| Ford Focus ST Ecoboost - General Discussion Discussion of Ford Ecoboost Engines |
![]() Join Date: Jan 2013 Location: Buffalo/NYC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
(Thread Starter) | Not Ranked : 0 score Let's hear it!
__________________ Current 2013 Ingot Silver Focus ST - ST3 Injen: 3in SES Exhaust TT Tips SOLD! 2008 Sunlight Silver MS3: BNR: S3 V2 Cobb: V3 AccessPort CNT: Catted Downpipe / Cat-Back Exhaust Damond Motorsports: RMM Eibach: Prokit HTP: 3" Intake System (One-piece) JBR: Rear Sway Bar Koni: Yellows MAC: 3-Port EBCS Morimoto: HID Kit / The Retrofit Source clear lens swap. NATOR FMIC: Cx Racing piping / Treadstone TR8 |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score Its quite a bit slower than the Focus ST, it doesn't feel any more nimble, or like a go kart at all. Just an econobox w/ a turbo that handles decently thanks to some electronic nannies. The new tech and interior is very nice in both ST models, just not worth the price tag imho.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
| The Following 3 Users Say Thank You to Neverlift For This Useful Post: |
![]() Join Date: May 2011 Location: Ottawa, ON
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 589
Groaned at 12 Times in 7 Posts
| Not Ranked : 0 score Nicer interior is subjective. I found the driver seat leg space cramped compared to my speed3. Edit: never mind, thought you meant Focus and not Fiesta. Sent from my iPhone using Tapatalk
__________________ --2010 Black Mica Mazdaspeed3-- Stock af ![]() Last edited by CaptObvious75; 06-29-2014 at 06:10 PM. Reason: because i can |
![]() Join Date: Feb 2013 Location: Broken Arrow, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 651
The fiesta is a much smaller car than the MS3. They're also pretty expensive. If you're set on a ST I'd go with the Focus. Larger, quicker, with a pretty similar price. Sent from my iPad using Tapatalk
__________________ 2013 Mazdaspeed 3 VRM Cobb AP V2 / JBR SRI / JBR TIP / CP-e xFlex RMM / Forge V1 BPV / AT Internals / eBay TP / Hypnotic Tune in progress 8K Low Beams / Optilux Yellow Fogs / Plastidipped Emblems / Painted Calipers / Rear Wiper Delete / Resonator Delete Thou shall sweep the fucking popcorn and keep dicks out of thy mouth. - Dan 3:16 | |
(Thread Starter) | Not Ranked : 0 score I know it's much smaller. The last few days I was thinking how nice it is to have the space in the ms3. I like the idea of a smaller car in theory though if it handles well and doesn't feel under powered. I'll have to test drive both but I'll probably be sticking with the ms3 for awhile. Sent from my iPhone using Tapatalk
Yeah I like the idea of a small quick little car. Two kids and a wife throws that out the window for me though. Some clever remark about being sent from Tapatalk
| The Following User Says Thank You to danmillerok For This Useful Post: | Snip (08-15-2014) |
![]() Join Date: Nov 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score I was a little underwhelmed with the Fiesta ST when I test drove it. I just crossed 180k on my 2008 MS3 and was looking at both the Focus and Fiesta, but wasn't crazy about either. By the time you spec out a Focus ST with the options I wanted thats similar to the Fiesta ST, it's hitting 27k or so. I found an 07 MS3 thats in perfect condition, 44k miles and always garaged, owned by a Formula 1000 driver that I think I'm going to purchase to replace this 08 lol. Best thing you can do is test drive it. |
| The Following 5 Users Say Thank You to chuck131 For This Useful Post: | 93GTS (07-02-2014), Easter Bunny (08-15-2014), Neverlift (07-02-2014), predapio (07-03-2014), SpeedThrizzle (07-01-2014) |
![]() Join Date: Sep 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 205
Just wanted to add. Fiesta also comes in a 1.0L ecoboost for a lot less. I haven't driven one yet, but if Richard Hammond from top gear uk liked it then it *may* be worth a look | |
Groans: 1,143
| Not Ranked : 0 score A lot of Ford people refuse to believe Mazda developed ALL of their 4 cylinder motors from the late 80s until 2006. Ford provided Mazda with v6's during that time period. He was indeed, an idiot.
| Not Ranked : 0 score I've been driving mazda since the late 80's and working on them since the 323 came to us as the escort with zero - valve - clearance and we're deemed junk because Americans don't understand how to maintain their cars. I always rolled my eyes when I had to ask for a probe part for a KL or FS and the for guy would say (without even looking) "...it's discontinued". Most of the guys behind the parts counter don't even know why they were trained to hate the probe/626/mx6... A few Mustang owners still do, however :-) |
![]() Join Date: Jul 2011 Location: Forney, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 20 Times in 6 Posts
| Not Ranked : 0 score Heard nothing hit great reviews for the fiesta st. And if you look around you can prob fond one at a good price. I saw one last week at a dealer I pass daily and it was on sale for $21k nicely loaded too. Sent from my HTC One X using Tapatalk 2
__________________ Cobb SRI, Cobb TIP, Forge V2, JBR RMM, AWR PMM, Cobb AP, CP-E downpipe, CP-E dual cat-back exhaust, CP-E TMIC, JBR EGR delete kit, JBR T.I.G., Sure shortcut and counterweight, Autotech internals, ACT 6-Puck clutch, Megan Racing springs, Enkei Imola rims 18x7.5, 235/40/18 Continental DWS Extreme Contact |
| The Following User Says NO Thank You to JAGspeed6 For This Un-useful Post: | Neverlift (07-02-2014) |
| Not Ranked : 0 score Don't have much experience with the Fiesta ST but the Focus is in many ways an evolution of the MS3 line. It is a shame Mazda is taking a break from playing in that space.
| The Following User Says Thank You to Lex For This Useful Post: | BigJimMs3 (07-07-2014) |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
In the looks department, it may be starting to grow on me though. We'll see what happens when it's tuned.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! | |
| The Following 4 Users Say Thank You to predapio For This Useful Post: |
![]() Join Date: Mar 2013
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 123
| Not Ranked : 0 score I drove one during the Eco Boost Challenge and overall I liked it over the Focus ST. The car felt like my Speed Protege, in feel and handling...... fun little car to toss around..
__________________ [size="2"]2003 MSP Spicy Orange #1151- "Zoom freakin' Zoom" Injen CAI (black), Yellow Calipers G2 System, Carbon Fiber Tower Brace, Red Line MT-90 Tranny Fluid, Custom FMIC-Big 3 Racing , Motegi F-7 Wheels , wrapped in Yokohama Parada Spec II's 215/40/17, SU Complete set of Motor Mounts, BC Coilovers, Adjustable End Links (front & rear),Power Slot Rotors, Techna Fit SS Brake Lines, Cobalt Friction XR-3 and XR-5 Pads, Russell Speed Bleeders, Mishimoto Radiator, Haltech Platinum Sport 1000, Disco Potato upgrade ATE Super Blue Brake fluid, (Kosei K-1 TS (painted yellow) w/ Kumho V710's 225/45/17) & Enkei RPF-1's 17 X 8 Black w /Toyo 888's 235/40/17 or B F Goodrich R-1's-NASA Time Trials, Apexcone 6000K HID's, AEM UEGO Wideband, AEM Tru-Boost and Electronic Controller & Boost Guage & AEM Digital Oil Pressure Gauge , Turbosmart Black Dual BOV, Custom 3" turbo-back exhaust (Patel Engineering), Findanza Lightweight Flywheel and Exedy Stage 1 Clutch, SS AFC, Wiseco Pistons, K-1 Rods- NASA TTD #327 2003 MazdaSpeed Protege 2013 MOCO Mazdaspeed 3-Crystal White Pearl-Bi-Color w/Tech Package-JBR Stage II SRI, Mishimoto OCC, JBR .250 RSB w/ Tri-Point end links, XPEL Clear Bra, JBR PMM & RMM, JBR MOCO Mud Flaps, Yellowspeed Coilovers, JBR Adjustable Rear Camber Arms, JBR Stage 2 Black Adjustable Short Shifter Plate and Bushings, JBR Shift Knob, EGR Delete, COBB AP, CP-e Flex II RMM, CP-e Triton CBE |
![]() Join Date: Jan 2013 Location: Union City, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 406
Groans: 128
| Not Ranked : 0 score Stock for stock I like the ST cars better, the ms3 is more raw, and I want all my money to go to performance if we're talking cars of this price
__________________ Mod-bug's back... |
| Not Ranked : 0 score I recently traded in my 2010 MS3 for a Fiesta ST. I had previously checked out the Focus ST but didn't like it enough to get rid of my car for... the fiesta on the other hand... It's smaller, more fun to toss around without all that understeer, better gas mileage, can put E10 87 in it no problem for just commuting, and of course... dem recaros. |
| The Following 2 Users Say Thank You to The_Shocker For This Useful Post: | 93GTS (08-08-2014), alextheguineapig (08-08-2014) |
| The Following User Says NO Thank You to The_Shocker For This Un-useful Post: | Neverlift (08-08-2014) |
![]() Join Date: Jan 2013 Location: Springfield, Ma
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
| Not Ranked : 0 score I would LOVE to see what numbers a mostly bolted, stock turbo'd, Freektune'd on E85 Fiesta ST would put down! @Justin@Freektune;
__________________ ![]() 08 Mazdaspeed 3 GT COBB APv2 // TR8 FMIC // CP-E Full Catted Exhaust // HTP 3" // Relentless Customs IM // JBR: TB TIG, Shifter Bushings, SSP // KMD's // Grimmspeed 3-Port // Damond RMM // Autolite XP5263's |
![]() Join Date: Dec 2013 Location: Pinckney, Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 794
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score I'd like someone to BT that bitch, almost to the amount of pointless.
__________________ 2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30 |
![]() | | #19 | ![]() |
![]() Join Date: Apr 2012
| The Following 2 Users Say Thank You to lug For This Useful Post: | ALPINEST4RS (08-15-2014), kolosok17 (08-15-2014) |
![]() | | #20 | ![]() |
Edit: that also includes all of the turbo 2.3 mustangs and thunderbirds from the eighties
__________________ I hugged rfinkle2 | |
![]() | | #21 | ![]() |
__________________ 2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30 | |
![]() | | #22 | ![]() |
| Not Ranked : 0 score The 2.3 in the 99+ ranger is a Mazda mzr that is externally balanced. It will swap with any other mzr. It is an evolution of the Mazda FS engine. |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Yes but not until 2001/2002 when they switched from the 2.5 sohc to the 2.3 dohc it went to the MZR everything before that is a version of the old Lima ford.
| The Following 2 Users Say Thank You to Easter Bunny For This Useful Post: | ALPINEST4RS (08-15-2014), Neverlift (08-16-2014) |
![]() | | #24 | ![]() |
![]() Join Date: Feb 2014 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
Groans: 64
| Not Ranked : 0 score Theres a Fiesta in my pants, but no ST...........D's.
__________________ ~2013 BLACK MS3~ COBB: (APV3//Exhaust Hangers) CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs) JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC) Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+ 》》》SUPPORT YOUR MSF VENDORS《《《 |
| The Following User Says NO Thank You to Thepedigree13 For This Un-useful Post: | Neverlift (08-16-2014) |
| 1.6L Fiesta ST E85? | dsmluck | Ford Focus ST Ecoboost - General Discussion | 13 | 08-27-2013 09:19 AM |
| Ex-Fiesta Movement cars will live on at Team O'Neil Fiesta Rally Experience | Haltech | Automotive News | 0 | 07-19-2010 07:50 AM |
| Ford's Fiesta to party on -- without the Fiesta | Haltech | Automotive News | 0 | 09-14-2009 03:20 PM |
| Fiesta ECOnetic | Haltech | Automotive News | 0 | 09-12-2008 09:30 AM |
| All-New Ford Fiesta | Haltech | Automotive News | 0 | 07-15-2008 02:30 PM |
