E-Tuners / Custom Hardparts
  • 1 Post By Bulgsta
 Old 05-31-2014, 06:44 PM   #1
Bulgsta's Avatar
Posts: 120   (View Stats)
Bulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond repute
Default Flashing lights at low boost
Ok I recently dropped in a new turbo with bunch of other supporting mods. One of them was a guardian angel.
Now that I have the car running, I am boosting very low 14-15 psi. I enabled VTA mode on the guardian angel and set the setpoint to 25 psi just so it does not interfere with the tuning at the moment.
At the moment I returned my GFB bov from 50/50 back to 100% recirc.
Solid light under vacuum, no light from -5 psi to 10 psi and once my EWG opens and I hit my 14-15 psi boost the light flashes on and off rapidly.
Any idea what that could be?
Is it because the valve is at 100% recirc and not VTA anymore?
Thanks
2007 Mazdaspeed 6
GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel
Bulgsta is offline   Reply With Quote
The Following User Says Thank You to Bulgsta For This Useful Post:
Lex (06-01-2014)
 Old 05-31-2014, 08:27 PM   #2
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Thanks
And you are expecting a logical answer?
WTF bro
The Following 2 Users Say Thank You to pzr2874 For This Useful Post:
Easter Bunny (06-01-2014), Vansquish (06-01-2014)
 Old 05-31-2014, 08:35 PM   #3
Bulgsta's Avatar
Apparently not from you.
2007 Mazdaspeed 6
The Following 2 Users Say NO Thank You to Bulgsta For This Un-useful Post:
 Old 05-31-2014, 08:44 PM   #4
pzr2874's Avatar
Groans: 146
Touche....
What light are you referring to? Traction?
 Old 05-31-2014, 08:57 PM   #5
Bulgsta's Avatar
The GA led indicator. Not sure what it means when it flashes
2007 Mazdaspeed 6
 Old 05-31-2014, 09:01 PM   #6
pzr2874's Avatar
Groans: 146
List what mods you have done. I have no clue wtf that indicator is.
 Old 05-31-2014, 09:23 PM   #7
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Have you tried switching the VTA mode back to the norm position? The LED usually indicates that the overboost protection has been triggered but I have only seen it as a solid LED when lit. Any logs/maps you can post?
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
pzr2874 (06-01-2014)
 Old 05-31-2014, 09:37 PM   #8
Bulgsta's Avatar
I will switch it back tomorrow. Currently I have a 14.5 spring in the EWG and i am boosting 14.5 psi at which point the EWG opens and maintains that 14.5. its just at WOT and when the EWG is open the led flashes rapidly.
Tomorrow I will try few things:
1) dropping the setpoint to 10 PSI see what it does
2) open my BOV to 50/50 and test it like that
3) I will turn the VTA option off
Here is a log but I doubt it will help. again my EWG as of now is controlled only by the spring
2007 Mazdaspeed 6
 Old 05-31-2014, 10:28 PM   #9
ms6mil's Avatar
Groans: 307
I'm assuming you already tried increased WGDC values, any logs with WGDC other than zeroed out and still only hitting 14 psi?
PTE5862 - TBD
 Old 06-01-2014, 06:40 AM   #10
Bulgsta's Avatar
Since I only just started the car few days ago this map has 0 WGDC because I wanted to get the turbo worked in not really hitting boost. My tuner upped the boost for the new map so I will let you guys know today
2007 Mazdaspeed 6
 Old 06-01-2014, 08:53 AM   #11
The LED on the GA will light when the bpv is being controlled by the GA. This will happen under 3 circumstances.
1. When the unit first starts up. One flash for non vta mode and two for vta mode.
2. When there is boost pressure on the bpv in line exceeds the threshold set on the dial causing the unit to protect from over boost.
3. If in vta mode under a certain amount of vacuum.
From what you are describing there are pressure pulsations on the bpv line under boost. Can you draw a little diagram or describe how your vacuum lines are connected and how the GA is connected?
Also make sure the line going to the bpv is connected to bpv out on the GA.
Bulgsta (06-01-2014)
 Old 06-01-2014, 09:37 AM   #12
Bulgsta's Avatar
Intake mani-->vacuum block-->GA bpv in-->bpv
Lex likes this.
2007 Mazdaspeed 6
Lex (06-01-2014)
 Old 06-01-2014, 10:49 AM   #13
Does it do this only in VTA mode?
 Old 06-01-2014, 05:42 PM   #14
Bulgsta's Avatar
Switched back to normal mode (non VTA) and it does not do it anymore.
I'll try it back into VTA mode and let you guys know
2007 Mazdaspeed 6
 Old 06-02-2014, 09:46 AM   #15
Check that it triggers normally at a 10psi test for overboost. The flashing light under VTA means the unit is detecting vacuum somehow which is a little odd. PM me with the results from the 10psi test and we will go from there to diagnose and fix the issue.
Bulgsta (06-02-2014)
 Old 07-21-2014, 09:45 PM   #16
Bulgsta's Avatar
Btw nothing was wrong with the GA. I wired a LED for when my meth sprays and instead of a blue LED they sent me a red one. Paying attention to the road i saw a red led flash so i figured it would be the GA LED but I was wrong.
Sorry about the post
2007 Mazdaspeed 6
Lex (07-22-2014)
 Old 07-22-2014, 12:35 AM   #17
Thanks for following up and clearing this up.
Bulgsta (07-22-2014)
Flashing lights, bogging Remixaflip MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 03-14-2014 10:27 PM
Report: Florida judge rules flashing lights for speed trap warning is covered under free speech Haltech Automotive News 1 05-24-2012 12:01 AM
BSM and Traction lose lights flashing dantes5823 Gen2 MS3 General Discussion 3 02-18-2012 04:22 PM
flashing boost on ap paulwalll MazdaSpeed 3/6 - ECU Computer Tuning 12 04-02-2011 11:25 AM
HIDs, Reverse lights, Liscence Plate lights Franconemo Exterior 31 06-12-2010 03:25 AM
Page generated in 0.35869 seconds with 24 queries
