E-Tuners / Custom Hardparts
  • 1 Post By atvfreek
  • 1 Post By Lex
 Old 08-23-2012, 09:57 AM   #1
LilGator's Avatar
Posts: 136   (View Stats)
LilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Default Big MAF - Sure Full3 AEROS
I'm just about ready to get an e-tune; downpipe and internals are in. I've currently got the regular AEROS installed and running the OTS stage 2 map (Stage2+SUR2 93): https://static.cobbtuning.com/cobbtu...093%20v200.ptm
Sure says Full3 needs a tune, so I'm just wondering if I'm OK to go ahead and install the 3" intake/inlet and drive on this tune or the Stage2+SUR2+TIH 93 OTS (https://static.cobbtuning.com/cobbtu...093%20v200.ptm) for however long needed waiting for an e-tune?
"This MAF size WILL require MAF calibration from the AccessPort via a custom tune, otherwise the car will not run."
Obviously I don't want to custom tune myself just so I can install the 3" and drive a bit waiting for someone else to custom tune!
I'm just wondering what order I need to do things in.
2007 Speed6 GT - LPM
RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP
SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV
MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports
E85 Stratified
LilGator is offline   Reply With Quote
The Following User Says Thank You to LilGator For This Useful Post:
Lex (08-23-2012)
The Following User Says NO Thank You to LilGator For This Un-useful Post:
Monotonous ONE (08-23-2012)
 Old 08-23-2012, 10:31 AM   #2
atvfreek's Avatar
Posts: 7,787   (View Stats)
Don't want to speak for Lex, but I would
1) Sign up for a tune, and he can get you a base map or
2)scale the maf curve yourself by 20% (1.2) and that will get you in the ballpark until he is able to tune you.
I believe you can go on his website and see if he has a spot open for a tune.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Lex (08-23-2012), LilGator (08-23-2012)
 Old 08-23-2012, 10:37 AM   #3
To make the 3" intake work you need to scale the MAF curve at Justin indicated. If you're ready for the tuning process, sign up on my site: Mazda DISI Tuning : Stratified Automotive Controls and complete the Tuning Instructions form including your mods. Don't worry about doing a MAF cal or WOT log now since we will need to redo these for the full 3" intake.
I will then follow up with a map for your 3" intake that this is where we start from.
 Old 08-23-2012, 10:43 AM   #4
For those of you with the SURE 3" here's a MAF cal for the intake. It may need tweaks on individual cars but it's a good starting point and will get the car up and running. Just copy and paste it into your MAF A and B tables (gen1, ms6) and MAF A table for gen2.
Code:
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.02	0.05	0.07	0.12	0.17	0.25	0.32	0.41	0.51	0.63	0.76	0.91	1.05	1.23	1.41	1.63	1.85	2.10	2.37	2.66	2.98	3.33	3.74	4.16	4.58	5.09	5.66	6.25	6.80	7.65	8.24	8.88	9.60	10.41	11.23	12.16	13.18	14.21	15.32	16.82	18.03	19.27	20.60	22.03	23.55	25.17	26.84	28.62	30.48	32.42	34.46	36.57	38.75	41.02	43.37	45.82	48.35	50.99	53.71	56.55	59.51	62.55	65.70	68.89	72.12	75.44	78.83	82.31	85.89	89.56	93.36	102.19	106.46	110.85	115.34	119.96	124.67	129.46	134.30	139.27	144.36	149.57	154.90	160.38	166.01	171.78	177.78	183.99	190.36	196.90	203.59	210.44	217.46	224.63	231.98	239.48	247.11	254.89	262.85	270.98	279.27	287.74	296.40	305.24	314.27	323.50	332.91	342.52	352.32	362.32	372.51	382.93	393.53	404.35	415.38	426.61	438.06	449.74	461.63	473.74
The Following 10 Users Say Thank You to Lex For This Useful Post:
08.5MS3 (08-23-2012), atvfreek (08-23-2012), Dmurray06 (08-23-2012), Don06speed6 (08-23-2012), IMASA (10-24-2012), LilGator (08-23-2012), MarkyMark (08-24-2012), Monotonous ONE (08-23-2012), Onelovesoccer (08-23-2012), rfinkle2 (08-23-2012)
 Old 08-23-2012, 10:47 AM   #5
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
You quoted the part where it says the car will not run.
Then you still asked if you can drive on it until a proper tune.
What part of "will not run" is so difficult to understand?
 Old 08-23-2012, 12:22 PM   #6
LilGator's Avatar
If you notice, the post is edited. After searching some more I found that quote and added it to the post for anyone else's benefit. No need to be a dick.
Regardless, the question remains the same and I appreciate Justin & Lex letting me know what I need to do. This makes things easy.
E85 Stratified
 Old 08-23-2012, 08:27 PM   #7
Groans: 819
I half respectfully and half disrespectfully disagree about not needing to be a dick.
You got solid answers from atvfreek and lex cause they are overly nice (and physically attractive) guys.
 Old 08-24-2012, 06:47 AM   #8
LilGator's Avatar
I can work with that.
E85 Stratified
SURE Aeros SRI G26 2010 MS3 - Turbo Induction 10 05-02-2011 07:15 AM
Page generated in 0.30423 seconds with 23 queries
