| Ford Focus ST Ecoboost - General Discussion Discussion of Ford Ecoboost Engines |
6Likes ![]() |
![]() Join Date: Dec 2008 Location: VA Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 930
(Thread Starter) | Not Ranked : 0 score Next to stock: Same pattern for throttle body, just too bad it faces down: Port for the "sound symposer": MAP sensor port (takes same MAP sensor as the MZR): Intake ports vs MZR's. Has 1 large port instead of 2 (no VTCS). They obviously dont line up with the MZR's. It would not seal on our head due to the seals overlapping the runners: Mounted up to the MZR. Bolts up fine and would have enough clearance for our fuel rail:
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD |
| The Following 25 Users Say Thank You to theschrum For This Useful Post: | anavrinIV (10-21-2013), Andjo (05-14-2013), BigRedSpecial (09-13-2013), Boosted Beluga (10-18-2013), breakfstincluded (09-13-2013), charlesfist (05-15-2013), cshunter (10-18-2013), dale_gribble (10-22-2013), El_Diablo (09-13-2013), impossible (07-01-2014), LatinKraze (10-18-2013), Lex (09-13-2013), Mauro_Penguin (11-01-2013), MazdaspeedKills (10-28-2013), Mr Wilson (05-14-2013), mxlplx71 (05-14-2013), silvapain (09-13-2013), SLOWHATCH (05-14-2013), slw97 (07-16-2013), snailD (10-27-2013), SpeedLife (10-27-2013), TiGraySpeed6 (05-15-2013), Todd98SE (05-14-2013), Tomas (10-19-2013), x09MS3GT (09-13-2013) |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score Just seeing this for the first time... that vertical TB would allow some interesting FMIC routing. Curious what it flows like; it shouldn't be hard to machine an adapter plate to match/seal the ports
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to BigRedSpecial For This Useful Post: | El_Diablo (09-13-2013) |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score good post
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
| The Following User Says Thank You to breakfstincluded For This Useful Post: | theschrum (10-21-2013) |
| Not Ranked : 0 score Considering most FMIC pipings, and the fact that the IM already sits close to the radiator fan ... yes it would lol.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following User Says Thank You to Voltwings For This Useful Post: | BigRedSpecial (09-13-2013) |
Groans: 56
| Not Ranked : 0 score Didn't think about space between the manifold and the fan lol... yep, that could definitely be an issue. Oil filter housing as well... fuck maybe it's completely impossible.
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score But, but, it's plastic!
__________________ |
| The Following User Says Thank You to helmetface For This Useful Post: | Agent_Orange (09-14-2013) |
![]() Join Date: May 2012 Location: Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
Once I get my motor installed, I plan to test fit the manifold to check radiator clearance. Sent from my XT907 using Tapatalk 4
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD | |
| The Following 2 Users Say Thank You to theschrum For This Useful Post: | BigRedSpecial (09-14-2013), snailD (10-27-2013) |
Groans: 56
| Not Ranked : 0 score I'd say aluminum would be the cheapest route to get one made up. It's hard to tell from the pictures, but does it clear the oil filter housing?
| The Following 3 Users Say Thank You to theschrum For This Useful Post: |
![]() Join Date: Feb 2013 Location: Moore, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score I have phenolic at work how big u need. And what thickness |
| The Following 5 Users Say Thank You to glockman25 For This Useful Post: | BigRedSpecial (10-19-2013), Easter Bunny (10-27-2013), El_Diablo (10-19-2013), Mauro_Penguin (11-01-2013), theschrum (10-18-2013) |
(Thread Starter) | Not Ranked : 0 score If you were able to get some, I would much appreciate it. I would need 16"x 2.5". 1/2" thickness would probably be the best for a smooth transition but I'm sure 1/4" or 3/8" would work fine. I will gladly throw some $$ or favors your way if you can do this.
| The Following 2 Users Say Thank You to theschrum For This Useful Post: | BigRedSpecial (10-19-2013), SLOWHATCH (10-19-2013) |
| Not Ranked : 0 score Give me a week or two I'll see what I can do |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
| Not Ranked : 0 score any flow data on this?
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." |
| Not Ranked : 0 score Two pieces of 3/16 work ? |
| Not Ranked : 0 score ok i have that size for sure im trying to source some thicker |
| Not Ranked : 0 score Sorry man I got two pieces but only .25 inch is that enough or u need an extra 1/8? If that work give me your address |
| The Following User Says Thank You to glockman25 For This Useful Post: | theschrum (10-23-2013) |
![]() | | #19 | ![]() |
![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,623
| Not Ranked : 0 score I had play around with this manifold and Made a flange so it will fit a disi head and come to my Senses that the manifold can handle high boost because it Plastic the max is 24psi before going boom
__________________ [SIGPIC][/SIGPIC] |
| The Following 2 Users Say Thank You to SPEED6 KILLAH For This Useful Post: | BigRedSpecial (10-27-2013), superskaterxes (10-28-2013) |
![]() | | #20 | ![]() |
Groans: 56
| Not Ranked : 0 score Danger to Manifold
| The Following 5 Users Say Thank You to BigRedSpecial For This Useful Post: | DoMiNic (10-28-2013), Easter Bunny (10-27-2013), impossible (07-01-2014), thehead (03-22-2014), Voltwings (10-27-2013) |
![]() | | #21 | ![]() |
![]() Join Date: Feb 2012 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,441
Groans: 88
| Not Ranked : 0 score First time in history that warning would make sense. Sent from my SCH-I605 using Tapatalk 2
__________________ 2012 LSM Mazdaspeed 3 -- sold 06/2015 ![]() Cobb AP -- 3" SRI + TIP -- gutted mid-pipe -- CX Racing FMIC -- JBR 88duro Mount Trilogy -- GrimmSpeed EBCS -- 3 Bar Map Sensor -- Kozmic vented OCC -- Synapse DV -- Magnaflow CBE -- DDM 55w 5000K low beams 4 gallon E85 mix self tune 314/370 Dynojet 2005 Black Mica Mazdaspeed MX-5 ![]() Bone stock so far |
| The Following 4 Users Say Thank You to Darth_Nuruodo For This Useful Post: |
![]() | | #22 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score Wrap it in carbon fiber cloth and epoxy resin, it will hold pressure then.
__________________ Nator is what it does. |
| The Following 2 Users Say Thank You to kritz For This Useful Post: | Easter Bunny (10-27-2013), silvapain (10-27-2013) |
![]() | | #23 | ![]() |
Any chance you could post pics of your flange?
![]() | | #24 | ![]() |
Groans: 95
| Not Ranked : 0 score Well, we'll see what @kmac; pulls out of his ass with the fiddyatefiddyate he has on his.
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Mounted the manifold up to a buddy's MS6 today to check fitment. The main issue is that the dipstick would prevent us from routing piping straight down. The N/A manifold would prevent this. The starter is close, but it doesn't appear to be a show stopper. The N/A manifold would prevent this. The coolant hoses are directly in the path of the cold pipe. The N/A manifold would prevent this. The manifold hits the fuel pressure sensor. IIRC, the JMF manifold uses an elbow to relocate the sensor. The PS pump hit the bracket, which could be easily cut off. There was plenty of spacing between the manifold and radiator (probably 1.5"-2"). I don't see us running this manifold. The N/A manifold won't have a MAP port, and is plastic as well so would be limited to about 24psi. Here are the pics... PS pump. Fuel pressure sensor Starter
| The Following 6 Users Say Thank You to theschrum For This Useful Post: | BigRedSpecial (10-28-2013), breakfstincluded (10-27-2013), Code Monkey (10-27-2013), El_Diablo (10-28-2013), Hush (10-28-2013), SPEED6 KILLAH (10-27-2013) |
![]() | | #26 | ![]() |
__________________ [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to SPEED6 KILLAH For This Useful Post: | theschrum (10-27-2013) |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score I am starting to consider fabricating an elbow for the throttle body to the stock location. This would solve most of the problems. I am trying to find 2 throttle body flanges. Sent from my XT907 using Tapatalk
![]() | | #28 | ![]() |
![]() Join Date: Feb 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score Thanks for sharing pictures and testing. Looks like a nice design apart from the slight fitment issues. I gather the ST does not have intake based EGR. Do you think the symposer port could be used for those needing to pass emissions. Its in roughly the right place. In the pictures it looks like the symposer port might shoot straight in No. 3 runner... or does the port channel off into the center of the plenum from there?
__________________ - 2008 Gen1 MS3 Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires. Self tuned on E85 |
![]() | | #29 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score Not sure what makes you guys think 24psi is max because its a "plastic" intake manifold. Its actually an FRP composite which is pretty strong. The honey comb structure isn't for looks but rather to reinforce the intake manifold in key points.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
| The Following User Says Thank You to El_Diablo For This Useful Post: | theschrum (10-28-2013) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score The ecoboost uses a valve timing driven egr. Aside from weight and thermal properties what are you seeing as advantages of this manifold?
![]() | | #31 | ![]() |
Groans: 769
| Not Ranked : 0 score Flow distribution and possible flow increase.
![]() | | #32 | ![]() |
![]() Join Date: Aug 2009 Location: Hershey, PA
Rep Power: 265 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Gotta give you cred for trying.This is the kinda stuff that makes this forum so great.
__________________ '06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs |
| The Following 3 Users Say Thank You to MazdaspeedKills For This Useful Post: |
![]() | | #33 | ![]() |
The only major benefit I can see other than thermal is more even flow. I didn't buy this intending to use it, but it was really inexpensive ($67). I was just hoping that it would only take a couple small modifications to work.
![]() | | #34 | ![]() |
Groans: 769
| Not Ranked : 0 score Just go ahead and bolt a fairly thick (or c channel) piece of steel or aluminum to the head ports and TB inlet, drill and tap the TB plate for an NPT fitting and hook it up to a compressed air source. Slowly up the air with a regulator from a safe location until you reach your desired test pressure.
![]() | | #35 | ![]() |
| Not Ranked : 0 score Did anyone have this manifold on a flow bench?
![]() | | #36 | ![]() |
Groans: 769
| Not Ranked : 0 score Not to my knowledge but I would love to see it.
![]() | | #37 | ![]() |
| Not Ranked : 0 score Fixed.
![]() | | #38 | ![]() |
Groans: 769
| Not Ranked : 0 score Not going to lie... I was tempted to type that, lol. I would love to see where they fail and at what PSI they fail.
![]() | | #39 | ![]() |
| Not Ranked : 0 score Hahah, well it would give you a fairly definitive answer on exactly how much boost it can handle. Perhaps you ought to send it over to @Turbo_Steve; to have it flowbenched first
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score @glockman25; Thanks for the phenolic! I will start matching it up once I get access to a bandsaw.
| The Following 2 Users Say Thank You to theschrum For This Useful Post: | 2k4_8 (11-03-2013), glockman25 (10-29-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f598/ecoboost-intake-manifold-vs-mzr-intake-manifold-145509/ | ||||
| Cosworth likely to make duratec RWD intake manifold- coming soon - Page 3 - Turbo Ranger Forums | This thread | Refback | 10-13-2013 05:37 PM | |
| intake manifold help | turd burglar | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 05-01-2010 09:14 PM |
| Intake manifold?? | steedspeed | MazdaSpeed 3/6 - Turbo Induction | 40 | 03-18-2010 03:01 AM |
| **WTB** MS6 intake manifold | Deadman | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 12-27-2008 06:24 PM |
