E-Tuners / Custom Hardparts
Like Tree7Likes
 Old 02-11-2013, 10:37 PM   #1
Novej's Avatar
Posts: 354   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
Cool Another ~400WHP BNR Speed 3
First off shot out to @Haltech for this awesome site. I've learned so much about this platform since I purchased her back in 2007. From my early days of pushing 300WHP+ with the Hypertech to the newest numbers she's now putting down I'll post below.....If it wasn't for this site I would never have met @Lex....though he and I have never met......or spoken outside emails for that matter LOL!!!
I could have chosen any of the awesome tuners this site has to offer and I'm sure I wouldn't be disappointed with any choice I could have made. Ultimately the customer service Lex showed me while purchasing my Guardian Angel was the reason I went with him. I HAVE NO REGRETS IN MY DECISION.
For a month Lex did his best to pull as much power as he could from the K04. Honestly in hindsight I wish I would have dyno'd it because he completly transformed the car. I was a hardcore Hypertech fan not anymore.......and its all LEX's fault!!!! Anyways, after 70,000 miles it was becoming quickly evident that my poor K04 was getting tired.....(albeit she never once smoked on me even when I added the UR catted downpipe). So for my birthday last year and with Lex's backing I gave Bryan Nickell a call...........
Here's what he sent me
Which meant "she" would have to go....
Yes you can pull her out with out removing the mani..........here's proof
albeit it takes some work.....but it can be done
Out with the old in with the new
Make sure you put those banjo bolts on correct.....This is how I ensured I angled it right
Might as well change the stock MAP sensor out.....Love the PNP harness....
The most annoying connector ever to get to.............(MAP PNP plugs into this guy)
The Guardian Angel and tune isn't the only STRATIFIED route I took here
New BNR Stage 3 Hung........(again never removing the stock mani.......PITA you've been warned haha)
Lex if you don't mind I'd like to send a shot out to @JP@edgeautosport.com......He sent me all the new studs and nuts needed for attaching the new turbine......And he insured it got to me before this install while saving me considerably from what the stealership tried to rape me with......so Thank-you JP
Anyother BNR S3 installers have this problem??? (Yes this is with everything torqued down)
SURE FULL 3" Whale Penis installed (filter later replaced with AEM Dryflow.....Lex and I proved it makes a considerable difference)
Here's where I installed my STRATIFIED EBCS.....
Real quick note on this guy, Lex truly has a winner with this in my opinion. The velcro/hook and loop whatever its called that he uses is AMAZING you can attach it and reattach it as many times as you need and it holds as if its the first time.....He also gives these no bullshit REUSEABLE clamps for the hoses.....All this for $85.....uh duh easy choice for me!
Another STRATIFIED EBCS pic with hose routing......
Finally All done......really doesn't look that different then when I started LOL
Quick install notes: BEWARE BEWARE the amount of coolant stored in that K04......You've been warned hahahaha
So after all this it was time for me to give my car over to Lex.......This was a LOOOOOOoooooOOOOng process but worth every moment. Lex provided me with an initial map just so the car will start. Yeah between the whale penis, new MAP, 3 Port and BNR I guess needed it. For the next month, almost month in a half.....Lex worked his magic....I logged gave him feedback then he'd create a map.....I'd log, give him feedback and then he'd create a map. He constantly had to change parameters because we quickly realized how bad the gas was out here. (even with the E85)......But most importantly Lex remained soooo patient with me. Even when I couldn't always explain what was wrong to me or how much I hated one of his revisions.....he remained calm, made the necessary changes and finally got me to the point where I was finally ready to see......just how much WE had changed her......
When I first bought the car stock she put down 240whp/260wtq..........
Today..............well see for yourself..............
This was the second run. The first run she put down 399WHP 350WTQ......
My Current Mod List:
BNR Stage 3 turbocharger,
SURE ID300 full 3" intake/maf housing,
Stratified 3 Port EBCS,
3 Bar MAP sensor/harness.
Cobb V2 FMIC (anodized black core),
Turbosmart BPV (both 10-20PSI and 20-25PSI available, 10-20 installed),
JBR EGR Delete,
Cosworth BSD,
UR catted downpipe (metal substrate),
Corksport Testpipe,
Racing Beat catback exhaust,
Fidanza flywheel,
Guardian Angel,
Sure 1/8" Intake manifold and throttle body Gaskets,
NGK Step colder spark plugs
I've included a log I took a few days ago with the current revision we're running. I can not make any alterations to these maps whats so ever, only Lex can. Uncorrected this equates to 391WHP/356WTQ.......I'm still in shock.
Lex is the truth people. The fact that he's also engineered parts that I'm using to get to this point........I have no words excetp "ALEX I AM TRULY GRATEFUL TO YOU"...(even if you are hell bent on convincing this part Eleanor part Christine mut to kill me LOL)
Another happy customer:friday:.. ...THANKS @Lex and STRATIFIED can't wait for what we have planned next.......................stay tuned everybody...........
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
The Following 55 Users Say Thank You to Novej For This Useful Post:
002hex (02-13-2013), 2k4_8 (02-13-2013), 802MS3 (02-12-2013), adrager622 (02-13-2013), aldekei (02-12-2013), Alpha (02-19-2013), ASHMS3 (02-13-2013), atvfreek (02-12-2013), beachshoer (02-12-2013), BlueStreak (02-13-2013), boostdmazda3 (02-11-2013), breakfasteatre (02-12-2013), breakfstincluded (02-11-2013), BrianB6 (02-11-2013), bstover17 (03-05-2013), bwspeed (02-12-2013), Cheapspeed (02-18-2013), ckMS3 (02-13-2013), Dimenus (02-13-2013), djuosnteisn (02-18-2013), Dmurray06 (02-12-2013), Dr. Speed (02-12-2013), Easter Bunny (02-12-2013), faeker (02-12-2013), Familyguy427 (02-12-2013), Fobio (02-12-2013), Gatorbait (02-12-2013), gsrtype1 (02-12-2013), helmetface (02-12-2013), Hush (02-12-2013), jbmazda6 (02-18-2013), JP@edgeautosport.com (02-12-2013), kish89 (02-12-2013), ktms3 (03-07-2013), Lex (02-12-2013), lilred (02-12-2013), Mase (02-13-2013), Micha (02-12-2013), Mike@Stratified (02-12-2013), Mistersix (02-12-2013), ms3blackmica (05-01-2013), Nliiitend1 (02-12-2013), Rainmens (02-13-2013), rfinkle2 (02-13-2013), Rich990 (02-14-2013), Rokusek (02-13-2013), SarcasticOne (02-11-2013), smoogs12 (02-18-2013), speedms6 (02-12-2013), SpeedNess (02-18-2013), taf0422 (02-12-2013), TheFlash (02-13-2013), wifudude (06-02-2013), YABBAMZR (02-12-2013), Yatta (02-13-2013)
 Old 02-11-2013, 11:02 PM   #2
BrianB6's Avatar
Posts: 400   (View Stats)
Time to by some tires.
Must be a blast to drive.
2006 - MS6 - Dead RIP
The Following 2 Users Say Thank You to BrianB6 For This Useful Post:
Lex (02-12-2013), Novej (02-11-2013)
 Old 02-11-2013, 11:06 PM   #3
Novej's Avatar
TRUTH on both accounts!!!
The Following User Says Thank You to Novej For This Useful Post:
Lex (02-12-2013)
 Old 02-11-2013, 11:27 PM   #4
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
this is 400whp without additional fueling?
The Following 4 Users Say Thank You to breakfstincluded For This Useful Post:
Easter Bunny (02-12-2013), Lex (02-12-2013), Novej (02-12-2013), Vader (02-12-2013)
 Old 02-12-2013, 12:04 AM   #5
Thanks Jevon, the pleasure was mine as we worked through your tunes and setup. Really enjoyed the process and I am very happy to see your hard work in putting this setup together paid off.
This car at 80k miles is really a model setup for the FWD MS3 on stock block. Boost is around 23.5psi, timing is moderate and he is only running 3gallons of E85. Injector duty is at 90% up top and he has a very nice flat torque curve through a very large portion of the rev range allowing him to run around 4.5 seconds 60-100. No meth, no 5th port, no extra fuel. The setup is capable of a few more ponies with a more aggressive tune but I think this is a very happy place to be for a DD.
Great job Jevon and thanks for letting Stratified help you get there!
aggierandy and atvfreek like this.
The Following 22 Users Say Thank You to Lex For This Useful Post:
002hex (02-13-2013), aggierandy (02-12-2013), ASHMS3 (02-13-2013), atvfreek (02-12-2013), beachshoer (02-12-2013), BigjohnB20 (02-12-2013), breakfstincluded (02-12-2013), dsb_chicago (02-13-2013), Easter Bunny (02-12-2013), exentix (02-12-2013), Familyguy427 (02-12-2013), forcedinduktion (02-13-2013), Gatorbait (02-12-2013), gsrtype1 (02-12-2013), kish89 (02-12-2013), Nliiitend1 (02-12-2013), Novej (02-12-2013), Rokusek (02-13-2013), SarcasticOne (02-13-2013), smoogs12 (02-18-2013), Vansquish (02-13-2013), Voltwings (02-13-2013)
 Old 02-12-2013, 12:05 AM   #6
DTKII's Avatar
Posts: 247   (View Stats)
DTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the world
What he said
Stay away from RD Motorsportz
DTKII is offline   Reply With Quote
The Following User Says Thank You to DTKII For This Useful Post:
Lex (02-12-2013)
 Old 02-12-2013, 08:48 AM   #7
Novej's Avatar
Originally Posted by DTKII View Post
What he said
Thats the only additional fueling added....
Lex (02-12-2013)
 Old 02-12-2013, 08:57 AM   #8
atvfreek's Avatar
Posts: 7,787   (View Stats)
Perfect tq curve! Great job @Lex; with the tune, and very nice write up @Novej;!
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
ASHMS3 (02-13-2013), Lex (02-12-2013), Novej (02-12-2013), sidekick (02-13-2013)
 Old 02-12-2013, 09:01 AM   #9
razorscs's Avatar
Posts: 391   (View Stats)
razorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the world
In the picture that you were asking if anyone had the same problem, what are we looking at? I ask because my BNR is going in soon and want to be as prepped as possible. Thanks!
Sent from my Nexus 7 using Tapatalk 2
2007 MS6- BNR S3, HTP 3" Intake, 3 Bar MAP, DO Meth, CP-E Catted DP, Autotech Internals, SRI, ETS TMIC, Sure Sidewinder, Sure Charge Tubes, Lex tuned, BC Coils, Sure RMM, JBR SSP, Dreadnaught, Whiteline RSB
2008 Mazdaspeed3- Totalled!
razorscs is offline   Reply With Quote
The Following User Says Thank You to razorscs For This Useful Post:
Novej (02-12-2013)
 Old 02-12-2013, 09:04 AM   #10
lilred's Avatar
Posts: 5,792   (View Stats)
Very nice man
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 02-12-2013, 09:12 AM   #11
Novej's Avatar
Hey shot out to you @atvfreek you and @002hex you guys were my direct motivation for going this route. Also shot out to guys like @Ziggo and anyone else who posted BNR install tips and instructions
Thank you ALL!
I was showing how close my WG actuator is to the fire wall Also something I forgot to mention with installing this way. You def want to remove the EGR valve for easier access!
Last edited by Novej; 02-12-2013 at 09:12 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Novej For This Useful Post:
002hex (02-13-2013), Lex (02-12-2013)
 Old 02-12-2013, 09:15 AM   #12
blackms3_71's Avatar
Posts: 2,250   (View Stats)
damn not bad for that part list makes me think i dont need the 3071
The Following 3 Users Say Thank You to blackms3_71 For This Useful Post:
agentgordon27 (02-13-2013), Lex (02-12-2013), Novej (02-12-2013)
 Old 02-12-2013, 07:32 PM   #13
Domino81's Avatar
Posts: 5,081   (View Stats)
Saw this one the website. Can't wait until I get my BNR.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
The Following 2 Users Say Thank You to Domino81 For This Useful Post:
 Old 02-12-2013, 07:48 PM   #14
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Looking good! Congrats on the numbers. Its amazing what these little turbos can do
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 2 Users Say Thank You to taf0422 For This Useful Post:
 Old 02-12-2013, 07:51 PM   #15
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Nice numbers
Watching verrrry closely.
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
The Following 2 Users Say Thank You to Kdawg207 For This Useful Post:
 Old 02-12-2013, 09:07 PM   #16
Novej's Avatar
AGREED!
Lex (02-12-2013)
 Old 02-12-2013, 09:20 PM   #17
Mistersix's Avatar
Posts: 2,585   (View Stats)
Awesome. 350ftlb from 4-6k! What an awesome torque curve. Nice work.
And yeah, lex is a kick ass.
The Following User Says Thank You to Mistersix For This Useful Post:
Lex (02-12-2013)
 Old 02-12-2013, 09:27 PM   #18
beachshoer's Avatar
Posts: 2,039   (View Stats)
Fantastic numbers! I also went with the BNR with a Lex tune. In week three or four of tuning and its been amazing. Im not going to be seeing those kind if numbers with no E85 and no meth with a stock block that just rolled 116k miles and racing in the heat we're keeping it conservative.
And yes leaving the exhaust mani is the way to go! I've done it both ways. Ya live and learn.
And that Velcro hook stuff is pretty badass. One of those stupid things you don't think about but you're glad someone else did.
2010 BM MS3
BNR S3
STRATIFIED TUNED
Other Mazdas in my stable
2010 VR MS3 Wifes Ride
1999 Miata
2001 Miata LS
The Following 2 Users Say Thank You to beachshoer For This Useful Post:
Lex (02-12-2013), Novej (07-22-2013)
 Old 02-12-2013, 09:45 PM   #19
Novej's Avatar
I mean he's allllllright hahahaha
You know not trying to scare you but Lex said we'd be keeping my tune "conservative" too.........Now I'm convinced ever since I told him I didn't like one of the earlier revisions......He is trying to make my car kill me with the crazy scary torque steer.....LOL!!!
Lex (02-12-2013), Mistersix (02-13-2013)
 Old 02-12-2013, 09:49 PM   #20
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
Simply incredible numbers.. What intercooler are you using?
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
The Following User Says Thank You to ABSpeed3 For This Useful Post:
Lex (02-12-2013)
 Old 02-12-2013, 10:00 PM   #21
Novej's Avatar
Cobb V2 (anodized black core).....
Lex (02-12-2013)
 Old 02-12-2013, 10:16 PM   #22
Familyguy427's Avatar
Posts: 1,476   (View Stats)
Familyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the world
Groaned at 22 Times in 12 Posts
Nice build and great job tuning @Lex;
This makes me want to go Beaner. Pun intended
lilred likes this.
Familyguy427 is offline   Reply With Quote
The Following 2 Users Say Thank You to Familyguy427 For This Useful Post:
Lex (02-13-2013), lilred (02-12-2013)
 Old 02-12-2013, 10:42 PM   #23
Ferdball's Avatar
Posts: 1,340   (View Stats)
Really? Velcro? AMAZING? Where are you from, the middle of... Oh, nevermind...
jk, nice build.
The Following 2 Users Say Thank You to Ferdball For This Useful Post:
Lex (02-13-2013), Novej (02-13-2013)
 Old 02-13-2013, 09:48 AM   #24
Novej's Avatar
jk, nice build.
Hey don't judge me.....and you bite your tongue saying Im from this place!!!!! I was stationed here NOT by choice LOL
Ferdball (02-13-2013), Lex (02-13-2013)
 Old 02-13-2013, 10:05 AM   #25
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Awesome build sir. This is where I would like to end up as well. Glad to see @Lex; took care of ya!
2012 Velocity Red Mica
The Following 2 Users Say Thank You to Dimenus For This Useful Post:
 Old 02-13-2013, 10:08 AM   #26
ckMS3's Avatar
Posts: 1,112   (View Stats)
Awesome write up and numbers!
348tq/367whp -21.5 psi
The Following 2 Users Say Thank You to ckMS3 For This Useful Post:
 Old 02-13-2013, 10:19 AM   #27
Rokusek's Avatar
Posts: 5,551   (View Stats)
Nice fucking work!!! These BNR builds keep stepping up their game and it has made me question a bigger turbo even more...
One more BNR build to pull me in just enought to make me wanna do it!
The Following 2 Users Say Thank You to Rokusek For This Useful Post:
 Old 02-13-2013, 10:25 AM   #28
Vader's Avatar
Posts: 1,651   (View Stats)
Groans: 45
You're built now...
Get a man sized turbo.
The Following User Says Thank You to Vader For This Useful Post:
Lex (02-13-2013)
 Old 02-13-2013, 10:27 AM   #29
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Jelly!
The Following User Says Thank You to forcedinduktion For This Useful Post:
Lex (02-13-2013)
 Old 02-13-2013, 10:28 AM   #30
KevMS6's Avatar
Posts: 316   (View Stats)
Nice write up and great results
Tuned with by
The Following 2 Users Say Thank You to KevMS6 For This Useful Post:
 Old 02-13-2013, 10:57 AM   #31
The "velcro" on the Stratified EBCV is not the stuff you guys are imagining. It is designed for this purpose and the engine bay temperatures. No messy holes in the battery tray or ECU cover needed and you can always relocate the valve.
As for the BNR, there are a few more builds/tunes coming along capable of similar numbers. 400whp with that kind of torque curve on the stock block is pretty ideal in my opinion. The bigger turbos have more capability but the extra HP up top has to be worth the slight loss in spool of the smaller turbo and OEM plug and play. That turbo support brace alone is worth it if running a tubular manifold.
There's always a trade-off just like with everything else and that's why I keep harping - you have to know your goals before jumping into a build or tune. If you know your goals and don't know how to get there, I've put together several articles, always answer questions, and even have a phone support service if a longer chat is needed.
Novej likes this.
The Following 8 Users Say Thank You to Lex For This Useful Post:
atvfreek (02-13-2013), Easter Bunny (02-18-2013), Ferdball (02-13-2013), ktms3 (03-07-2013), magicka (02-13-2013), Novej (02-13-2013), Rokusek (02-13-2013), Vader (02-13-2013)
 Old 02-13-2013, 11:00 AM   #32
Rokusek's Avatar
Originally Posted by Vader View Post
You're built now...
Idk yet, im still in the air about everything. I dont wanna have to deal with fuelling, and personally ill be completely content with 400whp.
The Following 4 Users Say Thank You to Rokusek For This Useful Post:
atvfreek (02-13-2013), Lex (02-13-2013), Vader (02-13-2013), Vansquish (02-13-2013)
 Old 02-13-2013, 11:10 AM   #33
Novej's Avatar
Man this really is an amazing turbo. I even told Bryan he needed to get with Mazda and convince them to use this turbo stock for the next Speed 3. He said they didn't want to contract with him because he wasn't a big "well known" company......
I've noticed little to no difference with spool up between this and the K0whore. However the boost comes on and simply stays on! Lex did a "reverse taper" setup with it which means at like 3500 rpm Im at somethng like 20psi and its just climbing in boost from there.....
^^^^^This............Yeah 400 is perfect for me!!! Honestly it may be too much....I def don't have the tire or suspension set up for it currently.......but that will be fixed here soon
Last edited by Novej; 02-13-2013 at 11:10 AM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to Novej For This Useful Post:
Lex (02-13-2013), Micha (02-13-2013), Rokusek (02-13-2013)
 Old 02-13-2013, 11:24 AM   #34
002hex's Avatar
Posts: 44   (View Stats)
002hex is the leader of the world002hex is the leader of the world002hex is the leader of the world002hex is the leader of the world002hex is the leader of the world002hex is the leader of the world002hex is the leader of the world002hex is the leader of the world002hex is the leader of the world002hex is the leader of the world002hex is the leader of the world
Congrats.. @Lex; is truly the man when it comes to tuning. I love this setup even though traction is a problem 1-3rd gear. Up next is some meth to cool things down.
BNR S3, Cobb BPV,Cobb 3port EBCS, Autotech internals,SURE full 3" aeros , MSCBE, AQ DP, Corksport TMIC, Denso Itv22, SURE RMM, JBR driver side MM(80), Bilstein sports, Eibach springs, Whiteline FSB and RSB, bosch 3 bar map sensor, Devils own DVC-30 WMI, Defi blue racer boost gauge
398.6 HP/ 385 TQ 30%E85
STRATIFIED TUNED
002hex is offline   Reply With Quote
The Following 2 Users Say Thank You to 002hex For This Useful Post:
 Old 02-13-2013, 11:25 AM   #35
julienjj's Avatar
Posts: 292   (View Stats)
julienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the world
I`ll be looking for one of those for my 6 when the turbo start smoking.However, isnt 400hp borderline on stock internals ?
Current money pits:
2006 MS6 Black mica
CP-E RMM|COBB AP|Test pipe|RX-8 oem wheels|Corksport SRI+TIP|Autotech CDFP|Michelin Pilot Super Sports 235/40ZR18|
|HKS SSQV|COBB Sift weight|Corksport mudflaps (Because rallycar)| JBR 70A Sidemounts|
2008 BMW 135i 6MT
M package|JB4 tune|255/35r18 Michelin PSS|BMW Performance exhaust|
julienjj is offline   Reply With Quote
The Following User Says Thank You to julienjj For This Useful Post:
Lex (02-13-2013)
 Old 02-13-2013, 11:29 AM   #36
Rokusek's Avatar
And that sounds perfect, im not looking for 500 plus, nor am i chasing numbers, im content with the setup i have now. Just needs some more tuning and ill be content, but at some point i want a bigger turbo, i have always been fond of the BNRS3 and its capabilities. Considering this is my daily (though its set up like a race car) I drive the shit out of it, so eating up tires cuz im always spinning, or dealing with the lag of a bigger turbo... yea... DO NOT WANT. I have been reading more and more about it, just need to make up my mind. seeing you and @atvfreek;'s threads definately almost made me 90% sure im gonna get a BNR.
The Following 3 Users Say Thank You to Rokusek For This Useful Post:
atvfreek (02-13-2013), Lex (02-13-2013), Novej (02-13-2013)
 Old 02-13-2013, 11:31 AM   #37
With a safe setup that 365 ft lbs of torque is not what I consider unsafe. Heck, lots of people run more torque than this on the K04. The key here is that turbo holds torques much deeper into the rev band meaning more area under the curve and more hp.
Remember
HP = torque*RPM/5252
atvfreek (02-13-2013), Easter Bunny (02-18-2013), Novej (02-13-2013), Rokusek (02-13-2013), sidekick (02-13-2013)
 Old 02-13-2013, 11:55 AM   #38
atvfreek's Avatar
You're built now...
Just because there is a "man sized" turbo under the hood, doesn't always mean it will outperform a smaller turbo. You need fuel, knock protection, a well flowing setup, and most importantly a tune to put it all together. What these BNR's are doing right now is probably better than at least half of all the GT30 or bigger turbos on the speeds right now.
Plus... they cost less, are easier to install, have no IWG problems, get to use the factory turbo bracket, and can even use the stock TIP if you needed to. Lots of good things about going with the BNR.
Rokusek and scorpiorc10 like this.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 17 Users Say Thank You to atvfreek For This Useful Post:
ckMS3 (02-13-2013), Easter Bunny (02-18-2013), Ferdball (02-13-2013), jomc111 (02-13-2013), Lex (02-13-2013), lilred (02-13-2013), maisonvi (02-13-2013), Micha (02-18-2013), mooseaidz (06-15-2016), Novej (02-13-2013), Rokusek (02-13-2013), SarcasticOne (02-13-2013), scorpiorc10 (01-14-2014), scubasteve711 (02-19-2013), sidekick (02-13-2013), taf0422 (02-13-2013), trf5000 (02-13-2013)
 Old 02-13-2013, 11:59 AM   #39
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Damn I want me some BNR.... Nice numbers man.
The Following 3 Users Say Thank You to maisonvi For This Useful Post:
Lex (02-13-2013), Micha (02-18-2013), Novej (03-05-2013)
 Old 02-13-2013, 12:17 PM   #40
agentgordon27's Avatar
Posts: 560   (View Stats)
would this setup have benefited from the boost dial? Obviously you got a good thing going as is; but as far as making the tuning easier I mean.
Stock as fook.
The Following User Says Thank You to agentgordon27 For This Useful Post:
Lex (02-13-2013)
HOW TO GET 400WHP FROM YOUR SPEED 3 (the practical way) EdgeAutosport.com Mazdaspeed3/6 General Discussion 137 11-24-2012 03:36 PM
My 400whp journey wcf I Love Brownies MazdaSpeed 3/6 - Dyno Sheets/Discussions 79 12-15-2011 12:12 PM
Building an 08 MS3. 400WHP Recipe? Daggoth MazdaSpeed 3/6 - Turbo Induction 57 11-15-2010 05:40 PM
The 400whp Club gsrtype1 MazdaSpeed 3/6 - Dyno Sheets/Discussions 16 09-26-2008 03:19 PM
Page generated in 0.67876 seconds with 47 queries
