E-Tuners / Custom Hardparts
  • 1 Post By
  • 1 Post By
 Old 07-15-2014, 11:19 AM   #1
So who's been using the calculator?
BuddySpeed3 (12-30-2017)
 Old 12-30-2017, 06:01 PM   #2
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
I recently purchased the Guardian Angel, and plan on using it with the AEM AFR fail safe once I get a 6th port kit, but I just have a few questions
When using 2 injectors, does the Split Second controller fire both injectors simultaneously but at a lower IPW than only 1 injector, or do they alternate?
Edit* Just found out that they fire simultaneously.
Once values are calculated, do we just copy and paste them into the R4 fuel map, load it to the SS controller, and that's it?
I noticed the Calculator starts at a Maf voltage no lower than 3.5 volts, is there a reason for that? (I doubt aux fuel would be needed at anything lower than that).
If the AFR is slightly off from target, is tweaking the R4 fuel map recommended over tweaking the maf curve?
I also read that some people had issues with injectors not firing when selecting 1 millisecond for injector opening time, and that a minimum of 5 milliseconds was needed. I can't remember where I read this though.
Thanks @Lex;
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Stoich Calculator kritz MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 12-05-2013 07:39 AM
TURBO CALCULATOR!!! superskaterxes Mazdaspeed3/6 General Discussion 10 04-19-2009 09:10 AM
Page generated in 0.24182 seconds with 22 queries
