E-Tuners / Custom Hardparts
  • 1 Post By Fstrnyou
  • 1 Post By
 Old 12-31-2017, 03:18 PM   #1
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
You don't really interpolate up to 5volts. Once your MAF curve is pretty close, you plot the known range in excel and generate a best fit curve. That curve will have a formula. For MAFvolts above your used range, plug the Volt cell value in the formula at it will spit out a g/s value.
BuddySpeed3 likes this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
BuddySpeed3 (01-01-2018)
 Old 12-31-2017, 06:59 PM   #2
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Thanks I read a thread by @rfinkle2; which went into more detail about that here:
Using Excel to dial in your maf curve (meth users, perfectionists, etc.)
I quickly read through it a while back but didn't fully understand it, so I'll definitely read it again
Are you using or planning to use aux fuel?
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Stoich Calculator kritz MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 12-05-2013 07:39 AM
TURBO CALCULATOR!!! superskaterxes Mazdaspeed3/6 General Discussion 10 04-19-2009 09:10 AM
Page generated in 0.23800 seconds with 22 queries
