0.25206 seconds with 21 queries
