E-Tuners / Custom Hardparts
 Old 01-07-2014, 08:00 PM   #1
djmoore250's Avatar
Posts: 29   (View Stats)
djmoore250 is a jewel in the roughdjmoore250 is a jewel in the roughdjmoore250 is a jewel in the roughdjmoore250 is a jewel in the rough
Default 93 Tune Completed...
Just got done with my 93 octane tune with Lex and saying I'm IMPRESSED is an understatement. There is so much more to the tune than making great power. With the OTS map I would never hit the rev limiter because the power would start to sign off, now the power delivery is so smooth and pulls so long I find myself bouncing it every once in a while. The speed3 in stock form is fun to drive, now all I think about is wanting to drive the car around, sucks having winter tires on because they are getting ripped from all of the WOT runs. The results speak for themselves (see attachment). Well done Lex and I'll be in touch for an e85 tune sooner than later, and hopefully if money permits I'll be in touch to tune the BNR S3.
2013 Speed3 With Tech / CPE Stage 2 RMM / CPE TMIC / Corksport Stage 2 SRI with TIP / Corksport Rear Sway Bar / Autotech Internals / Cobb AP V3 / NGK Iridium LTR7IX-11 Plugs / Turbosmart Kompact BOV / GrimmSpeed 3 port EBCS (2 Port Mode) / 20% Tint
djmoore250 is offline   Reply With Quote
The Following 5 Users Say Thank You to djmoore250 For This Useful Post:
bstover17 (01-07-2014), Hush (01-07-2014), Lex (01-07-2014), Mike@Stratified (01-07-2014), Tyhackman15 (04-22-2014)
 Old 04-16-2014, 09:18 PM   #2
bunta's Avatar
Posts: 42   (View Stats)
bunta has a spectacular aura aboutbunta has a spectacular aura about
So you made 320hp and 376tq with 93oct, sri,tip, internals, tmic and a tune? no downpipe, rp or exhaust?
bunta is offline   Reply With Quote
 Old 04-16-2014, 09:23 PM   #3
djmoore250's Avatar
My mod list wasn't updated, I have a catless test pipe and corksport cbe
 Old 04-16-2014, 09:50 PM   #4
bunta's Avatar
Man those are good numbers!! I have sri, tip, dp & tp(no cat), internals, stock tmic and cbe. Hopefully I can get close to your numbers on my 93
 Old 04-22-2014, 02:53 PM   #5
mrtheandrew's Avatar
Posts: 468   (View Stats)
wow! those are awesome numbers. makes me all giddy. ill have the same mods as you in a few weeks, but also a catted downpipe and FMIC... i can't wait for my tune!!
2007 True Red MS3
Koni Yellows || H&R Springs || JBR RSB || JBR Dogbone RMM || Centric Blanks || CS Pads || Goodridge SS Brake Lines || CS SSP || Hella Supertones || 55w 5000k HIDs/35w 3000k fogs || eonon D5151 HU/Nav/PS2 || 17x8 RPF1s || 235/45 DW || CS BPV || CS Intake/TIP || CXRacing/Godspeed FMIC || Ultimate Racing TP || Autotech Internals || AP v3
 Old 04-22-2014, 02:55 PM   #6
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
2013's and their magical nonsense... nice numbers man
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
 Old 04-23-2014, 07:57 AM   #7
CrawlingMS3's Avatar
Posts: 3,116   (View Stats)
CrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the world
Groans: 31
Groaned at 32 Times in 16 Posts
Change your correction factor to 1.01
Your numbers will be much more accurate then
Past
2012 Speed3. GT3071r // Manley rods // Wiseco pistons // some other goodies and some Nator love
Present
2014 Chevy Silverado Z71
CrawlingMS3 is offline   Reply With Quote
The Following User Says Thank You to CrawlingMS3 For This Useful Post:
El_Diablo (04-23-2014)
 Old 04-23-2014, 08:03 AM   #8
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
There are also two different tire sizes listed. Those numbers are certainly inflated.
Another small build completed turbo toshi MazdaSpeed 3/6 - Build Diaries 22 11-15-2012 12:46 AM
Preliminary Tune Completed SweetJP MazdaSpeed 3/6 - ECU Computer Tuning 4 10-17-2011 06:01 PM
Exhaust Completed Airman3454 Gen2 MS3 General Discussion 0 06-19-2011 01:19 PM
Completed set of Bolted Tires SnoXRacer183 2010 MS3 - Wheels & Tires 46 05-31-2010 07:10 AM
Page generated in 0.30076 seconds with 26 queries
