E-Tuners / Custom Hardparts
 Old 07-15-2013, 10:27 PM   #1
jakk's Avatar
Posts: 3,266   (View Stats)
jakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the worldjakk is the leader of the world
Default Great tuning experience
I just finished my 93 and E85 tunes with Alex, and the experience could not have been any better. It was obvious from the start that Alex was committed to getting the most power possible out of my car safely. All of my questions were answered promptly and concisely, and I would not hesitate for a moment to recommend Stratified for all your tuning needs! The 93 tune pulled much stronger than any OTS map I had, and the E85 tune pulls like a freight train, I really can't believe the power increase. I am having waaay too much boiling tires in 2nd lol.
I would like to get my car on an actual dyno sometime soon as the roads around me are not great for VD runs, but here is one run that I was able to get.
2012 Black Mica MS3|Autotech internals|SURE ID300 Full3 Aeros|ETS TMIC|UR TP|AP(Stratified 93 and E85 tunes)|NGK one step colder|Forge V2 BPV|JBR RSB|CP-E Stage 2 RMM|JBR shifter bushings
jakk is offline   Reply With Quote
The Following 4 Users Say Thank You to jakk For This Useful Post:
Dimenus (07-17-2013), Hush (07-15-2013), Lex (07-15-2013), Mike@Stratified (07-16-2013)
 Old 07-17-2013, 01:31 PM   #2
secondchance's Avatar
Posts: 421   (View Stats)
secondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the world
Groaned at 114 Times in 37 Posts
that vd run on 93 or e85 or a mix?
2009 Subaru WRX 265 Sedan || Cobb AP || Cobb SF intake w/ air box || Process West TMIC || Tein Springs || Grimspeed 3 port || Forge BPV || Invidia Catback || UR Downpipe || Kartboy short throw w/ cobb knob and bushings || Cobb Heatshield || DW65c fuel pump || NGK 1 steps
In Garage for Spring || HSD Coilovers || Eibach f+r sway bars || Whiteline positraction bushing kit || Kartboy Endlinks || Whitelink endlink reinforcements || GTSpec front + rear sway bars || Stoptech front and rear rotors,pads,lines
Sold
2007 MS3 295 whp 350 Torque
2010 Evo X 440AWHP 11.7 @ 113
2009 Ralliart w/ xswap 320AWHP (first in canadia to break 300whp in gen2 RA) 12.4@ 108
2004 srt-4 s2
2006 ms6
2005 srt-4 s3 w/toys 12.16 @ 117
secondchance is offline   Reply With Quote
 Old 07-17-2013, 01:43 PM   #3
manila's Avatar
Posts: 1,767   (View Stats)
@jakk; I'd like to know this as well^^
'12 MS3 Black Mica w/ Tech
 Old 07-17-2013, 01:46 PM   #4
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
e85 mix
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
 Old 07-17-2013, 03:41 PM   #5
jakk's Avatar
E85, sorry I should have clarified that. My best on 93 was like 283/316. It was very humid that night so I'm not sure how much of a difference that makes. At any rate, I would like to get on an actual dyno someday. I would estimate I am in the 305-310 whp range on a day with ideal temps/humidity.
The Following User Says Thank You to jakk For This Useful Post:
Lex (07-17-2013)
 Old 07-17-2013, 03:53 PM   #6
manila's Avatar
Humidity is no bueno. Nonetheless, you have great numbers!
Lex (07-17-2013)
My experience installing and tuning BNR stage 3 nofear72784 MazdaSpeed 3/6 - Big Turbo Builds 41 02-05-2015 09:07 AM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 177 12-03-2011 12:53 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning Cobb Tuning 1 08-31-2011 07:43 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 08-31-2011 07:32 PM
Page generated in 0.27106 seconds with 24 queries
