E-Tuners / Custom Hardparts
View Poll Results: Would you buy the Guardian Angel?
Yes - no more overboost fears! 141 92.16%
No ... 12 7.84%
Voters: 153. You may not vote on this poll
Like Tree33Likes
 Old 02-07-2012, 10:26 AM   #1
Default GI: Guardian Angel (Overboost Protection)
Alright guys, this is a GI thread for the Guardian Angel. I need to know what my initial production batch number should be based on initial demand because these things are expensive to make and it takes a little while for the case to be manufactured.
There are a bunch of pictures and information here but I will summarize below: http://www.mazdaspeedforum.org/forum/foru...02/index4.html
What is does:
- Prevents overboost conditions or acts as a methanol or other controller failsafe.
- It will prevent boot spikes due to cold weather, tuning issues.
- It will even prevent you overboosting if your WG line pops off.
- It has a built in trigger that can be used with meth controllers or other controllers. If the meth flow shuts off and the meth controller senses it, the device will trigger and cut your boost - usually below WG pressure.
- It is a much gentler cut than the fuel cut. The car will feel like it lost power, but you will still be able to keep your foot in it if you choose. This is NOT a fuel cut or ignition cut.
- Once you take your foot off the gas, the device resets automatically.
- The Guardian can be set to trigger at boost levels between 10-40psi.
- There is a warning LED that lights if the device is tripped. It also lights every time you turn on your car to show you it is working.
This will work with any boost controller, MBC, EBC, or stock. So if you're tuning, modifying the car, or doing any work with the boost system, as long as this device is installed properly it will save you from the dreaded overboost condition and likely bent rods.
What it works on:
- ANY turbocharged vehicle with a pull type/piston type BPV such as the stock one, Forge, Greddy, etc. It does not work with the HKS SSQV. If you have a BPV and want to know if it will work contact me.
Price
- $179
FIRST REVIEW HERE: http://www.mazdaspeedforum.org/forum/foru...3/#post1302377
I currently have 7 left from a first batch. However these are mostly spoken for with just a few left over. What I need to know is how many of you would purchase one to know how large of an order to make next since it takes 4 weeks for things to be built.
p057, Bucker, uncorked11 and 2 others like this.
The Following 38 Users Say Thank You to Lex For This Useful Post:
86AmishMs3 (03-18-2012), ak_spray (02-07-2012), atvfreek (02-07-2012), AZSPEED3 (02-07-2012), bigriver (02-07-2012), Bucker (02-07-2012), charlesfist (02-07-2012), Ckmazdaspeed3 (02-07-2012), Dano (02-07-2012), Dash08 (03-26-2012), daztdMS6 (02-07-2012), djuosnteisn (02-07-2012), EL F00LI0 (02-11-2012), Fail_6 (05-12-2012), Fobio (02-10-2012), franz (02-17-2012), Ingle (02-21-2012), jman46 (02-25-2012), kgb (02-08-2012), kunfu (02-25-2012), mayer (02-11-2012), Mistersix (06-10-2012), Mizzle (04-14-2012), ms3bamf (02-07-2012), MS6FL (02-28-2012), Nataphen (03-24-2012), p057 (02-29-2012), Raider (02-16-2012), ryno077 (02-07-2012), Scoobs (03-26-2012), TexasSpeed3 (03-03-2012), uncorked11 (03-25-2012), wankular (02-07-2012), wolly6973 (02-07-2012), xdm88 (05-26-2012), xI Leveler Ix (06-02-2012), Ziggo (02-07-2012), zpele (02-16-2012)
 Old 02-07-2012, 10:39 AM   #2
bigriver's Avatar
Posts: 1,123   (View Stats)
bigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the world
How is the install and de-mod (stock out for emissions check and dealer warranty visits)? If its not too bad, I'm down for one. Thanks Lex!
Edit: seems easy enough. I'm down!
2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. .
bigriver is offline   Reply With Quote
The Following User Says Thank You to bigriver For This Useful Post:
Lex (02-07-2012)
 Old 02-07-2012, 10:42 AM   #3
Install is very simple and I will post it here shortly. Basically, you need power and ground (add a fuse in the stock fuse panel and use the ground on fender where the battery grounds).
You also remove the BPV vacuum line, plug this line into the Guardian, and then plug the second port from the Guardian into the BPV.
The LED you can route into the the cabin without any modifications through the hood release cable passthrough.
So there are no modifications that are not reversible and it should take no more than 1 hour to install.
bigriver likes this.
The Following 8 Users Say Thank You to Lex For This Useful Post:
AZSPEED3 (02-07-2012), bigriver (02-07-2012), charlesfist (02-07-2012), Dash08 (03-26-2012), IanMacKenzie (11-27-2013), rfinkle2 (02-07-2012), TexasSpeed3 (03-03-2012), wolly6973 (02-07-2012)
 Old 03-09-2012, 04:58 PM   #4
HPFPUPGRADE's Avatar
Posts: 403   (View Stats)
HPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the world
Groaned at 22 Times in 17 Posts
Any worries about potential over spinning the turbo with the BOV open while the turbo is still trying to target XX boost?
This also got me thinking about being on PCM controlled boost. If there is a leak and the system cannot see it, will the adaptive in the PCM continue to adjust to reach that target?
HPFPUPGRADE is offline   Reply With Quote
 Old 03-09-2012, 04:59 PM   #5
708
Erich's Avatar
Posts: 4,274   (View Stats)
Warning is already stated that it is not to be used as a boost controller.
The Following 2 Users Say Thank You to Erich For This Useful Post:
Lex (03-09-2012), rfinkle2 (03-13-2012)
 Old 03-09-2012, 05:03 PM   #6
Thanks, so this would simply be for boost cut if over boost happened?
I only ask because I made something very similar to this for the SRT4 market and it killed several turbo's in a very short period of time, product never made it to market because of this.
 Old 03-09-2012, 05:03 PM   #7
This depends on how it is setup. If you are in load tuning mode and recirculating then it will still target load based on what the MAF sees regardless of whether the BPV is open or closed.
The ECU will always try and reach targets. This device is meant to save the motor from a catastrophic condition, not to be ridden on every day as a means to control boost.
The other thing to note is that once you're building less boost, you're generating less exhaust, and are naturally not going to spin the turbine as fast.
 Old 03-09-2012, 05:07 PM   #8
In boost tuning mode this could become a problem?
I am only commenting on this because you stated, "- It is a much gentler cut than the fuel cut. The car will feel like it lost power, but you will still be able to keep your foot in it if you choose. This is NOT a fuel cut or ignition cut."
Keeping your foot into the throttle with the BOV open could be catastrophic to the turbo, RPM's could potentially kill the turbo.
Other than that, its a great idea!
 Old 03-09-2012, 05:04 PM   #9
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
If you see the logs you'll notice the charge air pipes are still pressurized even when the BPV opens. IM pressure remains at about 7-10 psi. I.e. there is still back pressure holding the compressor from overspining.
The engagement feels really gentle.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
charlesfist (03-14-2012), Dano (03-12-2012), jracer (03-10-2012), Lex (03-09-2012)
 Old 02-07-2012, 10:41 AM   #10
starscream's Avatar
Posts: 630   (View Stats)
Groans: 44
Lex done.. I am taking one.
The Following User Says Thank You to starscream For This Useful Post:
Lex (02-07-2012)
 Old 02-07-2012, 10:45 AM   #11
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Four weeks should be perfect for me to get back on my feet from the build. I'm in.
I use turbo smart 50/50. Let me know if that is an issue. Thanks.
Also, pff topic, you got your piston and rod, right? If I left out anything you needed, let me know, cuz I found more stuff as I've been assembling the motor.
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
Lex (02-07-2012)
 Old 02-07-2012, 10:48 AM   #12
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
I'm down.
The Following 2 Users Say Thank You to triplejumper18 For This Useful Post:
breakfstincluded (03-09-2012), Lex (02-07-2012)
 Old 02-07-2012, 10:48 AM   #13
Ferg's Avatar
Posts: 1,498   (View Stats)
Ferg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the world
i will buy one, just not at this moment. definitely interested in getting this before i start upping boost and what not.
2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011
2008 Black Ms3 SOLD
Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs
AP Dizzy Tuned by BUCKER
CorkSport Interior LED Kit
2015 STi Limited in Lightning Red
Stock bottom end died at 18K hard canyon miles.
Current Mods after build
Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune
[11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap
Ferg is offline   Reply With Quote
The Following User Says Thank You to Ferg For This Useful Post:
Lex (02-07-2012)
 Old 02-07-2012, 12:07 PM   #14
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
I'm with you. Don't need one now but will need one soon.
07 MS3 Sport
CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP
SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon)
JBR: RSB
Cobb: Accessport
Corksport: TMIC
CNT: Catted Downpipe
ak_spray is offline   Reply With Quote
The Following 2 Users Say Thank You to ak_spray For This Useful Post:
Lex (02-07-2012), rfinkle2 (02-07-2012)
 Old 02-07-2012, 10:48 AM   #15
Next in line. Thank you for putting this out Lex. Very handy to have.
I can think of a good example, right off of the top of my head... One of the best tuners (imo) and knowledgable guys on the forum, cld12pk2go had his vacuum cap slip off the bottom of his wg actuator when he was running the grimmspeed.
He hit something in the neighborhood of 28 psi (iirc)..(no boost cut from protective tables in atr, btw)
hyperlink to post here:
http://www.mazdaspeedforum.org/forum/foru...tml#post982330
Moral of the story is that it can happen to anyone and the price of this device is WAY less than a rebuild.
Bucker likes this.
The Following 9 Users Say Thank You to rfinkle2 For This Useful Post:
AZSPEED3 (02-07-2012), bigriver (02-07-2012), charlesfist (02-07-2012), Dano (02-07-2012), daztdMS6 (02-07-2012), Lex (02-07-2012), TexasSpeed3 (03-03-2012), trf5000 (02-07-2012), wolly6973 (02-07-2012)
 Old 02-07-2012, 10:52 AM   #16
There are a lot of classic examples out there:
This inspired me. Another experienced guy:
http://www.mazdaspeedforum.org/forum/foru...27/#post797379
atvfreek (02-07-2012), charlesfist (02-07-2012), Ckmazdaspeed3 (02-07-2012), daztdMS6 (02-07-2012), Ferg (02-07-2012), rfinkle2 (02-07-2012), TexasSpeed3 (03-03-2012), wolly6973 (02-07-2012)
 Old 02-07-2012, 10:52 AM   #17
starscream's Avatar
Groans: 44
For me is more because I prefer to Load Tune over Boost Tune (Yeah FYBT) and with the weather having various extreme temps (well not too extreme recently in Ontario) I have been known to get spiking. I have been working more and more on the spikes, but it would be nice to have a backup safety just in case.
The Following 3 Users Say Thank You to starscream For This Useful Post:
Ferg (02-07-2012), Lex (02-07-2012), rfinkle2 (02-07-2012)
 Old 02-07-2012, 11:13 AM   #18
darth_speeder's Avatar
Posts: 653   (View Stats)
darth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the world
i can see myself picking one of these up once i start upgrading. better safe then sorry.
[SIGPIC][/SIGPIC] Corn Fed//Richtuned
darth_speeder is offline   Reply With Quote
The Following User Says Thank You to darth_speeder For This Useful Post:
Lex (02-07-2012)
 Old 02-07-2012, 11:18 AM   #19
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
I will most definitely take one. Will the install be an issue if I have my boost gauge tee'd into my bpv vac line?
Sent from my BlackBerry 9300 using Tapatalk
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
The Following User Says Thank You to EL F00LI0 For This Useful Post:
Lex (02-07-2012)
 Old 02-07-2012, 11:20 AM   #20
Not at all.
Ferg (02-07-2012)
 Old 02-07-2012, 11:23 AM   #21
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
Fantastic idea. I prolly will not be in on the first few batches but this is something I will def purchase in the future.
The Following 2 Users Say Thank You to captain slow For This Useful Post:
Lex (02-07-2012), wolly6973 (02-07-2012)
 Old 02-07-2012, 11:28 AM   #22
708
Erich's Avatar
I will take one. Can never have too much protection. I like to claim that is why I triple up condoms too, but really it is so I can last more then 2 pumps.
rfinkle2, Eric28243 and Ingle like this.
The Following 6 Users Say Thank You to Erich For This Useful Post:
Ferg (02-07-2012), Ingle (02-21-2012), Lex (02-07-2012), rfinkle2 (02-07-2012), wolly6973 (02-07-2012), Worbit (03-21-2012)
 Old 02-07-2012, 11:29 AM   #23
Ziggo's Avatar
Posts: 3,843   (View Stats)
Fantastic product and idea. Put me down for one, I will help in the testing too if needed.
Zigatapatalka
Ask Me About My:
 Old 02-07-2012, 11:35 AM   #24
trf5000's Avatar
Posts: 2,290   (View Stats)
Lex,
You should sell this to mazda. Should be a factory option on this car haha.
I think you are crazy not to want this. $179 for motor insurance.
Ferg likes this.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following 3 Users Say Thank You to trf5000 For This Useful Post:
 Old 02-07-2012, 11:46 AM   #25
wankular's Avatar
Posts: 4,343   (View Stats)
I will pick one up too. Not on this batch but probably the next one.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
Lex (02-07-2012)
 Old 02-07-2012, 11:50 AM   #26
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Definetly a good thing even for those that have basic mods and only starting to tune. $180 and an hour of work is worth peace of mind to me.
rfinkle2 and Blackedout1978 like this.
TEAM LUXURY
The Following 3 Users Say Thank You to Sid3wayS For This Useful Post:
 Old 02-07-2012, 12:06 PM   #27
charlesfist's Avatar
Posts: 281   (View Stats)
charlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the world
I may have missed it, but does it basically manipulate the pressure in the vacuum line to activate the BPV based on certain trigger conditions. I'm guessing its response time is pretty quick and has no relation to how much boost your are running or trying to bleed off in an over boost condition.
Also how easy is it to fine tune the boost set point potentiometer looking device. Least count around 1psi? hard to tell because of only 3 markings of 10, 25 and 40 psi.
Great work in making this safety system a reality Lex and great price point too.
Looks like the best insurance policy anyone could carry on their motor.
charlesfist is offline   Reply With Quote
The Following 3 Users Say Thank You to charlesfist For This Useful Post:
 Old 02-07-2012, 12:35 PM   #28
This is correct. The response is fairly fast and it is the same regardless of the boost you are running.
The markings are there as guidelines. The potentiometer is "infinitely tunable" and the resolution is quite good but it would have been too busy to make lots of markings on the case. What I suggest is that you set this up through a couple of trial runs where your normal boost levels are just below the trigger point.
So essentially, install it, set it to 10psi, see how car responds so that you are not taken aback when/if it triggers. Then move the trigger point up until you are just over your normal boost levels.
Even if this triggers falsely (ie you set it too low), it is very easy to adjust up and the car will continue running just fine. It is not a violent cut so if you are passing a slower car you do not lose all power. I notice that on my setup, I settle around 9-10psi with it triggered and still going WOT.
Of course don't use this as a boost controller, the turbo would have to work unnecessarily hard.
The Following 7 Users Say Thank You to Lex For This Useful Post:
charlesfist (02-07-2012), Erich (02-07-2012), Ferg (02-07-2012), Ingle (02-21-2012), rfinkle2 (02-07-2012), TiGraySpeed6 (02-07-2012), wolly6973 (02-07-2012)
 Old 02-07-2012, 01:16 PM   #29
Ferg's Avatar
so to dumb this down alot. what you are saying is if im presently at 14-15psi. set this to 10, and do a run. after it sets off at 14-15 turn it up a lil and go again. keep my eye on the ap and my boost levels and just go from there. till about 19 or so, then leave it there. i have been known to spike to 19 under conditions and that would be about my safety net. or turn it down to 17/18 to keep from reaching 19. correct?
2008 Black Ms3 SOLD
 Old 02-07-2012, 01:53 PM   #30
Think of this as the device that will stop a damaging boost spike. If you regularly spike to 19, I would set this to 21. An MS3 will not blow from a 19psi spike or a 21psi spike. Just set it a few psi the max level you usually see.
charlesfist (02-07-2012), rfinkle2 (02-09-2012)
 Old 02-07-2012, 02:23 PM   #31
Ferg's Avatar
gotcha lol
2008 Black Ms3 SOLD
 Old 02-07-2012, 02:42 PM   #32
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
I'm very interested on this product. Thank you for this thread Lex. Question, will there be maybe an opt for different colors for the Guardian Angel unit?
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
The Following User Says Thank You to daztdMS6 For This Useful Post:
Lex (02-07-2012)
 Old 02-07-2012, 02:43 PM   #33
Not for now due to volume ... but if these start selling the 100s across multiple platforms then it will certainly be.
 Old 02-07-2012, 02:47 PM   #34
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
Groans: 82
Will this be the 1st series price and then it will raise? Or will this be the set price point?
The Following User Says Thank You to deadlandxtreme For This Useful Post:
Lex (02-07-2012)
 Old 02-07-2012, 02:56 PM   #35
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Lex,
I am def interested. So if my FS controller detect a WMI fault it can trigger the GA to open the BPV? badassness!
IIRC my Labonte sends a constant 5v signal until there is a fault. I would bet your looking for a 5v signal when there is a fault....If so I think an SPDT relay should resolve that as I do this for my in dash lights.
charlesfist (02-07-2012), Lex (02-07-2012)
 Old 02-07-2012, 03:01 PM   #36
Intent is to keep the price at this level.
Lex,
Yes, this is correct. The signal has to be high - 3V and above to trigger so if your kit sets it to low then you will have to invert it yes.
Last edited by Lex; 02-07-2012 at 03:01 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-07-2012, 03:03 PM   #37
Trail of Fail
Dano's Avatar
yea the Labonte IFS-25 FS is totally backward from the IFS-10. It sends a constant 5 [or maybe 12v] signal UNTIL a fault is detected...kinda a double failsafe...if the FS is broken it will trip or if there is a fault it will trip.
in normal operation if you were looking for a signal to indicate fault and the FS was fried...well so would you be
 Old 02-07-2012, 03:24 PM   #38
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
What if we plan on running 50psi?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
86AmishMs3 (03-18-2012), ak_spray (02-07-2012), Dano (02-07-2012), Erich (02-07-2012), Lex (02-07-2012)
 Old 02-07-2012, 03:28 PM   #39
At 50psi, your balls are so large it doesn't matter if you blow. Because if you do, you take it like a boss and build the motor to take 100psi.
But in all seriousness in that case I would need to look at an 80 or 100psi sensor and the resolution would drop.
Dano (02-07-2012), djuosnteisn (02-07-2012), Ingle (02-21-2012), jman46 (02-25-2012), Nliiitend1 (02-14-2012), p057 (06-03-2012)
 Old 02-07-2012, 03:52 PM   #40
Groans: 398
This thing has to sell big time. Its just a matter of you getting this thing some visibility on all sorts of platforms. This thing is such a good idea I just cant believe this hasn't been a staple of building turbo cars as long as they've been around.
The Following User Says Thank You to captain slow For This Useful Post:
Lex (02-07-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/gi-guardian-angel-overboost-protection-104486/
Mazda MPS Owners Club • View topic - Overboost protection... This thread Refback 03-25-2012 04:24 AM
The Guardian Angel for your motor Lex Stratified Automotive Controls 158 10-28-2015 12:55 PM
Angel Eyes? Sparky_86 MazdaSpeed 6 - How-To's 26 05-20-2010 04:58 PM
Angel Eyes TXspeed3 MazdaSpeed 3/6 - Appearance 2 06-28-2009 08:36 PM
Angel Eyes Ballast kingpin748 Mazdaspeed3/6 General Discussion 0 04-20-2009 04:53 PM
Page generated in 0.74692 seconds with 44 queries
